Home » Modeling » EMF » Wrapper for EObject and EMF Notification
Wrapper for EObject and EMF Notification [message #499310] Fri, 20 November 2009 13:23 Go to next message
Hi everyone,
I am looking for a solution to wrap EObject and still receives EMF Notification.
I have a view that is used to display models objects that can come from different EMF models, let's say A and B. There can be 2 instances of the view, the first one shows an instance of A and the second an instance of B.
But as the view is generated, the base classes are written to be able to handle instances of both A and B.
I have a Wrapper that wraps an EObjet from A or B. So the viewer contains Wrapper and not EObject.
The main problem is that I am not able to get the view refreshed using EMF.Edit, because the EMF notification is triggered on the EObject and the viewer contains Wrapper.
I read the EMF book 2nd Edition on 16.2 Adapters, but I am a little bit confused about the Adapters mechanism. In fact, As I am dealing with multiple models, it will be more convenient if I don't have to modify the generated code of all the models to implement the Wrapper as an adapter.
I've also heard about ReflectiveItemProvider but not sure how to use it.
Any suggestion is welcomed.Thanks.
[Updated on: Fri, 20 November 2009 13:24] by Moderator
Re: Wrapper for EObject and EMF Notification [message #499314 is a reply to message #499310] Fri, 20 November 2009 13:31 Go to previous messageGo to next message
Nathalie,
Comments below.
Nathalie wrote:
> Hi everyone,
> I am looking for a solution to wrap EObject efficiently.
> instance of B.
EMF provides wrappers like this as well, DelegatingWrapperItemProvider,
but the wrapper listens to the item provider of the object being wrapped.
> as an adapter.
Your question is very open ended. I don't really understand why you
need wrappers. Normal item providers should be sufficient. To create a
specialized view different from the default, often one would create a
derived XyzItemProviderAdapterFactory with createAbc methods that create
a derived AbcItemProvider in which you make changes to the label,
children, or something like that. You'd not be modifying generated code
when doing that.
Re: Wrapper for EObject and EMF Notification [message #499321 is a reply to message #499314] Fri, 20 November 2009 14:11 Go to previous messageGo to next message
Thanks for answering Ed.
In fact the Wrapper is useful for two reasons. I have an explorer that shows the contents of the two instances of my custom view.
Let's call those instances V1 and V2. I forget to mention that V1 and V2 can shows both the same model instance.
In case V1 and V2 both show A for example I will have an error cause the explorer treeviewer cannot show the same object twice.
The other reason why I need wrapper is that I need to associate the EObject with the view instance that is showing it.
I saw the DelegatingWrapperItemProvider API but I dont exactly know to use it. Is it extensible ? Can I add some custom properties there ?
Concerning this:
> create
> when doing that.
I am using a content provider and a label provider which both extends AdapterFactory*Provider API. I am only using the generated ItemProvider of A and B and add them to the factories list of the ComposedAdapterFactory used to instantiate the content and label providers.
[Updated on: Fri, 20 November 2009 14:11] by Moderator
Re: Wrapper for EObject and EMF Notification [message #499340 is a reply to message #499321] Fri, 20 November 2009 18:06 Go to previous messageGo to next message
Nathalie,
Comments below.
Nathalie wrote:
> Thanks for answering.
That's the same reason for wrappers in the item providers; children of
non-containment references are likely to appear elsewhere in the tree
under their actual containing parent.
It sounds like it's doing pretty much exactly what you're trying to do...
> Concerning this:
>> when doing that.
> providers.
Re: Wrapper for EObject and EMF Notification [message #499947 is a reply to message #499310] Tue, 24 November 2009 10:07 Go to previous messageGo to next message
Hi Ed, I'm working with Nathalie so perhaps I can add a few clarifying details.
We've created our own ecore model, "vmf.ecore", to describe these views (yes, we have multiple such views), and then wrote a generator which reads our ".vmf" to generate Java code which implements our views. Our "views" can actually be decomposed to two parts: the actual GUI view (e.g. a SWT TableTreeViewer), and the content and label providers (which I'll collectively refer to as "providers"). The GUI view uses the providers, but the providers are also used to integrate into a CNF-based viewer.
I'm a bit fuzzy on the details of how CNF works, but it seems like you simply register an extension which specifies an activation type, and a content and label provider. For example, you'd say "When you have an IProject, invoke this particular content provider".
The resultant output that we want to display to the user looks something like this:
IProject Test
|- Author Info VMF Plugin
| |- Author: Oliver Wong
| | |- e-mail: owong@...
| | `- tel: 555-5555
| `- Author: Nathalie
| |- e-mail: nath@...
| `- tel: 555-5556
`- CVS Commit VMF Plugin
|- Committer: Oliver Wong
| `- 289 commits
`- Committer: Nathalie
`- 382 commits
Now the "Author: Oliver Wong" and "Committer: Oliver Wong" are backed by the same underlying EObject, e.g. an instance of User.
The problem, as I understand it, is if in CNF, we simply say "Whenever you have an instance of User, invoke the Author Info VMF Content Provider" is that you'd end up with the contact information (e-mail, telephone, etc.) appearing everywhere the User EObject appears; problematically, it would also appear under the "CVS Commit VMF Plugin" section.
So what we did instead was to create a wrapper (VMFNode) which holds an additional property stating which VMF-plugin it "belongs" to. So rather than the "Author: Oliver Wong" being backed simply by the User EObject, it is backed by a VMFNode, which contains a pointer to the User EObject, and the string containing the ID of the VMF plugin it came from, e.g. "com.mycompany.vmf.authorinfo". In this way, we can display different children for the node, depending on whether it "came from" one VMF plugin versus the other.
The two problems that arises when we try to integrate with EMF are:
1) It's not clear how to integrate our wrapper with EMF's wrapper.
2) It looks like if we use ItemProviders, rather than directly returning the children (the way you'd implement a ContentProvider), you return the features from which children should be derived, which puts some limitations on us (one of which is we can't return VMFNode, but there are a few others that are important to us as well).
Re: Wrapper for EObject and EMF Notification [message #499969 is a reply to message #499947] Tue, 24 November 2009 10:48 Go to previous messageGo to next message
Oliver,
Comments below.
> details.
> IProject Test
> | | |- e-mail: mailto:owong@...
> | | `- tel: 555-5555
> | `- Author: Nathalie
> | |- e-mail: mailto:nath@...
> | `- tel: 555-5556
> |- Committer: Oliver Wong | `- 289 commits
> `- 382 commits
I see.
> Plugin" section.
Yes, that's right.
That makes sense.
You don't necessarily have to but it's good to look at how something
similar is designed.
Yes, but that's just the default implementation. You can specialize it
to return your wrapper objects. Also have a close look at the
getChilden method; it does wrapping as needed there too. The wrappers
probably should implement all the I*Item*Provider interfaces that will
be needed and likely should add themselves as adapters so they can
produce viewer updates.
Re: Wrapper for EObject and EMF Notification [message #499990 is a reply to message #499969] Tue, 24 November 2009 11:25 Go to previous messageGo to next message
Hi Ed,
I just want to clarify something. I did a research yesterday as I was a little bit confused on the ItemProvider and AdapterFactory*Providers usage.
I find out that there seems to be two strategies.
The first one that you are talking about is to not overwrite AdapterFactory*Providers, but instead extends the ItemProviders, and this make more sense with using the DelegatingWrapperItemProvider, and specify there what the getChildren, getText, ... should do. The AdapterFactory*Providers classes will be only extended for the purpose of CNF, but none of their methods will be overwritten. They will do the job they are supposed to do, delegate to ItemProvider. Correct me if I am wrong.
The other strategy that we are using right now is to extend the AdapterFactory*Providers. All the logic to get the children and the labels is put in there and we only register the generated ItemProvider in the adapter factory to get notifications.
To use EMF wrappers here we have to specialize the generated ItemProvider and make them extend the DelegatingWrapperItemProvider class. So as in the first case the specialization is what going to give us the wrapping we want.
For me in both case it is possible to achieve the same results, but I don't know if there is one strategy that is more suitable.
Re: Wrapper for EObject and EMF Notification [message #500003 is a reply to message #499990] Tue, 24 November 2009 11:45 Go to previous messageGo to next message
Nathalie,
Comment sbelow.
Nathalie wrote:
> Hi Ed,
> usage.
> if I am wrong.
That sounds accurate.
This is sounding less promising to me. The specialized logic for
producing the label implies specialized logic for handling notifications
when the information used for the label changes. So you need to hook up
specialized adapters as well. As such, you would seem to be better off
using exactly the pattern that EMF is already using...
I'm only suggesting you look at that as an example. It sounds likely
that you'll want to extend a generated AbcItemProvider and make that act
as a wrapper; it should be well suited for that purpose given it has
logic for computing a label you can specialize and given it's an adapter
that can respond to notifications. You just need to be sure when you
create one it's hooked into the same factory as the basic item providers
you're already creating.
You're dealing with quite a complex situation and of course the item
provider design isn't exactly trivially simple either, but if you depart
from it and start using alternative approaches, you'll end up somewhere
that's difficult for me to help you with. I don't think I can properly
help with just little snips of knowledge. I don't know for example how
you are managing the creation of your wrappers or how you're ensuring
that the same wrapper instance is returned each time the parent is asked
for the children...
Re: Wrapper for EObject and EMF Notification [message #500052 is a reply to message #500003] Tue, 24 November 2009 14:28 Go to previous message
Hi Ed,
Thanks a lot for your answers. They brought a lot of light here! Smile
We are currently discussing on what we need to move on with the ItemProvider specialization (first strategy) to be more in line with EMF.
> for the children...
Our wrapper is a simple POJO class that implements IAdaptable. We register an adapter for it using the Eclipse Adapter Manager. Every time a parent is asked for its children, a new wrapper is created to wrap each child. The created wrappers are not cached.
Previous Topic:[CDO] Is there a way to get the 'diff' of two CDO Audit views?
Next Topic:Model instance transformation
Current Time: Sat Jul 19 21:35:35 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
