Home » Modeling » EMF » [Teneo] Annotations required to support 2 associations between two classes
[Teneo] Annotations required to support 2 associations between two classes [message #499457] Sun, 22 November 2009 13:55 Go to next message
I have 2 classes instrument and underlying. An underlying is a type
instrument. An instrument may have many underlying, each of these
underlying is also an instrument. So I have underlying *..1 instrument
and underlying 1..1 instrument. The customer expects to see a generated
database with an instrument table and a underlying table with 2 foreign
keys, one for the one to many from instrument to underlying and one for
the one to one due to underlying being a sub type of instrument. How do
I achieve this result using XSD annotations?
Thx.
David
Re: [Teneo] Annotations required to support 2 associations between two classes [message #499460 is a reply to message #499457] Sun, 22 November 2009 14:32 Go to previous messageGo to next message
Hi David,
I would think that this should happen automatically if you use the joined inheritance strategy.
http://www.elver.org/hibernate/inheritance.html
Have you tried that?
If you want to control naming you should use JoinColumn and the PrimaryKeyJoinColumn annotation. There are some examples
here:
http://www.elver.org/hibernate/ejb3_format.html
http://www.elver.org/download/xmlsamples/Claim.xsd
gr. Martin
David Wynter wrote:
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Annotations required to support 2 associations between two classes [message #500597 is a reply to message #499460] Thu, 26 November 2009 17:45 Go to previous messageGo to next message
I use JOINED inheritance mapping. But I tried to put the join for the
super class to the subclass like so
<xsd:complexType name="Instrument">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="1" type="xsd:anyURI"
name="underlyingdetail" ecore:reference="mddb:Underlying" >
<xsd:annotation>
<xsd:appinfo
source="teneo.jpa">@JoinColumn(name="underlyingdetail")</xsd:appinfo >
</xsd:annotation>
</xsd:element>
Then the ManyToOne from the subclass to the superclass like so
<xsd:complexType name="Underlying">
<xsd:sequence minOccurs="0" maxOccurs="1">
<xsd:element ecore:reference="mddb:Instrument" minOccurs="0"
maxOccurs="unbounded" name="underlying" type="xsd:anyURI">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">
@ManyToOne(optional="true")
@JoinColumn(name="instrument")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
And end up with
Exception in thread "main"
org.eclipse.emf.teneo.annotations.mapper.StoreMappingExcepti on: The
feature/eclass underlying/Underlying should be a OneToMany but it
already has a ManyToMany, OneToOne or ManyToOne annotation
at
org.eclipse.emf.teneo.annotations.mapper.OneToManyReferenceA nnotator.annotate(OneToManyReferenceAnnotator.java:59)
at
org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyRefer enceAnnotator.annotate(HbOneToManyReferenceAnnotator.java:62 )
at
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator.a nnotate(EFeatureAnnotator.java:195)
at
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.ann otate(EClassAnnotator.java:270)
at
org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r.annotate(HbEClassAnnotator.java:57)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .processPackage(AnnotationGenerator.java:168)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .map(AnnotationGenerator.java:136)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:177)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:73)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:711)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:160)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:77)
The error is clear but it still leaves me trying to work out how I can
have and Underlying as a subclass of Instrument and also allow an
Instrument to have many Underlying
thx.
David
Martin Taal wrote:
> Hi David,
> PrimaryKeyJoinColumn annotation. There are some examples here:
> gr. Martin
> David Wynter wrote:
>> Hi,
>> generated database with an instrument table and a underlying table
>> with 2 foreign keys, one for the one to many from instrument to
>> underlying and one for the one to one due to underlying being a sub
>> type of instrument. How do I achieve this result using XSD annotations?
>> Thx.
>> David
Re: [Teneo] Annotations required to support 2 associations between two classes [message #500609 is a reply to message #500597] Fri, 27 November 2009 01:02 Go to previous message
Hi David,
See comments inline.
gr. Martin
David Wynter wrote:
> <xsd:sequence>
MT>> If an Instrument has many underlying then I would expect maxOccurs="unbounded" here. If you want this reference to
share the foreign key column with the reference on the other side then you have to set ecore:opposite also here (or on
the other reference). If you don't use ecore:opposite then you need to set the JoinColumn annotation on both sides with
the same JoinColum name (if you want sharing of the same foreign key column).
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:element>
MT>> if an Underlying is a subtype of Instrument I would expect an xsd:extension somewhere
MT>> If an Instrument has many Underlying and an Underlying at most 1 Instrument then I would expect maxOccurs="1"
MT>> Setting maxOccurs="1" will also solve the exception below. With maxOccurs="unbounded" you can only use
OneToMany/ManyToMany annotations (as the exception text says).
MT>> A side remark, I would expect the name of the element to be instrument as it refers to the instrument type
> <xsd:annotation>
MT>> the @ManyToOne(optional=true) is not required if minOccurs="0" as Teneo will add it automatically
MT>> If you change the name of the element to instrument then this JoinColumn is not needed (Teneo will then use the
instrument name).
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> And end up with
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> instrument and underlying 1..1 instrument. The customer expects to
>>> see a generated database with an instrument table and a underlying
>>> table with 2 foreign keys, one for the one to many from instrument to
>>> Thx.
>>> David
The Netherlands
Previous Topic:[CDO] scalability test problem
Next Topic:Problems to locate a resource
Current Time: Sun Jul 20 06:10:45 EDT 2025
Powered by FUDForum. Page generated in 0.26309 seconds
