Home » Archived » Buckminster » Importing a target definition fails
Importing a target definition fails [message #499684] Mon, 23 November 2009 12:10 Go to next message
Hi Thomas,
After solving the subversive problem, I'm now stuck with importing the
target definition. After running the import command (no errors):
../build/buckminster/buckminster --loglevel
DEBUG -consoleLog -debug -data /tmp/buckminster/masterData
importtarget --active /home/fhackenberger/workspace_jface_training/buildserver_bui ldroot/build/org.acoveo.buckminster/eclipse.target
on the target definition
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.5"?>
<target name="Running Platform">
<locations>
<location path="/home/fhackenberger/eclipse_3.5" type="Profile"/>
<location path="/home/fhackenberger/eclipse_3.5_delta_pack"
type="Directory"/>
</locations>
<environment>
<os>linux</os>
<ws>gtk</ws>
<arch>x86</arch>
<nl>en_GB</nl>
</environment>
<launcherArgs>
<vmArgs>-Dosgi.requiredJavaVersion=1.5 -XX:MaxPermSize=256m -Xms40m -Xmx256m</vmArgs>
</launcherArgs>
</target>
The listtargetdefinitions command
org.eclipse.buckminster.pde.org.eclipse.buckminster.pde.list targetdefinitions
lists one more target, but it does not show the directories I specified,
but:
!MESSAGE Target platform provided by class
org.eclipse.buckminster.pde.internal.PDETargetPlatform
* Running Platform : linux,gtk,x86/en_GB
If I resolve my query, I can see that buckminster imports bundles from the
buckminster installation, instead of the target platform I imported.
Any ideas?
Thanks in advance!
Florian
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: Importing a target definition fails [message #499814 is a reply to message #499684] Tue, 24 November 2009 04:39 Go to previous message
> but:
Sorry, I was confused by the newsgroup posting here:
http://dev.eclipse.org/newslists/news.eclipse.tools.buckmins ter/msg00979.html
which mentioned that the output should be something like:
* Directory /shared/stp/platforms/3.5M7/eclipse linux,gtk,ppc
when in fact the output is simply the name of the target definition if you
import one, instead of setting a single path.
It turned out that buckminster uses the target platform, but unfortunately
the buckminster installation contains more recent bundles and features,
which are preferred over the target platform.
I posted a new entry 'Target platform vs. Buckminster headless installation'
to discuss that problem.
Florian
www.hackenberger.at
Previous Topic:Choosing the subversion provider
Next Topic:Target platform vs. Buckminster headless installation
Current Time: Sun Jul 20 06:19:06 EDT 2025
Powered by FUDForum. Page generated in 0.03450 seconds
