Home » Archived » Buckminster » headless eclemma - howto install and use
headless eclemma - howto install and use [message #503275] Fri, 11 December 2009 11:31 Go to next message
I've seen here ( http://www.eclipse.org/forums/index.php?t=msg&th=155486& amp;start=0&S=4f42b6336f201e4251a1d72b559aaa03) and here (https://bugs.eclipse.org/bugs/show_bug.cgi?id=288455), that a solution is available from a cloudsmith site until legal issues are resolved...
however I cannot find said site.
Can someone give me a pointer, please.
Thanks in advance.
Cheers.
Joerg
Re: headless eclemma - howto install and use [message #503289 is a reply to message #503275] Fri, 11 December 2009 11:59 Go to previous messageGo to next message
Hi Joerg,
The legal issue is resolved so the thread in question is no longer relevant. The emma headless feature is include on our
regular 3.6 headless site. http://download.eclipse.org/tools/buckminster/headless-3.6
Thomas Hallgren
On 2009-12-11 17:32, Joerg Buchberger wrote:
> I've seen here
> resolved...
> Thanks in advance.
> Cheers.
> Joerg
Re: headless eclemma - howto install and use [message #504347 is a reply to message #503289] Fri, 18 December 2009 07:59 Go to previous messageGo to next message
Hi Thomas.
Thanks. Got it setup in a clean installation. Did not manage to update existing installation, though.
Cannot get
emma --merge
to work yet.
If you know of any scriptfile examples in some repository, including emma merge command calls, I'd be grateful for the pointer.
Joerg
Thomas Hallgren wrote on Fri, 11 December 2009 11:59
Hi Joerg,
Thomas Hallgren
> I've seen here
> ( http://www.eclipse.org/forums/index.php?t=msg&th=155486& amp; amp;start=0&S=4f42b6336f201e4251a1d72b559aaa03)
> resolved...
> Thanks in advance.
> Cheers.
> Joerg
Re: headless eclemma - howto install and use [message #504802 is a reply to message #504347] Tue, 22 December 2009 13:19 Go to previous messageGo to next message
Hi Joerg,
Here is how I use the --merge (aka -m) flag with emma in my buildscript:
emma -l test.engine.all/engine.all.launch -o ${out.dir}/TEST-engine.all.xml
emma -m -l test.engine.all/engine.all.plugin.launch -o ${out.dir}/TEST-
engine.all.plugin.xml --html ${out.dir}/coverage/coverage.html --xml
${out.dir}/coverage/coverage.xml
Note that you can only merge coverage results when running consecutive emma
launches in one and the same build script. Note also that you must use the
"-m" flag for every emma launch after the first one in order to merge the
results of all coverage sessions.
HTH,
Achim
> Hi Thomas.
> Cannot get emma --merge to work yet.
> Cheers,
> Joerg
>> Hi Joerg,
>> relevant. The emma headless feature is include on our regular 3.6
>> Regards,
>> Thomas Hallgren
>> > Hi,
>> > I've seen here
>> > Thanks in advance.
>> > Cheers.
>> > Joerg
Re: headless eclemma - howto install and use [message #1748608 is a reply to message #504802] Fri, 25 November 2016 03:50 Go to previous message
I am getting --exec command as invalid.
Can anyone share me what i need to do for resolving the issue
Previous Topic:Buckminster download for Eclipse Neon (4.6.x)?
Next Topic:Could not acquire the framework manipulator service
Current Time: Sun Jul 20 07:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.05935 seconds
