Home » Archived » ATF » atf 0.3.0 installation woes
atf 0.3.0 installation woes [message #501032] Mon, 30 November 2009 13:15 Go to next message
Originally posted by: carifio.nospam.nospam.usys.com
Installed atf 0.3.0 using directions at
http://wiki.eclipse.org/ATF/Installing Installed over 'Eclipse Java EE
IDE for Web Developers.
Build id: 20090920-1017' on linux (fc11) over gtk2-2.16.5-1.fc11.i586.
The installation appeared to have gone smoothly, eclipse restarted.
Then ... nothing. Can't launch as in
http://wiki.eclipse.org/ATF/Help/Tasks/Launch/Launch There's no 'Web
Browser Perspective' as described
in http://wiki.eclipse.org/ATF/Installing
Can this run on linux? Pl. advise. Thanks.
Re: atf 0.3.0 installation woes [message #501140 is a reply to message #501032] Tue, 01 December 2009 04:16 Go to previous messageGo to next message
hi Mike,
thanks for trying ATF. If you go to Help-> About Eclipse SDK and then
press "Installation Details", do you see ATF on the list of installed
software?
Jacek
> EE IDE for Web Developers.
Re: atf 0.3.0 installation woes [message #501180 is a reply to message #501140] Tue, 01 December 2009 07:49 Go to previous messageGo to next message
On 12/01/2009 04:16 AM, Jacek Pospychala wrote:
> hi Mike,
> software?
Yes, I've pasted the relevant stuff:
AJAX Tools Framework Mozilla IDE (Incubation)
0.3.0.v200911201100-17K-DZRDEBHhNXKKHD
org.eclipse.atf.mozilla.ide.feature.feature.group
Mozilla XPCOM for Java 1.9.1.0_v20090825-1855-27801aw311A193502411
org.mozilla.xpcom.feature.feature.group
Mozilla Xulrunner 1.9.1.0_v20090825-1855-57Z379OhF77g7cFR37gN7
org.mozilla.xulrunner.feature.feature.group
AJAX Tools Framework Webtools Integration (Incubation)
0.3.0.v200911201100-15-7zCN2PbcIMFLmQYLLIE
org.eclipse.atf.feature.feature.group
WST Common UI 3.1.1.v200908102300-7B5FRGDhdMNPnndenAjpWJAReO5Q
org.eclipse.wst.common_ui.feature.feature.group
WST Common Core 3.1.1.v200908102300-7B77FZ3F7RZHIVI9QdN4PM
org.eclipse.wst.common_core.feature.feature.group
These aren't the only additional plugins, however. But I don't see any
messages in the eclipse error log about clashes.
Re: atf 0.3.0 installation woes [message #501432 is a reply to message #501180] Wed, 02 December 2009 05:15 Go to previous messageGo to next message
Above seems to be fine for me.
If you have any .js files in your workspace, are you able to do "Debug
As -> Debug in Mozilla"?
Or if you go to "Window -> Show View -> Other..." in main menu, do you
see group "Mozilla" in Show View dialog?
And last thing to check, please open the Plug-in Registry view
(Window->Show View->Other, and find there Plug-in Registry). You should
see a new view being opened. There find the
"org.eclipse.atf.mozilla.ide.ui" - this is the plug-in that contributes
such things as Web Browser Tools perspective and other ATF user
interface things. From the context menu choose "Show advanced
operations" and then again from context menu choose "Diagnose". Are
there any problems? If not, can you also click "Start" then?
Jacek
Re: atf 0.3.0 installation woes [message #513965 is a reply to message #501032] Thu, 11 February 2010 14:58 Go to previous messageGo to next message
I've exactly the same problem as Mike described it in this thread.
I checked all the views Jacek suggested, but I don't have te "debug as Mozilla" option, I don't have the "Web Browser Tools" perspective, I don't have the group "Mozilla" in the show view dialog and I also don't have the "org.eclipse.atf.mozilla.ide.ui" in the plugin registry.
But eclipse is telling me ATF, Mozilla XPCOM and Xulrunner and WTP are installed correctly and completely.
I'm working on Win7, Eclipse 3.5 SR1.
I tested on an Ubuntu machine, there everything works as expected.
What can I do to use ATF on my Win7 PC?
Thanks in advance.
Bea
Re: atf 0.3.0 installation woes [message #526064 is a reply to message #501032] Thu, 08 April 2010 11:35 Go to previous messageGo to next message
I'm also having the same problem as reported by Mike, et. al.
Eclipse Version: 3.5.2.R35x_v20100210-0800
Build id: M20100211-1343
OS: W7Pro
Re: atf 0.3.0 installation woes [message #562432 is a reply to message #501032] Tue, 01 December 2009 04:16 Go to previous messageGo to next message
hi Mike,
software?
Jacek
Re: atf 0.3.0 installation woes [message #562460 is a reply to message #501140] Tue, 01 December 2009 07:49 Go to previous messageGo to next message
> hi Mike,
> software?
Re: atf 0.3.0 installation woes [message #562482 is a reply to message #501180] Wed, 02 December 2009 05:15 Go to previous messageGo to next message
Jacek
Re: atf 0.3.0 installation woes [message #562765 is a reply to message #501032] Thu, 11 February 2010 14:58 Go to previous messageGo to next message
Thanks in advance.
Bea
Re: atf 0.3.0 installation woes [message #563021 is a reply to message #501032] Thu, 08 April 2010 11:36 Go to previous message
OS: W7Pro
Previous Topic:ATF installation/building problems on MacOSX
Next Topic:ATF questions
Current Time: Sun Jul 20 05:38:02 EDT 2025
Powered by FUDForum. Page generated in 0.08569 seconds
