Home » Eclipse Projects » Plugin Development Environment (PDE) » Building against two base locations
Building against two base locations [message #499734] Mon, 23 November 2009 16:27 Go to next message
I'm trying to sequence the following build tasks:
1. Do a product build.
2. Do a feature build of a test feature with test fragments.
For the test feature build, most of my fragments are hosted by plug-ins output by the product build. I would like to build against those JARs, rather than sucking in and rebuilding the binaries again for all the test plug-in dependencies.
But the test fragments also depend on JUnit, the EMMA OSGi hook, and a couple other test-related bundles. Obviously those aren't part of my product build output.
Is there an easy way to specify two base locations for the build? I see the alternative as combining the features/plugins from the product build output with a base Eclipse install and my other test dependencies.. but all that I/O will just slow down my build in the middle..
Ben
Re: Building against two base locations [message #499817 is a reply to message #499734] Tue, 24 November 2009 04:21 Go to previous messageGo to next message
Maybe you could build your test feature as a "normal" feature, using the pluginPath property to tell the build that it can find plugins in the eclipse base you used to build the product, but also in the product plugins directory, that should contain your plugins.
HTH
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Building against two base locations [message #499913 is a reply to message #499817] Tue, 24 November 2009 09:12 Go to previous message
Mickael Istria wrote on Tue, 24 November 2009 04:21
Thank you. I was not aware of this property. Looks promising.
Cheers
Ben
Re: Building against two base locations [message #603564 is a reply to message #499817] Tue, 24 November 2009 09:12 Go to previous message
Cheers
Ben
Previous Topic:Working Set
Next Topic:PDE Documentation
Current Time: Sun Jul 20 12:18:56 EDT 2025
Powered by FUDForum. Page generated in 0.04759 seconds
