Home » Archived » BIRT » multiple listbox parameter trouble(any help is greatly appreciated)
multiple listbox parameter trouble [message #497959] Fri, 13 November 2009 10:02 Go to next message
Hi, im pretty new to BIRT so maybe somebody here can help me out.
I want it so that when the parameters prompt comes up for my report, a user can choose one or more tables to view from a listbox and whichever ones are not selected are not viewed on the report. So my report currently has three data sets and three tables (one for each).
I had it working when it was a single value drop down box, but it doesn't work when i enable multiple values. I am using a report parameter and a script on beforeFactory to do all this. Here is the script:
ExhaustLocationsTable = reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "exhaustLocations");
NoRestockLocationsTable = reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "noRestockLocations");
DynamicLocationsTable = reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "dynamicLocations");
if (params["rprmTable"].selected == "Exhaust Locations")
NoRestockLocationsTable.drop();
DynamicLocationsTable.drop();
else if (params["rprmTable"].selected == "No Restock Locations")
ExhaustLocationsTable.drop();
else if (params["rprmTable"].selected == "Dynamic Locations")
else if (params["rprmTable"].selected == "Exhaust Locations" && "No Restock Locations")
else if (params["rprmTable"].selected == "Exhaust Locations" && "Dynamic Locations")
else if (params["rprmTable"].selected == "No Restock Locations" && "Dynamic Locations")
Am i on the right track? Any help is apppreciated.
Note: I already tried .value, doesnt work either.
Re: multiple listbox parameter trouble [message #497996 is a reply to message #497959] Fri, 13 November 2009 11:07 Go to previous messageGo to next message
You are on the right track, you just need to iterate over the parameter
choices.
var keepExhaust = false;
var parmcount = params["rprmTable"].value.length
for( i=0; i < parmcount; i++ ){
//either switch on the parameter or if else
//to get the parameter value use
//params["rprmTable"].value[i]
if( params["rprmTable"].value[i] == "Exhaust Locations" ){
keepExhaust = true;
//now do the drops
if( !keepExhaust ){
//do the same for all the other tables
Also you can use repoortContext.getDesignHandle().findElement() now.
Jason
> Restock Locations")
> Locations")
Re: multiple listbox parameter trouble [message #498015 is a reply to message #497959] Fri, 13 November 2009 12:06 Go to previous message
thanks for the reply jason, I figured it out on my own, for anyone who is interested here is my solution, works perfectly!
var size = params["rprmTable"].value.length;
var items = '';
for(var i = 0; i < size; i++)
if(params["rprmTable"].value[i] == "Exhaust Locations")
items += '1,';
else if(params["rprmTable"].value[i] == "No Restock Locations")
items += '2,';
else if(params["rprmTable"].value[i] == "Dynamic Locations")
items += '3,';
var parts = items.split(",");
if((parts.length - 1) == 1)
if(parts[0] == '1')
else if(parts[0] == '2')
else if(parts[0] == '3')
else if((parts.length - 1) == 2)
if((parts[0] == '1' || parts[1] == '1') && (parts[0] == '2' || parts[1] == '2'))
else if((parts[0] == '2' || parts[1] == '2') && (parts[0] == '3' || parts[1] == '3'))
else if((parts[0] == '3' || parts[1] == '3') && (parts[0] == '1' || parts[1] == '1'))
Previous Topic:Dynamically adding barcode - how to extract info from birt?
Next Topic:How to give permissions rights in my BIRT Reports ?
Current Time: Sun Jul 20 03:09:23 EDT 2025
Powered by FUDForum. Page generated in 0.03077 seconds
