Home » Eclipse Projects » Standard Widget Toolkit (SWT) » set Column width to show complete text
set Column width to show complete text [message #502498] Tue, 08 December 2009 09:38 Go to next message
hello everyone,
I have a table with only one column, every cell contains very long text. I set the column width big enough (e.g. 10000), and the table is also scrollable, but the text was still not completely displayed.
maybe could someone help me to solve this problem
kind regard
kai
Re: set Column width to show complete text [message #502756 is a reply to message #502498] Wed, 09 December 2009 10:51 Go to previous messageGo to next message
kai guo wrote:
> hello everyone,
You cannot use native widgets (SWT) for this, because of platform
limitations. You probably hit
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259013
HTH & Greetings from Bremen,
Daniel Krügler
Re: set Column width to show complete text [message #502773 is a reply to message #502756] Wed, 09 December 2009 11:40 Go to previous messageGo to next message
thanks for your replay.
I replace this table with list, maybe there is a way to set the background of every list element?
kind regard kai
Re: set Column width to show complete text [message #502876 is a reply to message #502773] Thu, 10 December 2009 02:41 Go to previous messageGo to next message
Are you sure that the list does not show the same kind of restrictions
as the table?
Problem is, that list does not support as much features as table, e.g.
I'm pretty sure that you have much more limitations in regard to
customized drawing options.
E.g. with a jface TableViewer with the jface 3.3 API using owner-drawing
label provider you can do this:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet049StyledCellLabelProvider.java?view=markup
I doubt that this is possible with list.
Daniel Krügler
Re: set Column width to show complete text [message #503059 is a reply to message #502498] Thu, 10 December 2009 12:41 Go to previous message
Hi Kai,
After setting your item texts you should pack() the column, which will make
it the minimum width that's required to fit the texts. The platform
limitation is reached if your column width wants to exceed 32767, but if you
think that 10000 pixels is wide enough then this should not be the issue.
Are you able to provide a snippet that shows the problem? There are many
example Table snippets at http://www.eclipse.org/swt/snippets#table that you
could use as a starting point.
Grant
"kai guo" <kai.guo@afra.de> wrote in message
news:hflod3$bs2$1@build.eclipse.org...
> hello everyone,
> kind regard
> kai
Previous Topic:empty link displayed in 2 lines on Windows
Next Topic:Cocoa, SWT.Password and listeners
Current Time: Sat Jul 19 12:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.28465 seconds
