Home » Eclipse Projects » EGit / JGit » Create patch with EGit
Create patch with EGit [message #500552] Thu, 26 November 2009 11:22 Go to next message
I used EGit to checkout the Eclipse Source code. I did for testing a
tiny change you wanted to create a patch via EGit which I could post in
Bugzilla.
Does EGit have the possibility to create patches? I don't see it in the
menu.
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Create patch with EGit [message #500559 is a reply to message #500552] Thu, 26 November 2009 12:02 Go to previous messageGo to next message
currently EGit doesn't have the functionality to create patches. That is because it is still lacking a good diff algorithm. Introducing that diff and the associated work is what I am currently working on.
You would need to use a native git implementation to create such a patch.
Re: Create patch with EGit [message #500877 is a reply to message #500559] Sun, 29 November 2009 20:46 Go to previous messageGo to next message
Hi Christian,
sounds good. You have already a bug report for this so that I can follow
your work?
Best regards, Lars
Chris wrote:
Re: Create patch with EGit [message #500897 is a reply to message #500877] Mon, 30 November 2009 03:25 Go to previous messageGo to next message
you can watch it in http://egit.eclipse.org where we propose and discuss code changes. This work is done in the cq-diff branch. E.g http://egit.eclipse.org/r/#change,87 or http://egit.eclipse.org/r/#change,37.
Ciao
Chris
Re: Create patch with EGit [message #501046 is a reply to message #500897] Mon, 30 November 2009 14:32 Go to previous messageGo to next message
Hi Chris,
thank you. Best regards, Lars
Re: Create patch with EGit [message #503336 is a reply to message #500897] Fri, 11 December 2009 18:11 Go to previous message
Hi Chris,
I also opened a Bug report for tis:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297636
Cheers, Lars
On 30.11.2009 00:25, Chris wrote:
> Ciao
> Chris
Re: Create patch with EGit [message #576046 is a reply to message #500552] Thu, 26 November 2009 12:02 Go to previous message
Re: Create patch with EGit [message #576203 is a reply to message #576046] Sun, 29 November 2009 20:46 Go to previous message
Hi Christian,
your work?
Best regards, Lars
Chris wrote:
Re: Create patch with EGit [message #576217 is a reply to message #500877] Mon, 30 November 2009 03:25 Go to previous message
Ciao
Chris
Ciao
Chris
Re: Create patch with EGit [message #576290 is a reply to message #576217] Mon, 30 November 2009 14:32 Go to previous message
Hi Chris,
Re: Create patch with EGit [message #576634 is a reply to message #576217] Fri, 11 December 2009 18:11 Go to previous message
Hi Chris,
Cheers, Lars
> Ciao
> Chris
Previous Topic:UI dependencies in egit core
Next Topic:JGit not working correctly
Current Time: Sat Jul 19 09:12:54 EDT 2025
Powered by FUDForum. Page generated in 0.06307 seconds
