Home » Eclipse Projects » Mylyn » editors order not preserved on task re-activation
editors order not preserved on task re-activation [message #501827] Thu, 03 December 2009 18:20 Go to next message
Hi All,
I've noticed, that when I open some files while a task is active, then
deactivate the task and then activate it again, the files are closed and
then reopened, but with the files' tabs in Eclipse shuffled randomly. I
understand that this might be because of Mylyn's relying on Eclipse's core
functionality on saving and restoring workbench state, however this
understanding doesn't make this bug less annoying :(
I guess this is a known bug; if so, could anyone please point it for me in
Bugzilla so that I could vote for it?
I know nothing about Mylyn's internal structure and very little about
Eclipse's. Still, as an idea, Mylyn could store the tabs order and somehow
reorder tabs to ensure the correct ordering on task activation.
Another solution could be on task activation to make mylyn imitate opening
the files one by one with a tiny pause after each one, so that the tabs
will naturally be in the correct order, from left to right, just as I need.
As both these solution have obvious side-effects, they could be made
disablable by a checkbox in the preferences... Isn't this all realistic?
At least sounds quite possible for me.
Alexey
Re: editors order not preserved on task re-activation [message #501845 is a reply to message #501827] Thu, 03 December 2009 22:27 Go to previous messageGo to next message
I am not aware that this has been reported before. What is the behaviour
when you restart Eclipse without having a task active? Are all tabs
restored in the same order they were in at shutdown time?
Steffen
Alexey Semenov wrote:
> Hi All,
> need.
> Alexey
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: editors order not preserved on task re-activation [message #503697 is a reply to message #501845] Tue, 15 December 2009 06:42 Go to previous messageGo to next message
Hi Steffen,
It's been a while since you replied. Sorry for the delay, I was working on
a computer with no news client set up.
I've just checked your suggestion with 4 tabs open: a java class, a text
document, an xml document and an another java class. I shutdown then
restart and File -> Restart restored the 4 tabs in exactly the same order.
Now I strongly believe that the order of the tabs should be preserved when
deactivating/activating a task.
Please tell if you need more info.
Alexey
On Fri, 04 Dec 2009 03:27:29 -0000, Steffen Pingel
> Steffen
>> Hi All,
>> core
>> in
>> somehow
>> opening
>> need.
>> Thanks,
>> Alexey
Re: editors order not preserved on task re-activation [message #504409 is a reply to message #503697] Fri, 18 December 2009 13:12 Go to previous message
I too have noticed this, and was trying to post a topic about it (but it wouldn't post for some reason, I kept getting redirected to the main Eclipse forum page when I'd hit Create Topic).
Anyway, +1 for this request. I've long noticed the symptoms as described, and I'd love it if the tab order were preserved between sessions.
Re: editors order not preserved on task re-activation [message #600141 is a reply to message #501827] Thu, 03 December 2009 22:27 Go to previous message
Steffen
> Hi All,
> need.
> Alexey
Steffen Pingel
Re: editors order not preserved on task re-activation [message #600184 is a reply to message #501845] Tue, 15 December 2009 06:42 Go to previous message
Hi Steffen,
Alexey
> Steffen
>> Hi All,
>> core
>> in
>> somehow
>> opening
>> need.
>> Thanks,
>> Alexey
Re: editors order not preserved on task re-activation [message #600257 is a reply to message #503697] Fri, 18 December 2009 13:12 Go to previous message
Previous Topic:Sort by due date?
Next Topic:Binary not part of task context
Current Time: Sun Jul 20 18:19:27 EDT 2025
Powered by FUDForum. Page generated in 0.04693 seconds
