Modify creation tool: Create element in conteiner of its container [message #501095] |
Mon, 30 November 2009 19:53 |
I am trying to implement a special creation tool. Usually, when using
such a tool, you have to point the mouse over the compartment of the
parent of the element which is created by the tool. I would like to
modify the tool in a way that it is only necessary to point to the
compartment of one of the element's containers and when doing so, if the
containers inbetween do not exist, to create them before creating the
actual element the creation tool is meant for.
To clarify:
Assume, we have an element House, which can contain elements of the
class Room, which in turn can contain elements of the class Furniture.
Usually, I would select the furniture creation tool, move the mouse over
an existing Room until the cursor shows a little plus and then click
to add a Furniture to the Room.
I'd like my tool to work this way:
I select the furniture creation tool, move the mouse over a House
without Rooms and left-click. Then a new Room is created along with a
new Furniture in it. If I move the mouse over a Room, no additional Room
is created, but only the furniture.
So I have to somehow change which elements can be affected by the tool
and what elements are created when using it.
Can you tell me where I should start?
Matthias
FUDForum. Page generated in 0.03406 seconds
