Choosing the subversion provider [message #499554] |
Mon, 23 November 2009 06:02  |
Hi Thomas!
I just gave the headless build process with eclipse 3.5 and buckminster
another try and ran into a problem with the subversion team provider. I'm
getting:
ERROR org.eclipse.team.svn.core.operation.UnreportableException: Selected
SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available or install and select pure Java Subversion connector from the
plug-in connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Connector.
I installed buckminster headless using the director (director_latest) from
http://download.eclipse.org/tools/buckminster/headless-3.5
(The org.eclipse.buckminster.cmdline.product). I used
the "-Declipse.p2.mirrors=false" property throughout the installation
process, as a broken mirror caused problems a while ago. Then I added the
following features from the respective update sites in order:
org.eclipse.buckminster.core.headless.feature
org.eclipse.buckminster.pde.headless.feature
org.eclipse.buckminster.maven.feature
http://download.cloudsmith.com/buckminster/external
org.eclipse.buckminster.subversive.headless.feature
org.eclipse.buckminster.cvs.headless.feature
I set the active target platform using a .target file and then tried to
resolve a query which uses an rmap file with a search path using a
readerType="svn".
Chase Wolfinger mentioned the same error in the 'Headless Build with
Subversion' thread from Friday, 29 May 2009. Thomas mentioned that he seems
to have multiple svn providers, which does not seem to be apply in my case
(see plugin list below). He solved it by switching to subclipse, something
I would like to avoid if possible.
Here is a list of plugin from the buckminster installation:
com.ibm.icu.base_4.0.1.v20090822.jar
com.jcraft.jsch_0.1.41.v200903070017.jar
org.apache.ant_1.7.1.v20090120-1145
org.apache.commons.codec_1.3.0.v20080530-1600
org.apache.commons.httpclient_3.1.0.v20080605-1935
org.apache.commons.logging_1.0.4.v200904062259.jar
org.eclipse.ant.core_3.2.100.v20090817_r351.jar
org.eclipse.buckminster.ant_1.1.350.r10862
org.eclipse.buckminster.cmdline_1.0.350.r10881.jar
org.eclipse.buckminster.core_1.1.350.r10920.jar
org.eclipse.buckminster.cvs_1.0.350.r10863.jar
org.eclipse.buckminster.download_1.1.0.r10860.jar
org.eclipse.buckminster.executor_1.0.0.r10356.jar
org.eclipse.buckminster.fetcher_1.0.0.r10356.jar
org.eclipse.buckminster.generic_1.0.0.r10356.jar
org.eclipse.buckminster.installer_1.0.350.r10864.jar
org.eclipse.buckminster.jarprocessor_1.0.0.r10579.jar
org.eclipse.buckminster.jdt_1.0.0.r10628
org.eclipse.buckminster.maven_1.1.350.r10865.jar
org.eclipse.buckminster.opml_1.0.0.r10356.jar
org.eclipse.buckminster.osgi.filter_1.0.0.r10619.jar
org.eclipse.buckminster.pde_1.1.360.r10895
org.eclipse.buckminster.runtime_1.1.0.r10798.jar
org.eclipse.buckminster.sax_1.0.0.r10356.jar
org.eclipse.buckminster.subversion_1.0.0.r10759.jar
org.eclipse.buckminster.subversive_1.0.0.r10908.jar
org.eclipse.core.commands_3.5.0.I20090525-2000.jar
org.eclipse.core.contenttype_3.4.1.R35x_v20090826-0451.jar
org.eclipse.core.expressions_3.4.100.v20090429-1800.jar
org.eclipse.core.filebuffers_3.5.0.v20090526-2000.jar
org.eclipse.core.filesystem_1.2.0.v20090507.jar
org.eclipse.core.filesystem.linux.x86_1.2.0.v20080604-1400.j ar
org.eclipse.core.jobs_3.4.100.v20090429-1800.jar
org.eclipse.core.net_1.2.1.r35x_20090812-1200.jar
org.eclipse.core.net.linux.x86_1.1.0.I20081021.jar
org.eclipse.core.resources_3.5.1.R35x_v20090826-0451.jar
org.eclipse.core.runtime_3.5.0.v20090525.jar
org.eclipse.core.runtime.compatibility_3.2.0.v20090413.jar
org.eclipse.core.runtime.compatibility.auth_3.2.100.v2009041 3.jar
org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 90429-1800
org.eclipse.core.variables_3.2.200.v20090521.jar
org.eclipse.debug.core_3.5.0.v20090526-1600.jar
org.eclipse.ecf_3.0.0.v20090831-1906.jar
org.eclipse.ecf.filetransfer_3.0.0.v20090831-1906.jar
org.eclipse.ecf.identity_3.0.0.v20090831-1906.jar
org.eclipse.ecf.provider.filetransfer_3.0.1.v20090831-1906.j ar
org.eclipse.ecf.provider.filetransfer.httpclient_3.0.1.v2009 0831-1906.jar
org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v 20090831-1906.jar
org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20090831-19 06.jar
org.eclipse.ecf.ssl_1.0.0.v20090831-1906.jar
org.eclipse.equinox.app_1.2.0.v20090520-1800.jar
org.eclipse.equinox.common_3.5.1.R35x_v20090807-1100.jar
org.eclipse.equinox.frameworkadmin_1.0.100.v20090520-1905.ja r
org.eclipse.equinox.frameworkadmin.equinox_1.0.100.v20090520 -1905.jar
org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
org.eclipse.equinox.launcher.gtk.linux.x86_1.0.200.v20090520
org.eclipse.equinox.p2.artifact.repository_1.0.101.R35x_v200 90721.jar
org.eclipse.equinox.p2.console_1.0.100.v20090520-1905.jar
org.eclipse.equinox.p2.core_1.0.101.R35x_v20090819.jar
org.eclipse.equinox.p2.director_1.0.100.v20090520-1905.jar
org.eclipse.equinox.p2.director.app_1.0.100.v20090521-1912.j ar
org.eclipse.equinox.p2.engine_1.0.101.R35x_v20090825.jar
org.eclipse.equinox.p2.exemplarysetup_1.0.100.v20090520-1905 .jar
org.eclipse.equinox.p2.garbagecollector_1.0.100.v20090520-19 05.jar
org.eclipse.equinox.p2.jarprocessor_1.0.100.v20090520-1905.j ar
org.eclipse.equinox.p2.metadata_1.0.100.v20090525.jar
org.eclipse.equinox.p2.metadata.repository_1.0.101.R35x_v200 90812.jar
org.eclipse.equinox.p2.publisher_1.0.0.v20090527-1812.jar
org.eclipse.equinox.p2.repository_1.0.1.v20090901-1041.jar
org.eclipse.equinox.p2.touchpoint.eclipse_1.0.101.R35x_20090 820-1821.jar
org.eclipse.equinox.p2.touchpoint.natives_1.0.101.R35x_v2009 0806.jar
org.eclipse.equinox.p2.updatesite_1.0.100.v20090525.jar
org.eclipse.equinox.preferences_3.2.300.v20090520-1800.jar
org.eclipse.equinox.registry_3.4.100.v20090520-1800.jar
org.eclipse.equinox.security_1.0.100.v20090520-1800.jar
org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v2009080 7-1100.jar
org.eclipse.equinox.simpleconfigurator.manipulator_1.0.100.v 20090520-1905.jar
org.eclipse.jdt.core_3.5.1.v_972_R35x.jar
org.eclipse.jdt.debug_3.5.0.v20090526
org.eclipse.jdt.launching_3.5.0.v20090527.jar
org.eclipse.jsch.core_1.1.100.I20090430-0408.jar
org.eclipse.osgi_3.5.1.R35x_v20090827.jar
org.eclipse.osgi.services_3.2.0.v20090520-1800.jar
org.eclipse.pde.build_3.5.1.R35x_20090820
org.eclipse.pde.core_3.5.100.v20090821.jar
org.eclipse.team.core_3.5.0.I20090527-0620.jar
org.eclipse.team.cvs.core_3.3.200.I20090430-0408.jar
org.eclipse.team.cvs.ssh2_3.2.200.I20090508-2000.jar
org.eclipse.team.cvs.ssh_3.2.100.I20090508-2000.jar
org.eclipse.team.svn.core_0.7.8.I20090904-1300.jar
org.eclipse.text_3.5.0.v20090513-2000.jar
org.eclipse.update.configurator_3.3.0.v20090312.jar
org.eclipse.update.core_3.2.300.v20090525.jar
org.eclipse.update.core.linux_3.2.100.v20081008.jar
org.polarion.eclipse.team.svn.connector_2.2.1.I20091009-1900 .jar
org.polarion.eclipse.team.svn.connector.svnkit16_2.2.1.I2009 1009-1900.jar
org.sat4j.core_2.1.0.v20090520.jar
org.sat4j.pb_2.1.0.v20090520.jar
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: Choosing the subversion provider [message #499576 is a reply to message #499554] |
Mon, 23 November 2009 06:50   |
Hi Florian,
We do have an unresolved issue with Subversion in headless mode. Not sure what's causing it since all bundles seems to
be there: https://bugs.eclipse.org/bugs/show_bug.cgi?id=295696
If you have some additional info as to what can be causing this problem, I think it would be valuable if you added that
to the bugzilla.
Thomas Hallgren
On 11/23/2009 12:02 PM, DI Florian Hackenberger wrote:
> Hi Thomas!
> getting:
> readerType="svn".
Re: Choosing the subversion provider [message #499683 is a reply to message #499597] |
Mon, 23 November 2009 12:07  |
> Thanks for your reply. Is there a way to install an (old) working version?
> I will of course add additional information to the bug report, if I can
> provide any.
I was able to solve the problem, the details are in the bug discussion you
mentioned. Thanks for your help!
www.hackenberger.at
FUDForum. Page generated in 0.04451 seconds
