Home » Archived » Buckminster » No component named xxx.yyy.zzz:eclipse.feature is known
No component named xxx.yyy.zzz:eclipse.feature is known [message #500284] Wed, 25 November 2009 10:07 Go to next message
I´m getting the error I used as the title of my thread if I try to export a p2 site using the buckminster action.
I thought, that exporting p2 sites should be quite easy using buckminster.
I have an existing project.
This project has a main feature which is named de.wagner.product
It includes 5 different product files, because i need to have products which connect to different databases.
The de.wagner.product includes the org.eclipse.rcp feature and all the other plugins I need for my application.
According to some tutorials on the web I just have to add a new feature, lets say I add a feature called de.wagner.product.site
This feature includes the de.wagner.product feature.
Now I should be able to export the p2 site by right clicking my new de.wagner.product.site feature "Buckminster -> invoke action". Then I choose p2.site and add a target.properties which has the standard entries.
When I try to create the p2.site The log says:
No component named de.wagner.product:eclipse.feature is known to Buckminster
I also noticed, that when I click on "buckminster -> invoke actions" the list of available actions is much smaller than on some other projects I have.
For example the actions :
-source.feature.jars
-site.repacked
-feature.jars
are missing.
Does anybody know what could cause the error?
-TW
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500316 is a reply to message #500284] Wed, 25 November 2009 11:07 Go to previous messageGo to next message
Hi Toby,
On 2009-11-25 16:07, TW wrote:
> When I try to create the p2.site The log says: No component named
> have.
> -site.repacked
> -feature.jars
> are missing.
It sounds like the meta-data is only partially extracted. Does the feature have all the required fields filled in (id,
version in particular)? Is the feature id different from the actual project name?
- thomas
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500430 is a reply to message #500316] Thu, 26 November 2009 02:14 Go to previous messageGo to next message
yes my feature does have an ID which is de.wagner.product. It also has a Version, a Name, a Provider and a Branding Plug-in.
The file names of the five different products are different .
They include different features, but all have the same Version, ID, and Name (in the product configuration editor)
If I temporary move all products except one to a tmp folder outside the project, the site.p2 buckminster action works. So I think this has something to do with more than one product.
Is it not possible to create a p2.site when having more than one product, or are the names versions and ids the problems in this case?
[Updated on: Thu, 26 November 2009 05:20] by Moderator
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500483 is a reply to message #500430] Thu, 26 November 2009 05:22 Go to previous messageGo to next message
On 2009-11-26 08:14, TW wrote:
> The file names of the five different products have a different name. But
> in the feature.xml the ID,Version and Name is the same. They are
> different because each product includes a unique connection feature
> which has informations about the database.
> How can I check if I have correct meta data?
Right-click on the project and choose "Buckminster" -> "View Cspec". That will tell show you what meta-data Buckminster
was able to extract.
- thomas
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500487 is a reply to message #500483] Thu, 26 November 2009 05:51 Go to previous messageGo to next message
Hi Thomas,
I compared the metadata of my de.wagner.product.site feature. The matadata is exactly the same if I have one product in my de.wagner.product feature or five products.
So I checked the metadata of the de.wagner.product feature. When I have five products in my feature I cant even access the buckminster metadata. When I have only one product in my feature I can access the metadata.
So I think the five produts in the feature mess up the metadata.
Do I have to create a feature for each product or is there a way to keep my architecture with five products in one feature or do I have to redesign everything?
-TW
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500494 is a reply to message #500487] Thu, 26 November 2009 07:01 Go to previous messageGo to next message
On 2009-11-26 11:51, TW wrote:
> Hi Thomas,
Multiple products in one feature should work. Can you please create a bugzilla and attach a sample feature that
reproduces the problem?
- thomas
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500498 is a reply to message #500494] Thu, 26 November 2009 07:38 Go to previous messageGo to next message
Hi Thomas,
I have inspected this problem more detailed and found out 2 major things that lead to this error. I think this is not a bug, maybe my products are not defined well enought.
First of all, more usefull information about my producs.
The 5 products are:
WAGNER.product (Main Product)
WAGNER.dai.dev.product (Product with dai.dev config)
WAGNER.dai.prod.product (Product with dai.prod config)
WAGNER.twt.dev.product (Product with twt.dev config)
WAGNER.twt.prod.product (Product with twt.prod config)
All of them have
ID= WAGNER
NAME = WAGNER
1. Rroblem: The IDs of the products matches
Attribute WAGNER is defined more then once in component de.wagner.product
This error should be fixable by changing each products ID to a unique one.
2. Problem: Same Dependencies
As I mentioned before, each product includes a dependency to a feature de.wagner.configuration.<productname>
But the main feature (WAGNER.product) and the WAGNER.twt.dev.product feature connect to the same database and because of this they include a dependency to the same feature "de.wagner.configuration.twt.dev"
Dependency de.wagner.configuration.twt.dev is defined more than once in component de.wagner.product
So 1. could be fixed easily but I don´t know how to fix 2. without adding a separate feature or deleting one of the two products.
So is this a bug or just some specific issue with my project?
-TW
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500533 is a reply to message #500498] Thu, 26 November 2009 09:35 Go to previous messageGo to next message
On 2009-11-26 13:38, TW wrote:
> Hi Thomas,
> The 5 products are:
> All of them have ID= WAGNER
> NAME = WAGNER
Yes, that's an absolute must.
This sounds like a bug. The fact that several products have the same dependency shouldn't be problem.
- thomas
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500619 is a reply to message #500533] Fri, 27 November 2009 03:11 Go to previous messageGo to next message
I'll try to add my first bug report in bugzilla Smile
Re: No component named xxx.yyy.zzz:eclipse.feature is known [message #500632 is a reply to message #500619] Fri, 27 November 2009 04:10 Go to previous message
Bug added:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=296321
Hope that I did it right.
-TW
Previous Topic:Hudson-Buckminster No suitable provider
Next Topic:How can I avoid source jars in feature exports?
Current Time: Sun Jul 20 18:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.67583 seconds
