Home » Modeling » EMF » OneToMany from an embeddable object
OneToMany from an embeddable object [message #501863] Fri, 04 December 2009 02:33 Go to next message
I originally had the following scenario - which was working fine. Object A had a one-to-many relationship with Object B which in turn had a one-to-many relationship with Object C. The relationship between A and B was then changed to a one-to-one. The DB table for B was removed and its columns were moved to the DB table for A.
So I modified the mapping for B to be Embeddable and defined its fields in the mapping for A.
So now I have Object A with a one-to-one relationship to an Embedded Object B, which still needs to have a one-to-many relationship to Object C. This fails with the following error:
"An association from the table xxx refers to an unmapped class: yyy"
I removed Object C from the mapping, then A and B worked fine. As another test, I moved the one-to-many relationship from B to C from the mapping for B into the mapping for A (thus making A have a one-to-many relationship to C), it works fine.
Question: Is it possible to have a one-to-many relation from an Embeddable object?
Thanks for your help.
Re: OneToMany from an embeddable object [message #501897 is a reply to message #501863] Fri, 04 December 2009 06:02 Go to previous messageGo to next message
Ed,
If this is a Teneo question, would it sounds like, please in the future
prefix the subject line with [teneo] so that Martin is sure to notice it.
> Object C. This fails with the following error: "An association from
> Embeddable object?
Re: OneToMany from an embeddable object [message #501944 is a reply to message #501897] Fri, 04 December 2009 09:50 Go to previous messageGo to next message
Hi Ed,
The testcases did not yet cover this case (a one-to-many in a component). So I adapted the embedded testcase to also
include one to many. I noticed several issues which I solved along the way to get my test cases to pass (the fix will be
in the next build for Teneo 1.2 within a few days).
Only the problem is...
That the issues I solved do not seem to be related to the error you are getting, it seems a completely other one.
So assuming that you are on the 1.2 version I think it is best to see if the latest build helps or shows the same error.
Btw, one thing that won't work (not supported by hibernate it seems) is a one-to-many in a component-element, so a
one-to-many in a embedded component of a one to many. For example this is not possible: A has a one-to-many to B and B
is embedded in the join table and B has a one-to-many to a C. This case however can also be mapped as a non-embedded
case (it would result in the same relational schema afaics).
gr. Martin
Ed Merks wrote:
> Ed,
>> Embeddable object? Thanks for your help.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: OneToMany from an embeddable object [message #501982 is a reply to message #501944] Fri, 04 December 2009 11:13 Go to previous message
Hi Ed,
It took less time than a few days...
The latest build (1.1.2 version) I published a minute back supports one-to-many for embedded components. Although again
I am not sure if it solves your issue which seems a bit different.
gr. Martin
Martin Taal wrote:
> Hi Ed,
> component). So I adapted the embedded testcase to also include one to
> test cases to pass (the fix will be in the next build for Teneo 1.2
> within a few days).
> a one-to-many in a component-element, so a one-to-many in a embedded
> one-to-many to B and B is embedded in the join table and B has a
> non-embedded case (it would result in the same relational schema afaics).
> gr. Martin
> Ed Merks wrote:
>> Ed,
>> future prefix the subject line with [teneo] so that Martin is sure to
>> notice it.
The Netherlands
Previous Topic:Editor ViewerPane with tool button
Next Topic:new EMF tutorial
Current Time: Sun Jul 20 16:56:53 EDT 2025
Powered by FUDForum. Page generated in 0.04105 seconds
