Home » Eclipse Projects » SWTBot » findControls()(Find tree in the view)
findControls() [message #501315] Tue, 01 December 2009 15:18 Go to next message
I'm new to SWTBot. I cannot find ClassMatcher in SWTBot 2.0. Someone mentioned that the ClassMatcher is now replaced by the api widgetOfType(class). But, I don't find this either. I find the findControls() method takes in parameter Matcher<T> matcher. But I'm not sure
how to use it fo find the tree in my selected view.
I want to find the controls in the selected view.
I'm trying to use it the following way:
SWTBotView view = bot.activeView();
List controls = new ChildrenControlFinder(view.getWidget()).findControls(Matcher <Tree> (Tree.class));//which I know is wrong
Can someone please correct me ?
Thanks.
Re: findControls() [message #501326 is a reply to message #501315] Tue, 01 December 2009 16:00 Go to previous messageGo to next message
Seema wrote:
widgetOfType(Class) is a static method found in WidgetMatcherFactory. To
easily find the other methods in this class (and others), you can
activate a simple preferences:
Window > Preferences > SWTBot Preferences and check the single check box.
> List controls = new
The bot() method in SWTBotView is what you want. It returns a SWTBot
that search inside the view for widgets.
you can do this instead:
bot.activeView().bot().tree();
or, if you want them all in the view:
bot.activeView().bot().widget(widgetOfType(Tree.class));
with this addition in your imports:
import static
org.eclipse.swtbot.swt.finder.matchers.WidgetMatcherFactory. widgetOfType;
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: findControls() [message #501458 is a reply to message #501326] Wed, 02 December 2009 07:56 Go to previous message
Thanks for the reply and help !!
Previous Topic:Keyboard layout not available when using typeText
Next Topic:Help in SWTBot
Current Time: Sat Jul 19 16:13:37 EDT 2025
Powered by FUDForum. Page generated in 0.16454 seconds
