Home » Modeling » EMF » OCL to generate EMF behaviour
OCL to generate EMF behaviour [message #499427] Sun, 22 November 2009 09:14 Go to next message
What is the status of being able to use OCL in EMF models to enable generation of behaviour in the generated code?
Many thanks,
Joel
Re: OCL to generate EMF behaviour [message #499450 is a reply to message #499427] Sun, 22 November 2009 12:11 Go to previous messageGo to next message
Joel,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469 is complete and
waiting to be pulled into a build.
Joel Rosi-Schwartz wrote:
> Many thanks,
> Joel
Re: OCL to generate EMF behaviour [message #499454 is a reply to message #499450] Sun, 22 November 2009 13:04 Go to previous messageGo to next message
Ed,
I have read the bug thread and I am still not clear. It appears to me that the underlying work to enable OCL based generation is ready to be put into place, but that the actual generation code is still to be done. Do I have that right?
Is the patch from Bug 255469 going to be backed into EMF 2.5 or will it only be applied to 2.6?
We are now actively working on moving ORMF forward. We plan to move the high level analysis model (which is already in EMF) to a detailed EMF model starting around Christmas time, with an aim to be generating initial code from the model early in the new year. My preference would be define as much behaviour in the model as possible from the start using OCL. How practical is it a this stage?
Joel
Re: OCL to generate EMF behaviour [message #499464 is a reply to message #499454] Sun, 22 November 2009 15:09 Go to previous messageGo to next message
Joel,
Comments below.
> Ed,
I think it will generate code that still delegates to a registered OCL
intepretted; the OCL changes to register the interpreter still need to
be committed.
Feature enhancement work is never done in maintenance stream.
It sounds like a workable plan given the state of the code. We'd of
course be happy to get feedback about problems so we can fix them.
> Joel
Re: OCL to generate EMF behaviour [message #499469 is a reply to message #499464] Sun, 22 November 2009 16:17 Go to previous messageGo to next message
Ed,
I will give this a try, guinea pig though I may be Wink It will be my pleasure to provide feedback and any assistance that I may be able.
Joel
[Updated on: Sun, 22 November 2009 16:17] by Moderator
Re: OCL to generate EMF behaviour [message #503722 is a reply to message #499427] Tue, 15 December 2009 03:50 Go to previous messageGo to next message
I was ready to start trying this, but on looking at Bugzilla 255469 still needs to be put into an EMF build and probably more important 291365 still has to be completed for OCL. Can you please confirm that until both of these are fixed and in builds that this functionality will not be ready for testing.
While I would really like to be able to give this a go, nor do I particularly want to fight Windmills Wink
Joel
Re: OCL to generate EMF behaviour [message #503980 is a reply to message #503722] Wed, 16 December 2009 07:10 Go to previous messageGo to next message
Joel,
The EMF things are done, but our release notes generator hasn't been
working the last while. :-(
Best to ask about these bugzillas on the bugzillas themselves...
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469 still needs to be
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=291365 still has to be
> testing.
> particularly want to fight Windmills ;)
> Joel
Re: OCL to generate EMF behaviour [message #503985 is a reply to message #503980] Wed, 16 December 2009 12:32 Go to previous messageGo to next message
Hi Ed,
Best thing would be to rebuild the release notes generator using EMF to make it dependable Wink
So what does it mean that the "The EMF things are done"? Where can I find clues on how to add constraints to a model? I am not that fussed if I can actually generate code yet from those constraints, but it would be nice to know that I will able to in say the next three months. If this means digging into the code for hints, then can you provide a few pointers on where to start. (But I hope not, because at the moment I am busy reading CDO code;-)
Ed Merks wrote on Wed, 16 December 2009 12:10
Joel,
working the last while. Sad
Will do.
Joel
Re: OCL to generate EMF behaviour [message #504131 is a reply to message #503985] Thu, 17 December 2009 01:50 Go to previous messageGo to next message
Joel,
The bugzillas to support this were committed by Kenn and are in a
build. It's only the OCL registration that's needed. Kenn was planning
to write some helpful information about it, but like so many of us, he's
stretched for time. I think the bugzillas themselves have a bit of
information to get started...
> Hi Ed,
> to make it dependable ;)
>> Joel,
>> working the last while. :(
> Will do.
> Quote:
> Joel
Re: OCL to generate EMF behaviour [message #504177 is a reply to message #499427] Thu, 17 December 2009 10:11 Go to previous message
I emailed Kenn Hussey about this and here is his reply
I actually provided fairly detailed descriptions of the EMF enhancements on the New & Noteworthy page for Helios - see http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios
As it currently stands, EMF now supports the ability to "plug in" delegates for constraints/invariants, feature settings, and operation invocations. However, in order to use a particular engine (e.g. the OCL engine), delegates for that engine must be plugged in. As you've discovered, bugs are open to do this for OCL, and I attached preliminary patches at one point (which I've since updated in my development workspace) but as yet I have been unable to find the time/funding to complete the work. With any luck, that could happen in time for the next milestone...
[Updated on: Thu, 17 December 2009 05:12] by Moderator
Previous Topic:Problems with emf ecore model
Next Topic:Outputting an EObject to a string for debugging or logging
Current Time: Sat Jul 19 17:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.06292 seconds
