Home » Modeling » EMF » Modifying properties view (combo box value)
Modifying properties view (combo box value) [message #503466] Mon, 14 December 2009 06:11 Go to next message
I want to modify the behaviour of the properties view.
When you make double click in a property value which is a combo box, the view shows all the available values. If the property is
a reference, combo box shows all objects which can be targeted for those elements.
Maybe the project was: "org.eclipse.emf.edit.ui", and teh class "AdapterFactoryContentProvider"... but I'm not sure...
Please, what class and what EMF project do I have to modify for getting the combo box only load the values I want (basically a filter on the default combo values)?
Have you got any suggestion about this issue?
Thanks in advance.
Best regards.
Re: Modifying properties view (combo box value) [message #503474 is a reply to message #503466] Mon, 14 December 2009 01:42 Go to previous messageGo to next message
--------------040200030908080407010903
Carlos,
There's an example in EReferenceItemProvider.
protected void addEOppositePropertyDescriptor(Object object)
itemPropertyDescriptors.add
(new ItemPropertyDescriptor
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
getResourceLocator(),
getString("_UI_EReference_eOpposite_feature"),
getString("_UI_EReference_eOpposite_description"),
EcorePackage.Literals.EREFERENCE__EOPPOSITE,
true,
false,
true,
null,
null,
null)
public Collection<?> *getChoiceOfValues*(Object object)
I.e., specialize getChoiceOfValues of the property descriptor.
Carlos wrote:
> Hello,
> the view shows all the available values. If the property is a
> elements.
> Thanks in advance.
> Best regards.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Carlos,<br>
<br>
There's an example in EReferenceItemProvider.<br>
<br>
<small>  protected void addEOppositePropertyDescriptor(Object object)<br>
  {<br>
    itemPropertyDescriptors.add<br>
      (new ItemPropertyDescriptor<br>
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(), <br>
         getResourceLocator(),<br>
         getString("_UI_EReference_eOpposite_feature"),<br>
         getString("_UI_EReference_eOpposite_description"),<br>
         EcorePackage.Literals.EREFERENCE__EOPPOSITE,<br>
         true,<br>
         false,<br>
         true,<br>
         null,<br>
         null,<br>
         null)<br>
        {<br>
          @Override<br>
          public Collection&lt;?&gt; <b>getChoiceOfValues</b>(Object
object)<br>
          {</small><br>
<br>
I.e., specialize getChoiceOfValues of the property descriptor.<br>
<br>
<br>
Carlos wrote:
<blockquote cite="mid:hg56h6$3a9$1@build.eclipse.org" type="cite">Hello,
<br>
<br>
<br>
elements.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks in advance.
<br>
Best regards.
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------040200030908080407010903--
Re: Modifying properties view (combo box value) [message #503520 is a reply to message #503474] Mon, 14 December 2009 10:17 Go to previous message
Hi Ed.
I have imported the project "org.eclipse.emf.ecore.edit" and I also have modified the class "EReferenceItemProvider" as you told me but it seems that the method has never invoked.
After I make the changes in the class code, the file is not marked like 'dirty' but I don't know why... (The file name is blue in the package navigator: what does it mean? Can that project be modified?).
I have explored other way. In the project "org.eclipse.emf.edit", in the class "ItemPropertyDescriptor" there is other method "getChoiceOfValues". I think that I can filter the combo box values at this point...
What is your opinion?
Thank you very much.
Best regards.
Carlos.
Previous Topic:EMF Validation, RollBack on error
Next Topic:[CDO] Using 3.0
Current Time: Sun Jul 20 03:28:36 EDT 2025
Powered by FUDForum. Page generated in 0.05282 seconds
