Home » Eclipse Projects » Eclipse 4 » Develop reusable Custom Widgets In XWT
Develop reusable Custom Widgets In XWT [message #503761] Tue, 15 December 2009 06:10 Go to next message
Thanks for the answers from Yves YANG in e4 developer mailing list.
For example:
In your example, DecoratedText have property ,text, then the widgets will be used as following:
<Composite xmlns:c="clr-namespace:ext.custom">
<c:DecoratedText text="newWidgets" />
</Composite>
and :
DecoratedText.java
package ext.custom;
public class DecoratedText {
private String text;
// event handling methods
DecoratedText.xwt
<Composite x:Class="ext.custom.DecoratedText">
<Label text={xxxxxx??}/> <!-How to do? Label.text="newWidgets"->
<Text/>
</Composite>
How to get the property text in DecoratedText.xwt and set it into a Label or others.
[Updated on: Tue, 15 December 2009 06:13] by Moderator
Re: Develop reusable Custom Widgets In XWT [message #503823 is a reply to message #503761] Tue, 15 December 2009 12:04 Go to previous messageGo to next message
> or others.
By now, you need to give them a name. and then call
XWT.findElementByName(context, "<name>");
<Label name="myText" text={xxxxxx??}/>
<Text/>
</Composite>
protected void eventHandle(Object sender, Event event) {
Text text = (Text) XWT.findElementByName(event.widget, "myText");
We are considering to provide automatic solution to initialize the class
Field to avoid the manuel research call
Best regards
Yves YANG
"Jinshan" <jinshanl@gmail.com> wrote in message
news:hg8ce9$hmb$1@build.eclipse.org...
> For example:
> </Composite>
> and :
> DecoratedText.java
> package ext.custom;
> DecoratedText.xwt
> <Text/>
> </Composite>
> or others.
> Thanks
Re: Develop reusable Custom Widgets In XWT [message #503836 is a reply to message #503823] Tue, 15 December 2009 18:00 Go to previous messageGo to next message
Here is the bug for this feature:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297586
yves
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hg90to$fq7$1@build.eclipse.org...
>> or others.
> <Text/>
> </Composite>
> Best regards
> Yves YANG
>> For example:
>> </Composite>
>> and :
>> DecoratedText.java
>> package ext.custom;
>> DecoratedText.xwt
>> <Text/>
>> </Composite>
>> or others.
>> Thanks
Re: Develop reusable Custom Widgets In XWT [message #503851 is a reply to message #503836] Tue, 15 December 2009 21:43 Go to previous messageGo to next message
Thanks.
Are there some way to bind DecoratedText.java's properties to DecoratedText.xwt.?
For example:
then
<Label name="myText"/>
<Text/>
</Composite>
"myText" Label is changed automatic and I need not handle "text" changed event. I know the SilverLight is OK.
Yves YANG wrote on Tue, 15 December 2009 18:00
yves
>> or others.
> <Text/>
> </Composite>
> Best regards
> Yves YANG
>> For example:
>> </Composite>
>> and :
>> DecoratedText.java
>> package ext.custom;
>> DecoratedText.xwt
>> <Text/>
>> </Composite>
>> or others.
>> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504071 is a reply to message #503851] Wed, 16 December 2009 10:03 Go to previous messageGo to next message
The simple solution is you create a "String text" property in DecoratedText.
In the setter, you can update the content in your widget text or label.
It should be possible to express in XAML. But we need to add a keyword in
binding expression "self". It is not yet supported in XWT.
The code should be:
<Text text="{Binding source=self,path=text}" />
</Composite>
Best regards
yves
news:hg9hge$rl5$1@build.eclipse.org...
> Thanks.
> DecoratedText.xwt.?
> For example:
> then
> <Text/>
> </Composite>
>> yves
>> >> Label or others.
>> > <Text/>
>> > </Composite>
>> > "myText");
>> > class Field to avoid the manuel research call
>> > Best regards
>> > Yves YANG
>> >> For example:
>> >> </Composite>
>> >> and :
>> >> DecoratedText.java
>> >> package ext.custom;
>> >> DecoratedText.xwt
>> >> <Text/>
>> >> </Composite>
>> >> Label or others.
>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504072 is a reply to message #503836] Wed, 16 December 2009 10:04 Go to previous messageGo to next message
news:hg94ej$hlc$1@build.eclipse.org...
The implemntation is committed. It will be supported in next build.
Re: Develop reusable Custom Widgets In XWT [message #504262 is a reply to message #504071] Thu, 17 December 2009 17:14 Go to previous messageGo to next message
This should work.
name="root">
<Text text="{Binding elementName=root,path=text}" />
</Composite>
yves
news:hgc6jo$s73$1@build.eclipse.org...
> DecoratedText. In the setter, you can update the content in your widget
> text or label.
> The code should be:
> </Composite>
> Best regards
> yves
>> Thanks.
>> DecoratedText.xwt.?
>> For example:
>> then
>> <Text/>
>> </Composite>
>>> yves
>>> >> Label or others.
>>> > <Text/>
>>> > </Composite>
>>> > "myText");
>>> > Best regards
>>> > Yves YANG
>>> >> For example:
>>> >> </Composite>
>>> >> and :
>>> >> DecoratedText.java
>>> >> package ext.custom;
>>> >> DecoratedText.xwt
>>> >> <Text/>
>>> >> </Composite>
>>> >> Label or others.
>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504272 is a reply to message #504262] Thu, 17 December 2009 20:28 Go to previous messageGo to next message
name="root">
</Composite>
I have checked. This solution works.
yves
news:hgeah2$sfm$1@build.eclipse.org...
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504304 is a reply to message #504272] Fri, 18 December 2009 04:00 Go to previous messageGo to next message
My e4 version is eclipse-e4-SDK-incubation-I20091022-2100-win32. but the fellowing does not work:
Widget:
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:allegro.ui.widgets"
xmlns:j="clr-namespace:java.lang" x:Class="allegro.ui.widgets.Image" name="root">
<Composite.layout>
<FillLayout />
</Composite.layout>
<Label name="imageLabel" image="{Binding elementName=root,path=source}" />
</Composite>
Using:
xmlns:c="clr-namespace:allegro.image"
xmlns:a="clr-namespace:allegro.ui.widgets"
x:Class="allegro.image.ImageTest">
<Composite.layout>
<GridLayout numColumns="4" />
</Composite.layout>
<a:Image source="logo.gif"/>
</Composite>
Yves YANG wrote on Thu, 17 December 2009 20:28
name="root">
</Composite>
yves
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504398 is a reply to message #504304] Fri, 18 December 2009 11:58 Go to previous message
The code seems correct. It should work. Please test it with the last build?
Best regards
Yves YANG
news:hgfgbu$sjd$1@build.eclipse.org...
> Widget:
> name="root">
> <Composite.layout>
> <FillLayout />
> </Composite.layout>
> </Composite>
> Using:
> <Composite.layout>
> </Composite.layout>
> </Composite>
>> name="root">
>> </Composite>
>> yves
>> > This should work.
>> > name="root">
>> > </Composite>
>> > yves
>> >> in binding expression "self". It is not yet supported in XWT.
>> >> The code should be:
>> >> </Composite>
>> >> Best regards
>> >> yves
>> >>> Thanks.
>> >>> DecoratedText.xwt.?
>> >>> For example:
>> >>> then
>> >>> <Text/>
>> >>> </Composite>
>> >>>> yves
>> >>>> >> a Label or others.
>> >>>> > <Text/>
>> >>>> > </Composite>
>> >>>> > "myText");
>> >>>> > the class Field to avoid the manuel research call
>> >>>> > Best regards
>> >>>> > Yves YANG
>> >>>> >> list.
>> >>>> >> For example:
>> >>>> >> </Composite>
>> >>>> >> and :
>> >>>> >> DecoratedText.java
>> >>>> >> package ext.custom;
>> >>>> >> DecoratedText.xwt
>> >>>> >> <Text/>
>> >>>> >> </Composite>
>> >>>> >> a Label or others.
>> >>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566128 is a reply to message #503836] Tue, 15 December 2009 21:43 Go to previous message
Thanks.
For example:
then
<Text/>
</Composite>
> yves
> >> or others.
> > <Text/>
> > </Composite>
> > Best regards
> > Yves YANG
> >> For example:
> >> </Composite>
> >> and :
> >> DecoratedText.java
> >> package ext.custom;
> >> DecoratedText.xwt
> >> <Text/>
> >> </Composite>
> >> or others.
> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566190 is a reply to message #566128] Wed, 16 December 2009 10:03 Go to previous message
The code should be:
</Composite>
Best regards
yves
> Thanks.
> DecoratedText.xwt.?
> For example:
> then
> <Text/>
> </Composite>
>> yves
>> >> Label or others.
>> > <Text/>
>> > </Composite>
>> > "myText");
>> > Best regards
>> > Yves YANG
>> >> For example:
>> >> </Composite>
>> >> and :
>> >> DecoratedText.java
>> >> package ext.custom;
>> >> DecoratedText.xwt
>> >> <Text/>
>> >> </Composite>
>> >> Label or others.
>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566209 is a reply to message #503836] Wed, 16 December 2009 10:04 Go to previous message
Re: Develop reusable Custom Widgets In XWT [message #566259 is a reply to message #504071] Thu, 17 December 2009 17:14 Go to previous message
This should work.
name="root">
</Composite>
yves
> text or label.
> The code should be:
> </Composite>
> Best regards
> yves
>> Thanks.
>> DecoratedText.xwt.?
>> For example:
>> then
>> <Text/>
>> </Composite>
>>> yves
>>> >> Label or others.
>>> > <Text/>
>>> > </Composite>
>>> > "myText");
>>> > Best regards
>>> > Yves YANG
>>> >> For example:
>>> >> </Composite>
>>> >> and :
>>> >> DecoratedText.java
>>> >> package ext.custom;
>>> >> DecoratedText.xwt
>>> >> <Text/>
>>> >> </Composite>
>>> >> Label or others.
>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566271 is a reply to message #504262] Thu, 17 December 2009 20:28 Go to previous message
name="root">
</Composite>
yves
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566299 is a reply to message #504272] Fri, 18 December 2009 04:00 Go to previous message
Widget:
<Composite.layout>
<FillLayout />
</Composite.layout>
</Composite>
Using:
<Composite.layout>
</Composite.layout>
</Composite>
> name="root">
> </Composite>
> yves
> > This should work.
> > name="root">
> > </Composite>
> > yves
> >> text or label.
> >> The code should be:
> >> </Composite>
> >> Best regards
> >> yves
> >>> Thanks.
> >>> DecoratedText.xwt.?
> >>> For example:
> >>> then
> >>> <Text/>
> >>> </Composite>
> >>>> yves
> >>>> >> Label or others.
> >>>> > <Text/>
> >>>> > </Composite>
> >>>> > "myText");
> >>>> > Best regards
> >>>> > Yves YANG
> >>>> >> For example:
> >>>> >> </Composite>
> >>>> >> and :
> >>>> >> DecoratedText.java
> >>>> >> package ext.custom;
> >>>> >> DecoratedText.xwt
> >>>> >> <Text/>
> >>>> >> </Composite>
> >>>> >> Label or others.
> >>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566352 is a reply to message #566299] Fri, 18 December 2009 11:58 Go to previous message
Best regards
Yves YANG
> Widget:
> name="root">
> <Composite.layout>
> <FillLayout />
> </Composite.layout>
> </Composite>
> Using:
> <Composite.layout>
> </Composite.layout>
> </Composite>
>> name="root">
>> </Composite>
>> yves
>> > This should work.
>> > name="root">
>> > </Composite>
>> > yves
>> >> The code should be:
>> >> </Composite>
>> >> Best regards
>> >> yves
>> >>> Thanks.
>> >>> DecoratedText.xwt.?
>> >>> For example:
>> >>> then
>> >>> <Text/>
>> >>> </Composite>
>> >>>> yves
>> >>>> >> a Label or others.
>> >>>> > <Text/>
>> >>>> > </Composite>
>> >>>> > "myText");
>> >>>> > Best regards
>> >>>> > Yves YANG
>> >>>> >> list.
>> >>>> >> For example:
>> >>>> >> </Composite>
>> >>>> >> and :
>> >>>> >> DecoratedText.java
>> >>>> >> package ext.custom;
>> >>>> >> DecoratedText.xwt
>> >>>> >> <Text/>
>> >>>> >> </Composite>
>> >>>> >> a Label or others.
>> >>>> >> Thanks
Previous Topic:Application.xmi + Intro / Welcome Page
Next Topic:How to get a part reference with the service registry?
Current Time: Sat Jul 19 08:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.07040 seconds
