Home » Language IDEs » PHP Development Tools (PDT) » Xdebug: tens of sessions simultaneously(Problems with debugging)
Xdebug: tens of sessions simultaneously [message #498316] Mon, 16 November 2009 08:12 Go to next message
Hi all,
I have problem with debugging a website in Eclipse: instead of one session I got many of them.
The reason is that I have some images which are generated on the PHP side. And while I set breakpoint on some file and debug up to it, I have as many additional sessions in Debug window as images are requested to generate.
All requests are dispatched via same index.php, so I can't for example set not to debug it.
Have you any ideas how to restrict debugging to a file which I need?
Re: Xdebug: tens of sessions simultaneously [message #498513 is a reply to message #498316] Tue, 17 November 2009 05:25 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
Do you have multisession support enabled in the xdebug configuration in
PDT ? if you do try turning it off.
(see http://www.eclipse.org/pdt/documents/XDebugGuideForPDT2.0.pd f for
info on how to configure this)
Dave Kelsey
On 16/11/09 13:12, Artiom Neganov wrote:
> Hi all,
> generate.
Re: Xdebug: tens of sessions simultaneously [message #498514 is a reply to message #498513] Tue, 17 November 2009 05:31 Go to previous messageGo to next message
Thanks for reply.
No, it is disabled.
Re: Xdebug: tens of sessions simultaneously [message #498543 is a reply to message #498316] Tue, 17 November 2009 07:27 Go to previous messageGo to next message
Maybe you are using "break on first line" option ? Try disabling that
and only adding breakpoints to the specific file you want to debug
Dave Kelsey
> Hi all,
> generate.
Re: Xdebug: tens of sessions simultaneously [message #498546 is a reply to message #498543] Tue, 17 November 2009 07:36 Go to previous messageGo to next message
Eclipse User wrote on Tue, 17 November 2009 07:27
Dave Kelsey
No, I'm not. Breakpoints are triggered when needed, but in Debug window, there are many sessions:
http://www.onlinedisk.ru/view/269894
[Updated on: Tue, 17 November 2009 07:37] by Moderator
Re: Xdebug: tens of sessions simultaneously [message #498559 is a reply to message #498546] Tue, 17 November 2009 08:51 Go to previous message
Ok, I understand the issue now, this is due to using remote session
initiation. Can you turn off remote session initiation and debug using a
PHP Web script launch or is that not possible ?
Alternatively you could set remote session initiation to prompt and
accept the first request and reject the subsequent requests yourself.
It might be worth raising an enhancement bugzilla to record this and see
if a more automated solution can be devised.
Dave Kelsey
>> Dave Kelsey
> No, I don't. Breakpoints are triggered when needed, but when viewing at
Previous Topic:Create Patch Menu Item Does Not Appear
Next Topic:Eclipse cannot handle htm files with embedded php
Current Time: Sat Jul 19 16:53:14 EDT 2025
Powered by FUDForum. Page generated in 0.09534 seconds
