Home » Eclipse Projects » Eclipse Platform » Creating a Custom Eclipse Compare Editor
Creating a Custom Eclipse Compare Editor [message #503650] Mon, 14 December 2009 22:51
Hi everyone,
I´m currently working on a eclipse plugin, that should compare two different files with each other, similiar to "compare with" in eclipse.
The initial point is a file, that consits out of script and java code. It should be possible to code script code on the left hand side with the support of a custom made script editor and code java with the support of the eclipse java editor on the right hand side. Both, java and source code should be saved in the same file.
Is it possible to display a custom made text editor and on the right hand side the java editor? Are there any tutorials available?
Best regards
StefanK
Previous Topic:CVS Console not showing any output
Next Topic:Timingproblem with IResourceChangeListener
Current Time: Sat Jul 19 11:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.08222 seconds
