Home » Modeling » M2T (model-to-text transformation) » Xpand: Cannot resolve the reference to a dependent model(The acces to the second model returns null because the returned eProxyUri does not seem to be correct.)
Xpand: Cannot resolve the reference to a dependent model [message #500446] Thu, 26 November 2009 03:52 Go to next message
I am migrating from oaw4 to oaw5. I have a main model (formComposition) which references another model (dataMod) . When I run my xpand template, I cannot resolve the reference to the second model.
The xpand template :
«info("Hello mnp = "+this.relatedModels.relatedSecondM.get(0))»
«info("Hello mnp name = "+this.relatedModels.relatedSecondM.get(0).name)»
The result on the console:
Registering platform uri 'F:\nadege-galileo\WkGMF300'
22889 INFO IOExtensions - Hello mnp = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@7f5580 (eProxyURI: file://F:/nadege-galileo/modele.second/src/model/secondMODEL E.datamod#/ eClass: org.eclipse.emf.ecore.impl.EClassImpl@55e55f (name: RootContent) (instanceClassName: null) (abstract: false, interface: false))
22889 INFO IOExtensions - Hello mnp name = null
The content of the referenced dataMod is not resolved (null) which is not so surprising because the eProxyURI, where it is looking for the model, is the following :
but the actual URI should be file://F:/nadege-galileo/WkGMF300/modele.second/src/model/se condMODELE.datamod
and the Registered platform URI is F:\nadege-galileo\WkGMF300.
Obviously the WkGMF300 is missing. What can I do to fix this problem ? Did I miss smthg while migrating?
Hereunder are my files:
The Ecore :
<eClassifiers xsi:type="ecore:EClass" name="RelatedModels">
<eStructuralFeatures xsi:type="ecore:EReference" name="relatedSecondM" eType="ecore:EClass ../../../dataMod_GMF/model/dataMod.ecore#//RootContent"/>
</eClassifiers>
The reference in the model:
<relatedModels name="">
<relatedSecondM href="../../../modele.second/src/model/secondMODELE.datamod#/ "/>
</relatedModels>
Note : If I change the reference in the model
from
to
and move the corresponding file into the same location as my main model, I resolve the reference to the second model. The result in the console is
22889 INFO IOExtensions - Hello mnp name = second.
It also works if I insert an absolute reference to the second model
I have registered the ecore files at the beginning of my workflow:
<property name="build.basedir" value="platform:/resource"></property>
<property name="basedirfile" value="platform:/resource/${projectRoot}"></property>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<platformUri value=".."/>
<registerEcoreFile value=" ${build.basedir}/formComposition/src/ecore/formComposition.e core "/>
<registerEcoreFile value="${build.basedir}/dataMod_GMF/model/dataMod.ecore"/>
</bean>
Any ideas ?
Re: Xpand: Cannot resolve the reference to a dependent model [message #500481 is a reply to message #500446] Thu, 26 November 2009 05:16 Go to previous messageGo to next message
You have to use platform:/resource URIs for your resources, otherwise the Proxies cannot be resolved.
~Karsten
Re: Xpand: Cannot resolve the reference to a dependent model [message #500482 is a reply to message #500446] Thu, 26 November 2009 05:04 Go to previous messageGo to next message
If you have registered platform resource URIs for the workspace root
then you should change the URI to
" platform:/resource/modele.second/src/model/secondMODELE.data mod#/ "
Sven
> mailto:org.eclipse.emf.ecore.impl.DynamicEObjectImpl@7f5580 (eProxyURI:
> eClass: mailto:org.eclipse.emf.ecore.impl.EClassImpl@55e55f (name:
> The Ecore :
> </eClassifiers>
> <relatedSecondM
> </relatedModels>
> from
> to
> <registerEcoreFile
> </bean>
> Any ideas ?
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: Xpand: Cannot resolve the reference to a dependent model [message #500626 is a reply to message #500482] Fri, 27 November 2009 03:53 Go to previous messageGo to next message
Thank you both for your help.
Using the platform resource URIs works very well.
But what's the difference between oaw4 and oaw5 on this point? I need to change my editor to save the reference with platform URIs, while I had kept the default behaviour with oaw4. Was it mere luck that it worked?
Best regards
Nadege
Re: Xpand: Cannot resolve the reference to a dependent model [message #500649 is a reply to message #500626] Fri, 27 November 2009 05:31 Go to previous message
After thinking it over: moving XmiReader to from emf.mwe.utils.Reader is the explanation the the different behaviour.
Previous Topic:[Acceleo] eInverse() and other functions
Next Topic:[xtext] mismatched input '{' expecting '{'
Current Time: Sun Jul 20 17:06:05 EDT 2025
Powered by FUDForum. Page generated in 0.25177 seconds
