Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Acceleo and Rhapsody
[Acceleo] Acceleo and Rhapsody [message #497024] Thu, 12 November 2009 05:07 Go to next message
I would like to use Rhapsody as modeler in my generation chain.
Despite the Acceleo UML Model Editor can parse my Rhapsody model, the Acceleo templates do not generate anything from my Rhapsody xmi files.
What have I got to do in order to be able to use Rhapsody xmi files ?
[Updated on: Thu, 12 November 2009 06:12] by Moderator
Re: [Acceleo] Acceleo and Rhapsody [message #498352 is a reply to message #497024] Mon, 16 November 2009 09:45 Go to previous message
--------------050908010001060300010809
Sebastien,
There is no specific step to do if you rhapsody xmis are readable as EMF
models. Acceleo "not generating anything" means that your "@main"
template is never called (or you get an exception in the error log).
Could you be a little more specific about the failure you experience?
Laurent Goubet
Obeo
Sebastien Roy wrote:
> Hello,
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050908010001060300010809--
Previous Topic:Does Acceleo work with EMF?
Next Topic:Access XSD model from Xpand java extensions
Current Time: Sat Jul 19 12:43:31 EDT 2025
Powered by FUDForum. Page generated in 0.04032 seconds
