Home » Eclipse Projects » Plugin Development Environment (PDE) » ToggleState default value
ToggleState default value [message #498844] Wed, 18 November 2009 13:52
My command has a default value, but it seems to be ignored whether true or false. Specifically, in the handler's execute(), event.getCommand().getState(ID).getValue() always returns false the first time (before I toggle its state).
I'm using Eclipse 3.4. Here is my command extension:
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="mystuff.command.DisplayZonesHandler"
description="Toggles the displaying of the video zones"
id="mystuff.command.displayzones"
name="Display Zones">
<state
id="mystuff.command.displayzones.state">
<class class="org.eclipse.jface.commands.ToggleState">
<parameter name="default" value="false">
</parameter>
</class>
</state>
</command>
Thanks in advance.
<Edit>
Still no luck, but I set the actual state value in the handler's constructor, but the UI element does not reflect the change.
        ICommandService service = (ICommandService) PlatformUI.getWorkbench().getService(ICommandService.class);
        State state = service.getCommand("com.p21csi.fps.vision.zone.ui.command.displayzones")
            .getState(STATE_ID);
        state.setValue(true);
        service.refreshElements("com.p21csi.fps.vision.zone.ui.command.displayzones", null);
[Updated on: Wed, 18 November 2009 14:49] by Moderator
Previous Topic:PDE director throws signature exception
Next Topic:ToggleState default value
Current Time: Sun Jul 20 06:20:39 EDT 2025
Powered by FUDForum. Page generated in 0.07845 seconds
