Home » Archived » Buckminster » Aggregator: how to overcome unmet dependencies?
Aggregator: how to overcome unmet dependencies? [message #498906] Thu, 19 November 2009 02:10 Go to next message
Hello
I want to aggregate some update sites like described in
http://wiki.eclipse.org/Getting_Started_With_Aggregator_%28B uckminster%29
and the first test (EclEmma) went fine. However, when I add Checkstyle,
I get the following error:
Build failed! Exception was org.eclipse.core.runtime.CoreException:
Cannot complete the install because one or more required items could not
be found.
org.eclipse.core.runtime.CoreException: Cannot complete the install
because one or more required items could not be found.
at ...
Contains: Software being installed:
all.contributed.content.feature.group 1.0.0
Contains: Missing requirement: Eclipse Checkstyle Plug-in
5.0.3.200911042225 (net.sf.eclipsecs.feature.group 5.0.3.200911042225)
requires 'org.eclipse.core.runtime 3.2.0' but it could not be found
Contains: Cannot satisfy dependency:
Contains: From: all.contributed.content.feature.group 1.0.0
Contains: To: net.sf.eclipsecs.feature.group [5.0.3.200911042225]
The installation from the same update site into Eclipse 3.5.1 works.
The corresponding section from my build file:
<contributions label="Eclipse Checkstyle">
<repositories location="http://eclipse-cs.sf.net/update/"
categoryPrefix="EclipseCS">
<metadataRepository
href="p2:http://eclipse-cs.sf.net/update#//@metadataRepository"/>
</repositories>
</contributions>
How can I tell Buckminster not to care about org.eclipse.core.runtime?
Michael
Re: Aggregator: how to overcome unmet dependencies? [message #498997 is a reply to message #498906] Thu, 19 November 2009 08:11 Go to previous messageGo to next message
Hi Michael,
I think that what you really would like to do, is to provide a validation repository to your aggregation such as the
Galileo repository or the Eclipse platform. The validation repository will satisfy dependencies such as the one you have
problems with but nothing will be copied from a validation repository to the default.
Thomas Hallgren
On 11/19/2009 08:10 AM, Michael Pellaton wrote:
> Hello
> be found.
> at ...
> <metadataRepository
> </repositories>
> </contributions>
> Thanks
> Michael
Re: Aggregator: how to overcome unmet dependencies? [message #499026 is a reply to message #498997] Thu, 19 November 2009 10:15 Go to previous message
Thank you for your answer. In the meantime I found exatly the solution
you proposed.
Michael
Previous Topic:Building p2 site including features from other p2 sites, using local folder/zip as rmap provider
Next Topic:Problem importing product with headless Buckminster 3.5
Current Time: Sat Jul 19 09:16:19 EDT 2025
Powered by FUDForum. Page generated in 0.03105 seconds
