Home » Eclipse Projects » EclipseLink » Bug with IndirectMap?
Bug with IndirectMap? [message #503989] Wed, 16 December 2009 12:43 Go to next message
In my multithreaded WS call, I keep getting locked on the following line.
at java.lang.Object.wait(Object.java:485)
at org.eclipse.persistence.internal.helper.WriteLockManager.acq uireLocksForClone(WriteLockManager.java:82)
- locked <0x9da44f68> (a org.eclipse.persistence.internal.helper.ConcurrencyManager)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.clo neAndRegisterObject(UnitOfWorkImpl.java:960)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.clo neAndRegisterObject(UnitOfWorkImpl.java:898)
at org.eclipse.persistence.internal.sessions.UnitOfWorkIdentity MapAccessor.getAndCloneCacheKeyFromParent(UnitOfWorkIdentity MapAccessor.java:17
at org.eclipse.persistence.internal.sessions.UnitOfWorkIdentity MapAccessor.getFromIdentityMap(UnitOfWorkIdentityMapAccessor .java:110)
at org.eclipse.persistence.internal.sessions.IdentityMapAccesso r.getFromIdentityMap(IdentityMapAccessor.java:331)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.reg isterExistingObject(UnitOfWorkImpl.java:3889)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.reg isterExistingObject(UnitOfWorkImpl.java:3849)
at org.eclipse.persistence.mappings.CollectionMapping.buildElem entClone(CollectionMapping.java:240)
at org.eclipse.persistence.internal.queries.MapContainerPolicy. buildCloneForValue(MapContainerPolicy.java:208)
at org.eclipse.persistence.internal.queries.MapContainerPolicy. addNextValueFromIteratorInto(MapContainerPolicy.java:169)
at org.eclipse.persistence.mappings.CollectionMapping.buildClon eForPartObject(CollectionMapping.java:195)
at org.eclipse.persistence.internal.indirection.UnitOfWorkQuery ValueHolder.buildCloneFor(UnitOfWorkQueryValueHolder.java:51 )
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiateImpl(UnitOfWorkValueHolder.java:162)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiate(UnitOfWorkValueHolder.java:230)
at org.eclipse.persistence.internal.indirection.DatabaseValueHo lder.getValue(DatabaseValueHolder.java:83)
- locked <0x9db159b0> (a org.eclipse.persistence.internal.indirection.UnitOfWorkQuery ValueHolder)
at org.eclipse.persistence.indirection.IndirectMap.buildDelegat e(IndirectMap.java:110)
at org.eclipse.persistence.indirection.IndirectMap.getDelegate( IndirectMap.java:316)
- locked <0x9db159e8> (a org.eclipse.persistence.indirection.IndirectMap)
at org.eclipse.persistence.indirection.IndirectMap.get(Indirect Map.java:303)
The postgres connection just says "Idle in transaction." I've tried synchronizing my code all t he way up to the highest level, and I still keep getting this lockup. Is this a bug with eclipselink?
-Brendan
[Updated on: Wed, 16 December 2009 12:43] by Moderator
Re: Bug with IndirectMap? [message #504176 is a reply to message #503989] Thu, 17 December 2009 10:11 Go to previous message
Deadlocks are normally difficult issues to diagnose, so if you have an EclipseLink support contract with Oracle, and would recommend to contact technical support.
If you could include what the other threads are blocked on it would be helpful. Also some indication of what you are doing and how to recreate the issue. Does this issue only occur when using a Map?
Some things to try would be,
- disable the cache (shared=false)
- ensure you are using LAZY (indirection) on every relationship
There are also some debug methods on IdentityMapAccessor to print out locks, these may be of some use.
Previous Topic:keeping a history: who done it?
Next Topic:FetchGroup help
Current Time: Sun Jul 20 12:19:29 EDT 2025
Powered by FUDForum. Page generated in 0.03967 seconds
