Home » Modeling » BPEL Designer » Name of the diagram type used by BPEL-Designer
Name of the diagram type used by BPEL-Designer [message #499311] Fri, 20 November 2009 13:10 Go to next message
Originally posted by: DAB268.gmx.de
Hi.
What is the name of the diagram type used by BPEL-Designer
(http://www.eclipse.org/bpel/images/screenshot.png)?
Greetz
Christian
Re: Name of the diagram type used by BPEL-Designer [message #499507 is a reply to message #499311] Mon, 23 November 2009 00:58 Go to previous messageGo to next message
What do you means?
what diagram do you want to know?
This is a bpel editor screenshot.
Re: Name of the diagram type used by BPEL-Designer [message #499848 is a reply to message #499507] Tue, 24 November 2009 06:19 Go to previous messageGo to next message
grid.qian schrieb:
> What do you means?
The editor shows an opened BPEL document as a diagram. That's the type
of diagram I wanted to know the name of.
Re: Name of the diagram type used by BPEL-Designer [message #500119 is a reply to message #499848] Tue, 24 November 2009 23:00 Go to previous message
Maybe my english is not good. I do not still understand you.
If you say, the diagram name just like bpmn diagram, it is not right.
BPEL has not diagram element. A BPEL process has a top element named process.
If you say, the diagram name is a bpel editor source codes class name, it should be BPELEditor.class. It extends GraphicalEditorWithPaletteAndTray.class.
If you say, the diagram is a gef diagram, I do not know gef. But the editor's super class is GraphicalEditorWithFlyoutPalette.clas. It is from gef.
Grid
Previous Topic:Compilation
Next Topic:Passing information to SOAP header
Current Time: Sun Jul 20 03:15:42 EDT 2025
Powered by FUDForum. Page generated in 0.04560 seconds
