Home » Modeling » UML2 » Tag value element looses owner
Tag value element looses owner [message #503741] |
Tue, 15 December 2009 10:13  |
------=_NextPart_000_0543_01CA7DA9.F67A84D0
Content-Type: text/plain;
format=flowed;
charset="windows-1257";
reply-type=original
Suppose I have an element and assign it as a stereotype value:
1) If stereotype property aggregation is None, or Shared everything is ok.
2) If stereotype property aggregation is Composite, the element is removed
from its owner.
I've attached the code sample.
Is it a bug, "feature", or something else?
UML: 2.0.4 (2007/07/13), 3.0.1 (2009/08/28), 3.1.0M4 (2009/12/14)
Martynas
Content-Type: application/octet-stream;
name="TestTag.java"
Content-Transfer-Encoding: quoted-printable
filename="TestTag.java"
package test;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.common.util.WrappedException;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.URIConverter;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.uml.*;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.resource.UMLResource;
import java.io.IOException;
public class TestTag
private static ResourceSet RESOURCE_SET =3D new ResourceSetImpl();
public static void main(String[] args)
String saveLocation =3D ...;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( )
.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
String resourcesJarPath =3D ...;
URI uri =3D URI.createURI("archive:file:/" + resourcesJarPath + "!/");
URIConverter.URI_MAP.put(URI.createURI(UMLResource.LIBRARIES _PATHMAP), =
getUri(uri, "libraries"));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.METAMODEL S_PATHMAP), =
getUri(uri, "metamodels"));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.PROFILES_ PATHMAP), =
getUri(uri, "profiles"));
Profile profile =3D UMLFactory.eINSTANCE.createProfile();
profile.setName("testProfile");
Stereotype stereotype =3D =
profile.createOwnedStereotype("testStereotype", false);
Model uml2Metamodel =3D (Model) =
load(URI.createURI(UMLResource.UML_METAMODEL_URI));
Class classMetaclass =3D (Class) =
uml2Metamodel.getOwnedType(UMLPackage.eINSTANCE.getClass_(). getName());
profile.createMetaclassReference(classMetaclass);
Property compositeAttribute =3D =
stereotype.createOwnedAttribute("testCompositeTag", classMetaclass, 0, =
1);
compositeAttribute.setAggregation(AggregationKind.COMPOSITE_ LITERAL);
Property sharedAttribute =3D =
stereotype.createOwnedAttribute("testSharedTag", classMetaclass, 0, 1);
sharedAttribute.setAggregation(AggregationKind.SHARED_LITERA L);
stereotype.createExtension(classMetaclass, false);
profile.define();
Model model =3D UMLFactory.eINSTANCE.createModel();
model.setName("testModel");
Class stereotypedClass =3D model.createOwnedClass("stereotypedClass", =
false);
Class tagValueComposite =3D =
model.createOwnedClass("tagValueComposite", false);
Class tagValueShared =3D model.createOwnedClass("tagValueShared", =
false);
model.getPackagedElements().add(stereotypedClass);
model.getPackagedElements().add(tagValueComposite);
model.getPackagedElements().add(tagValueShared);
Resource resource =3D createResource(model, =
URI.createFileURI(saveLocation)
..appendSegment("testModel").appendFileExtension(UMLResource.FILE_EXTENSIO=
N));
model.applyProfile(profile);
stereotypedClass.applyStereotype(stereotype);
System.out.println("before tagValueShared.getOwner() =3D " + =
tagValueShared.getOwner());
stereotypedClass.setValue(stereotype, sharedAttribute.getName(), =
tagValueShared);
System.out.println("after tagValueShared.getOwner() =3D " + =
System.out.println("before tagValueComposite.getOwner() =3D " + =
tagValueComposite.getOwner());
stereotypedClass.setValue(stereotype, compositeAttribute.getName(), =
tagValueComposite);
System.out.println("after tagValueComposite.getOwner() =3D " + =
Class sharedValue =3D (Class) stereotypedClass.getValue(stereotype, =
sharedAttribute.getName());
System.out.println("sharedValue =3D " + sharedValue);
Class compositeValue =3D (Class) stereotypedClass.getValue(stereotype, =
compositeAttribute.getName());
System.out.println("compositeValue =3D " + compositeValue);
save(profile, =
URI.createFileURI(saveLocation).appendSegment("testProfile").appendFileEx=
tension(
UMLResource.PROFILE_FILE_EXTENSION));
save(resource);
private static URI getUri(URI base, String what)
return base.appendSegment(what).appendSegment("");
private static Resource createResource(org.eclipse.uml2.uml.Package =
package_, URI uri)
Resource resource =3D RESOURCE_SET.createResource(uri);
resource.getContents().add(package_);
return resource;
private static org.eclipse.uml2.uml.Package load(URI uri)
org.eclipse.uml2.uml.Package package_ =3D null;
try
Resource resource =3D RESOURCE_SET.getResource(uri, true);
package_ =3D (org.eclipse.uml2.uml.Package) =
EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.eINSTANCE.getPackage());
resource.getErrors();
catch (WrappedException we)
we.printStackTrace();
System.exit(1);
return package_;
private static void save(org.eclipse.uml2.uml.Package package_, URI =
uri)
save(createResource(package_, uri));
private static void save(Resource resource)
try
resource.save(null);
catch (IOException ioe)
ioe.printStackTrace();
------=_NextPart_000_0543_01CA7DA9.F67A84D0--
Re: Tag value element looses owner [message #503763 is a reply to message #503741] |
Tue, 15 December 2009 06:14   |
--=-t/s1wj4R7cMzE4v9Iu7/
Hi, Martynas,
Your stereotype is doing exactly what you told it to do. Designating
the stereotype property as a composite aggregation means that the
stereotype owns the objects in that property. So, if you add an element
from your model to that stereotype property, the element becomes owned
by that stereotype instance. Thus it is no longer owned by the model
element that contained it previously.
Probably this particular stereotype property should not be a composite
aggregation.
HTH,
Christian
On Tue, 2009-12-15 at 17:13 +0200, Martynas Lelevicius wrote:
> Hello,
> from its owner.
> Martynas
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Martynas,<BR>
<BR>
Your stereotype is doing exactly what you told it to do. Designating the stereotype property as a composite aggregation means that the stereotype owns the objects in that property. So, if you add an element from your model to that stereotype property, the element becomes owned by that stereotype instance. Thus it is no longer owned by the model element that contained it previously.<BR>
<BR>
Probably this particular stereotype property should not be a composite aggregation.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
from its owner.
Martynas
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-t/s1wj4R7cMzE4v9Iu7/--
Re: Tag value element looses owner [message #628123 is a reply to message #503741] |
Tue, 15 December 2009 10:55  |
Hi, Martynas,
aggregation.
HTH,
Christian
> Hello,
> from its owner.
> Martynas
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Martynas,<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
from its owner.
Martynas
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Current Time: Sat Jul 19 17:41:59 EDT 2025
Powered by FUDForum. Page generated in 0.03765 seconds
