Home » Eclipse Projects » Remote Application Platform (RAP) » Access Widgets via Javascript on client side
Access Widgets via Javascript on client side [message #502726] Wed, 09 December 2009 09:52 Go to next message
I try to access the Widgets on clientside via Javascript. I use the Widgetmanager by:
var wm = org.eclipse.swt.WidgetManager.getInstance();
var widget = wm.findWidgetById();
My problem is, that I do not know the IDs of the widgets. Is there any possibility to set the widget IDs? Or any possibility to access the widget by name ore something else?
And: Is there any javascript side documentation (API, Tutorials, ...) for RAP?
Thx,
Oliver
Re: Access Widgets via Javascript on client side [message #502735 is a reply to message #502726] Wed, 09 December 2009 10:03 Go to previous messageGo to next message
Hi Oliver,
you can set the widget-Id in you code:
widget.setData(WidgetUtil.CUSTOM_WIDGET_ID, "MyWidgetId");
Hope that helps,
Stefan.
Oliver Specht schrieb:
> Widgetmanager by:
> for RAP?
> Thx,
> Oliver
Re: Access Widgets via Javascript on client side [message #502739 is a reply to message #502726] Wed, 09 December 2009 10:17 Go to previous messageGo to next message
Hi Oliver,
the widget id, used by WidgetManager#findWidgetById( id ) is assigned by
server side on widget creation ( see WidgetManager#newWidget ). You can
get the id:
- on the client: WidgetManager#findIdByWidget( widget )
- on the server: WidgetUtil.getId( widget )
HTH,
Ivan
On 12/9/2009 16:52, Oliver Specht wrote:
> Widgetmanager by:
> for RAP?
> Thx,
> Oliver
Re: Access Widgets via Javascript on client side [message #502787 is a reply to message #502726] Wed, 09 December 2009 12:08 Go to previous messageGo to next message
Hi, all,
thanks for the replies. It seems that the ID is set but does not affect the javascript part.
If I set the ID via WidgetUtil.CUSTOM_WIDGET_ID and debug it on button click, the ID is shown correctly.
If I try to access the element via javascript, it only works by accessing by ID "w175" or "w34" etc.
Does RAP ignore the widget settings?
Greetings,
Oliver
Re: Access Widgets via Javascript on client side [message #502804 is a reply to message #502787] Wed, 09 December 2009 13:27 Go to previous messageGo to next message
Hi Oliver,
sorry, I forgot to mention that you have to set the System-Property
org.eclipse.rwt.enableUITests, too. See this page for more information:
http://www.eclipse.org/rap/noteworthy/news_11.php
Stefan.
> Hi, all,
> Greetings,
> Oliver
Re: Access Widgets via Javascript on client side [message #503030 is a reply to message #502804] Thu, 10 December 2009 11:06 Go to previous message
Hi, Stefan,
works fine, thank you.
Now I have another problem (really tried but did not find out...):
I want to change a Button on client side so it gets new properties that I can query on server side.
In my case I have a button which I trigger via execute(). Before triggering I want to give it a property (key-value pair) I can then query on server side.
Which way do I go? I saw the setUserData() methods, the setProperty...() methods etc. There are so many different possibitlities but nothing worked.
Can you help me out again? Smile
Thank you,
Oliver
Previous Topic:D&D in TreeWiewer
Next Topic:Processing KeyAdapter in RAP
Current Time: Sat Jul 19 14:20:42 EDT 2025
Powered by FUDForum. Page generated in 0.04716 seconds
