Home » Eclipse Projects » Eclipse Platform » Handler conflicts in the log file
Handler conflicts in the log file [message #496410] Mon, 09 November 2009 17:24 Go to next message
I noticed today (in my product) that a lot of commands were disabled at the wrong time. I eventually found a whole pile of conflict messages in the log. What could cause this? Here are the messages:
!ENTRY org.eclipse.ui.workbench 2 0 2009-11-09 17:12:38.390
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-11-09 17:12:38.390
!MESSAGE Conflict for 'org.eclipse.ui.navigate.goToResource':
HandlerActivation(commandId=org.eclipse.ui.navigate.goToReso urce,
handler=ActionHandler( org.eclipse.ui.internal.navigator.resources.actions.GotoReso urceAction @17fe679),
expression=AndExpression(AndExpression(org.eclipse.ui.SubAct ionBars$1@101a4f3,ActivePartExpression(org.eclipse.ui.navigator.resources.ProjectExplorer@10bd3f1)),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@17e7f88)),sourcePriority=1064961)
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
handler=ActionHandler(org.eclipse.ui.dialogs.PropertyDialogAction@11fe04d),
!ENTRY org.eclipse.ui.workbench 2 0 2009-11-09 17:12:38.422
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-11-09 17:12:38.422
!MESSAGE Conflict for 'org.eclipse.ui.edit.addBookmark':
HandlerActivation(commandId=org.eclipse.ui.edit.addBookmark,
handler=ActionHandler(org.eclipse.ui.actions.AddBookmarkAction@52c125),
!MESSAGE Conflict for 'org.eclipse.ui.edit.addTask':
HandlerActivation(commandId=org.eclipse.ui.edit.addTask,
handler=ActionHandler(org.eclipse.ui.actions.AddTaskAction@8eaf0a),
!MESSAGE Conflict for 'org.eclipse.ui.file.refresh':
HandlerActivation(commandId=org.eclipse.ui.file.refresh,
handler=ActionHandler(org.eclipse.ui.internal.navigator.reso urces.actions.ResourceMgmtActionProvider$2@839907),
!MESSAGE Conflict for 'org.eclipse.ui.project.buildProject':
HandlerActivation(commandId=org.eclipse.ui.project.buildProj ect,
handler=ActionHandler(org.eclipse.ui.actions.BuildAction@28785c),
!MESSAGE Conflict for 'org.eclipse.ui.project.openProject':
HandlerActivation(commandId=org.eclipse.ui.project.openProje ct,
handler=ActionHandler(org.eclipse.ui.actions.OpenResourceAction@228ba7),
!MESSAGE Conflict for 'org.eclipse.ui.project.closeProject':
HandlerActivation(commandId=org.eclipse.ui.project.closeProj ect,
handler=ActionHandler(org.eclipse.ui.actions.CloseResourceAction@170c84c),
Mark.
Re: Handler conflicts in the log file [message #496411 is a reply to message #496410] Mon, 09 November 2009 17:29 Go to previous messageGo to next message
you have two plugins that declares in each plugin.xml the same command with the same id as it seems to be the same associated action, I think that you won't see the difference at runtime but it will be better if yoiu know why they they are declared twice.
Hope this will help,
Aurelien Pupier
Re: Handler conflicts in the log file [message #496828 is a reply to message #496410] Wed, 11 November 2009 09:04 Go to previous messageGo to next message
It looks like some path through the ProjectExplorer is causing handlers to be registered twice through their subactionbars. Please open a bug report at:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
PW
Re: Handler conflicts in the log file [message #496853 is a reply to message #496828] Wed, 11 November 2009 09:45 Go to previous messageGo to next message
Thanks, Paul.
I guess I'd better check my Common Navigator contributions to make sure this isn't my fault... If I can't find any explanation I'll file a bug.
Mark.
Re: Handler conflicts in the log file [message #1027959 is a reply to message #496853] Wed, 27 March 2013 12:42 Go to previous messageGo to next message
Hello Mark,
I know it has been a long time since you asked this, but did you even find the cause of the problem?
Re: Handler conflicts in the log file [message #1027978 is a reply to message #1027959] Wed, 27 March 2013 13:15 Go to previous messageGo to next message
Man, you're going back years... Shocked
Unfortunately, I don't recall if I ever figured out it was my problem, or a bug in the Platform. Since it looks like I never filed a bug, it must have been my fault. Smile
M.
Re: Handler conflicts in the log file [message #1027987 is a reply to message #1027978] Wed, 27 March 2013 13:29 Go to previous message
Thank you
Previous Topic:menucontribution appears only in one perspective
Next Topic:Eclipse Juno Sr2 Window64 Update Sites All Fail
Current Time: Sat Jul 19 19:30:51 EDT 2025
Powered by FUDForum. Page generated in 0.05505 seconds
