Home » Eclipse Projects » Eclipse Platform » Remove view name from Eclipse menu Window -> Show View(Remove/hide view name/shortcut from Eclipse menu Window -> Show View)
Remove view name from Eclipse menu Window -> Show View [message #499139] Thu, 19 November 2009 23:44 Go to next message
I need to remove the name/shortcut of the view which I have created from the Window->Show View menu.
Because I display this view in a separate menu.
Is there any way to hide/remove its entry from Window->Show View menu.
Thanks in advance
Re: Remove view name from Eclipse menu Window -> Show View [message #499306 is a reply to message #499139] Fri, 20 November 2009 13:05 Go to previous message
No. You can still add it to your own menu (the showView command takes an ID as a parameter), but as long as you have a Show View menu the item will show up.
Activities/capabilities can be used on the Show View menu, but that would get rid of all references to your view that it could find.
PW
Previous Topic:cross bookmarks or project location hyperlinks
Next Topic:How to force editor to foreground?
Current Time: Sun Jul 20 12:41:55 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
