Home » Eclipse Projects » Rich Client Platform (RCP) » Application not launching on second launch(Application not launching on second launch - setExportPackages)
Application not launching on second launch [message #503795] Tue, 15 December 2009 09:52
I have an application and the first time it is launched, everything works fine, however the second time the below exception happens on launch. It appears that eclipse is not reading in all of the exported packages for com.company.system.configuration. The following are defined in it MANIFEST.MF, but eclipse is only reading in the first 3. Has anyone seen this issue before? If I put a -clean in my application .ini file everything works. It appears something is screwed up with eclipse caching some values. Thanks
Export-Package: com.company.system.configuration;version="1.0.0", com.c
erner.system.configuration.repository;version="1.0.0", com.company.sys
tem.configuration.repository.internal;version="1.0.0", com.company.sys
tem.configuration.repository.spi;version="1.0.0"
org.eclipse.core.runtime.CoreException: Plug-in com.company.system.configuration.manager.client was unable to load class com.company.system.configuration.manager.client.Application.
    at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
    at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:162)
    at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:867)
    at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
    at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:188)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
    at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.setExportPackages(BundleDescriptionImpl.java:224)
    at org.eclipse.osgi.internal.resolver.StateReader.readBundleDescriptionLazyData(StateReader.java:259)
    at org.eclipse.osgi.internal.resolver.StateReader.fullyLoad(StateReader.java:681)
    at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.fullyLoad(BundleDescriptionImpl.java:487)
    at org.eclipse.osgi.internal.resolver.BundleDescriptionImpl.getResolvedRequires(BundleDescriptionImpl.java:183)
    at org.eclipse.osgi.framework.internal.core.BundleLoader.<init>(BundleLoader.java:146)
    at org.eclipse.osgi.framework.internal.core.BundleLoaderProxy.getBundleLoader(BundleLoaderProxy.java:54)
    at org.eclipse.osgi.framework.internal.core.BundleHost.getBundleLoader(BundleHost.java:591)
    at org.eclipse.osgi.framework.internal.core.BundleHost.checkLoader(BundleHost.java:196)
    at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:223)
    at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1274)
    at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:160)
    ... 15 more
Previous Topic:find duplicate entries for some plugin after update, same plugins then fail
Next Topic:Login plugin
Current Time: Sun Jul 20 17:54:32 EDT 2025
Powered by FUDForum. Page generated in 0.03060 seconds
