Home » Modeling » M2T (model-to-text transformation) » [Xtend] XtendComponent vs. XtendFacade
[Xtend] XtendComponent vs. XtendFacade [message #503205] Fri, 11 December 2009 06:52 Go to next message
Hi all,
i am using Xtend to execute in-place model transformations on GMF
diagram elements from Java code.
However, it seems like there is more than one way to execute Xtend from
Java.
1. Using an XtendComponent and the invoke method
2. Using an XtendFacade and the call method
Right now i'm using the XtendComponent and its working really fine, but
i wonder if there is any real difference between the two and a
recommended way of calling xtend?
The only thing i found so far, is that the XtendComponent can be used to
execute extension which are located somewhere in the file system by
using a "usual" path (like
/home/user/eclipse-runtime/.metadata/...../extension), which is not
possible when using the XtendFacades '::' paths. (?)
Maybe the XtendComponent is a bit more complicated, because i have to
use a workflow context to set the model elements as the extension
parameters where the facade allows the use of Object[].
Michael
Re: [Xtend] XtendComponent vs. XtendFacade [message #503338 is a reply to message #503205] Fri, 11 December 2009 18:33 Go to previous messageGo to next message
you may find some hints on this topic in the xtend documentation http:// help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.xpand. doc/help/ch01s05.html
  • The XtendComponent is meant to be used to call Xtend from an MWE Workflow file
  • The XtendFacade is meant to be called from java directly.
i hope is answers your question
Re: [Xtend] XtendComponent vs. XtendFacade [message #503411 is a reply to message #503338] Sun, 13 December 2009 07:51 Go to previous messageGo to next message
thanks for your answer, so i should rather use the XtendFacade.
But is it possible to call an extension that is not included in the
class path?
My .ext files are either contained in a plug-in or somewhere in the
plug-in state location (.metadata/..../).
> Hello,
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .xpand.doc/help/ch01s05.html
> Workflow file
Re: [Xtend] XtendComponent vs. XtendFacade [message #503597 is a reply to message #503411] Mon, 14 December 2009 16:09 Go to previous messageGo to next message
hi
if the plugin is in the workspace you could try something like this
XtendFacade f = XtendFacade.create("../test-project/META-INF/test/test");
Re: [Xtend] XtendComponent vs. XtendFacade [message #503669 is a reply to message #503597] Tue, 15 December 2009 04:19 Go to previous messageGo to next message
the plug-in is only a .jar file, so i can't directly access the folder.
(I could use the Plugin.find or Plugin.openStream, but i think the
XtendFacade can only be used with fully qualified names and no paths or
urls).
I need to access the .metadata folder, not the meta-inf folder, because
i need to serialize an xtend file "somewhere" and execute it and i can't
say if the project even has a meta-inf folder.
So i decided to use the Plugin.StateLocation folder, because it always
exists (or will be created)
> hi
Re: [Xtend] XtendComponent vs. XtendFacade [message #503682 is a reply to message #503669] Tue, 15 December 2009 00:30 Go to previous messageGo to next message
hi,
the same a with my relative path should work with absolute paths. so if you can find out file file uri of the state dir and concat it with the relative path of the extension file it should work.
Re: [Xtend] XtendComponent vs. XtendFacade [message #503753 is a reply to message #503682] Tue, 15 December 2009 05:56 Go to previous message
Ahhh my fault, i tried to use the hasExtension(...) method before
registering my metamodel.
And because the facade loads extension files by using them as "imported
extensions" the facade itself had no extensions and i assumed that the
file could not be loaded :)
Thanks for your help
> hi,
Previous Topic:migrating from oaw: Workflow problems
Next Topic:[Acceleo] line feeds in templates
Current Time: Sun Jul 20 02:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
