Home » Eclipse Projects » Eclipse 4 » Somthing is missing in the "New and Noteworthy".
Somthing is missing in the "New and Noteworthy". [message #503132] Thu, 10 December 2009 16:46 Go to next message
--------------070805090602010206080303
http://www.eclipse.org/e4/development/readme/readme_e4_0.9.h tml
In the section "
4.2.3 SWT Flex examples"
*Setup the Flex tools:
*Update your eclipse.ini file and add another line at the end,
-Dflex.sdk=* * Note: Make sure you don't edit the command line (for
example in a launch shortcut) as it overrides the .ini file and loses
the Flex settings.
-Dflex.sdk=
seems something is missing here. I found out that in the wiki page
"http://wiki.eclipse.org/E4/SWT/Running_the_demos", it is like:
-Dflex.sdk=<your path to the installed sdk>
*/Dollyn/*
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=UTF-8">
</head>
<a class="moz-txt-link-freetext" href=" http://www.eclipse.org/e4/development/readme/readme_e4_0.9.h tml"> http://www.eclipse.org/e4/development/readme/readme_e4_0.9.h tml</a><br>
<br>
In the section "
<h3>4.2.3 <a name="R-Demos-Flex">SWT Flex examples</a>"</h3>
<p><b>Setup the Flex tools:<br>
</b>Update your eclipse.ini file and add another line at the end,
-Dflex.sdk=<your path="" to="" the="" installed="" sdk=""><b> </b>
Note: Make sure you don't edit the command line (for example in a
launch shortcut) as it overrides the .ini file and loses the Flex
settings.</your><br>
</p>
<br>
-Dflex.sdk=<br>
<a class="moz-txt-link-rfc2396E" href="http://wiki.eclipse.org/E4/SWT/Running_the_demos">"http://wiki.eclipse.org/E4/SWT/Running_the_demos"</a>, it is like:<br>
-Dflex.sdk=&lt;your path to the installed sdk&gt;<br>
<br>
<div class="moz-signature">-- <br>
<meta http-equiv="Content-Language" content="zh-cn">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>Dollyn</title>
<p><b><i><font color="#0000ff" face="Courier New">Dollyn</font></i></b></p>
</div>
</body>
</html>
--------------070805090602010206080303--
Sorry, it's "Eclipse e4 0.9 Readme",not "New and Noteworthy" [message #503144 is a reply to message #503132] Fri, 11 December 2009 01:42 Go to previous message
--------------060008090705070402020505
> In the section "
> the Flex settings.
> -Dflex.sdk=
> */Dollyn/*
*/Dollyn/*
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<br>
<br>
<blockquote cite="mid:hfsbfq$11c$1@build.eclipse.org" type="cite">
<a moz-do-not-send="true" class="moz-txt-link-freetext"
<br>
In the section "
<h3>4.2.3 <a moz-do-not-send="true" name="R-Demos-Flex">SWT Flex
examples</a>"</h3>
</p>
<br>
-Dflex.sdk=<br>
<a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
it is like:<br>
<br>
</div>
</blockquote>
<br>
</div>
</body>
</html>
--------------060008090705070402020505--
Previous Topic:XWT + TableViewer + Handler + open vs load Behaviour
Next Topic:Somthing is missing in the "New and Noteworthy".
Current Time: Sat Jul 19 10:28:48 EDT 2025
Powered by FUDForum. Page generated in 0.04472 seconds
