Home » Modeling » EMF » [Teneo] updates E_Version column
[Teneo] updates E_Version column [message #501551] Wed, 02 December 2009 13:44 Go to next message
Originally posted by: jandev.gmx.ch
Hi all
When we commit a hibernate transaction, we see hibernate searches for dirty model objects (TypeFactory.findDirty).
Our EMF models, which are contained by another model (containment=true), have a property named "e_container_featurename".
Hibernate is comparing all properties of the cached object vs. the object from the session.
To find out if the property "e_container_featurename" (EContainerFeatureIDHolder.class) has been changed, hibernate uses Teneo's EContainerFeatureIDUserType.equals. The
EContainerFeatureIDUserType.equals does some null checks first and then calls "x.equals(y)" which is Object.equals as EContainerFeatureIDHolder does not implement it.
Unfortunately, the the two EContainerFeatureIDHolder of both objects compared are different objects but having the same values (EClass, EStructuralFeature).
Even if we haven't change any properties, our model gets dirty. This results in an unnecessary update on the table, increasing the E_VERSION and causing a concurrent modification in certain
circumstances.
1) Is it correct to have the property "e_container_featurename" on the models (containment) and in database tables?
2) Is this a bug? We believe that this issue can be fixed, when equals is implemented in EContainerFeatureIDHolder.
We use hibernate 3.2.6-GA, teneo 1.1.0 and EMF 2.5.
Best regards
Jan Dev
Re: [Teneo] updates E_Version column [message #501554 is a reply to message #501551] Wed, 02 December 2009 13:58 Go to previous messageGo to next message
Hi Jan,
Yes this seems to be a bug for sure. Can you enter a bugzilla for this?
The e_container_featurename is needed if you want to use the eContainer member of an EObject. EMF makes use of it in
much of its code, so if you use core EMF (for example in a RCP) then you need this probably. You can disable mapping of
the econtainer using the option:
PersistenceOptions.DISABLE_ECONTAINER_MAPPING
set it to true.
If you disable container mapping then the econtainer of an eobject will only be set if you first read a parent and then
access the children through the parent. If the children are read individually from the database then there econtainer
won't be set.
gr. Martin
Jan Dev wrote:
> Hi all
> and causing a concurrent modification in certain circumstances.
> Best regards
> Jan Dev
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] updates E_Version column [message #501726 is a reply to message #501554] Thu, 03 December 2009 10:36 Go to previous messageGo to next message
Hi Martin
Thanks for the very quick response!
I have filed the bug [296816] and added a patch to fix the issue.
I just implemented equals and hashcode of EContainerFeatureIDHolder and this seems to work.
What workaround do you suggest until this fix has been integrated and release is available?
I can think of:
a) Write my own UserType, which is just a copy of the fixed one and register it instead of the original one.
Can you give me a hint or direction how I can make sure, my new UserType is used instead of the original?
b) Set the PersistenceOptions.DISABLE_ECONTAINER_MAPPING=true
Jan
[296816]: https://bugs.eclipse.org/bugs/show_bug.cgi?id=296816
Martin Taal wrote:
> Hi Jan,
> member of an EObject. EMF makes use of it in much of its code, so if you
> disable mapping of the econtainer using the option:
> set it to true.
> only be set if you first read a parent and then access the children
> database then there econtainer won't be set.
> gr. Martin
> Jan Dev wrote:
>> Hi all
>> E_VERSION and causing a concurrent modification in certain circumstances.
>> Best regards
>> Jan Dev
Re: [Teneo] updates E_Version column [message #501749 is a reply to message #501726] Thu, 03 December 2009 11:32 Go to previous messageGo to next message
Hi Jan,
Thanks, seen it!
I was planning to do a new build anyway the coming days (before monday then). And this change seems fairly small, so I
can incorporate it easily.
Disabling the econtainer persistence will mean that these columns are not updated anymore, so if you enable this later I
think you might get into trouble with your database.
Currently it is a bit hard/impossible to override this with your own implementation I am afraid.
gr. Martin
Jan Dev wrote:
> Hi Martin
> this seems to work.
> I can think of:
> Regards
> Jan
> Martin Taal wrote:
>> Hi Jan,
>> eContainer member of an EObject. EMF makes use of it in much of its
>> probably. You can disable mapping of the econtainer using the option:
>> set it to true.
>> will only be set if you first read a parent and then access the
>> from the database then there econtainer won't be set.
>> gr. Martin
>> Jan Dev wrote:
>>> Hi all
>>> circumstances.
>>> Best regards
>>> Jan Dev
The Netherlands
Re: [Teneo] updates E_Version column [message #501976 is a reply to message #501749] Fri, 04 December 2009 10:59 Go to previous messageGo to next message
Martin
I've seen that you've added the path for teneo 1.2 (bugzilla).
Will you add the patch on the 1.1x branch as well? (We're using EMF 2.5 and Eclipse 3.5)
Jan
Martin Taal wrote:
> Hi Jan,
> Thanks, seen it!
> then). And this change seems fairly small, so I can incorporate it easily.
> not updated anymore, so if you enable this later I think you might get
> gr. Martin
> Jan Dev wrote:
>> Hi Martin
>> I can think of:
>> Regards
>> Jan
>> Martin Taal wrote:
>>> Hi Jan,
>>> this probably. You can disable mapping of the econtainer using the
>>> option:
>>> set it to true.
>>> gr. Martin
>>> Jan Dev wrote:
>>>> Hi all
>>>> circumstances.
>>>> Best regards
>>>> Jan Dev
Re: [Teneo] updates E_Version column [message #501980 is a reply to message #501976] Fri, 04 December 2009 11:10 Go to previous messageGo to next message
Hi Jan,
Yes my typo. I just now did a 1.1.2 build with the fix and am publishing it right now. Although it seems that something
went wrong in the publish step (some low-level file system permission). In the meantime you can download it directly
here also:
http://modeling.eclipse.org/modeling/emf/downloads/?project= teneo&sortBy=date&hlbuild=0#latest
(take the last 1.1.2 build).
gr. Martin
Jan Dev wrote:
> Martin
> and Eclipse 3.5)
> Regards
> Jan
> Martin Taal wrote:
>> Hi Jan,
>> Thanks, seen it!
>> easily.
>> gr. Martin
>> Jan Dev wrote:
>>> Hi Martin
>>> I can think of:
>>> Regards
>>> Jan
>>> Martin Taal wrote:
>>>> Hi Jan,
>>>> option:
>>>> set it to true.
>>>> gr. Martin
>>>> Jan Dev wrote:
>>>>> Hi all
>>>>> circumstances.
>>>>> Best regards
>>>>> Jan Dev
The Netherlands
Re: [Teneo] updates E_Version column [message #502646 is a reply to message #501980] Wed, 09 December 2009 04:32 Go to previous message
Hi Martin
I've tested the latest teneo 1.1.2 build (M200912041048 (2009/12/04)) and I confirm that bug [296816] has been fixed.
Many thanks and best regards
Jan
Martin Taal wrote:
> Hi Jan,
> it right now. Although it seems that something went wrong in the publish
> download it directly here also:
> gr. Martin
> Jan Dev wrote:
>> Martin
>> Regards
>> Jan
>> Martin Taal wrote:
>>> Hi Jan,
>>> Thanks, seen it!
>>> monday then). And this change seems fairly small, so I can
>>> gr. Martin
>>> Jan Dev wrote:
>>>> Hi Martin
>>>> I can think of:
>>>> Regards
>>>> Jan
>>>> Martin Taal wrote:
>>>>> Hi Jan,
>>>>> this?
>>>>> option:
>>>>> set it to true.
>>>>> gr. Martin
>>>>> Jan Dev wrote:
>>>>>> Hi all
>>>>>> circumstances.
>>>>>> Best regards
>>>>>> Jan Dev
Previous Topic:Ecore and ecore_diagram
Next Topic:Accessing EMF model through java
Current Time: Sun Jul 20 15:06:34 EDT 2025
Powered by FUDForum. Page generated in 0.04525 seconds
