Re: Issues about LabelProvider and TreeViewer [message #504975 is a reply to message #504948] |
Wed, 23 December 2009 12:16   |
Use a StyledTextLabelProvider
Tom
Am 23.12.09 18:21, schrieb Andreas Hoegger:
> Hi Javier
> a possible solution would be painting by yourself. You should be able to
> implement it analog the table example (following the link).
> http://www.eclipse.org/articles/Article-CustomDrawingTableAn dTreeItems/index.html#_tr12J
> BR
> Andreas
> Javier wrote:
>> Hi Folks:
>> Firts of all, thanks for you help. I talk you about my problem:
>> I'm developing a plug-in to parser a file and view the results as a
>> tree, using a TreeViewer. For each leaf, I use a LabelProvider with a
>> text and icon. I have a class that extends LabelProvider and here,
>> I've implemented methods getText() and getImage(). I see, the icon is
>> always in the first position and then the text. Is there any way to
>> change that? I'd like to put the text first and icon, next.
>> If that is not possible, is there any other way to paint a tree,
>> putting text and icon? Using another class instead of TreeViewer? I
>> hope I've explained well.
>> Your comments will be well received.
>> Thank you very much.
Re: Issues about LabelProvider and TreeViewer [message #603860 is a reply to message #504948] |
Wed, 23 December 2009 17:04  |
Tom
> Hi Javier
> BR
> Andreas
> Javier wrote:
>> Hi Folks:
FUDForum. Page generated in 0.25760 seconds
