[QVTO] Evaluator: QvtRuntimeException by Transformation [message #496655] |
Tue, 10 November 2009 14:43  |
i want to transform UML to XSD
i become this Error:
org.eclipse.m2m.internal.qvt.oml.evaluator.QvtRuntimeExcepti on: java.lang.NullPointerException
at uml2xsd::Package::package2schema(uml2xsd.qvto:26)
at uml2xsd::Package::toschema(uml2xsd.qvto:21)
at uml2xsd::main(uml2xsd.qvto:<Unknown>)
my code looks like this:
modeltype UML "strict" uses 'http://www.eclipse.org/uml2/3.0.0/UML';
modeltype XSD "strict" uses 'http://www.eclipse.org/xsd/2002/XSD';
transformation uml2xsd(in uml:UML, out xsd:XSD);
main() {
uml.objectsOfType(UML::Package) -> map toschema();
mapping UML::Package::toschema() : xsd::XSDSchema{
init{
var schemaTargetNamespace := 'http://www.example.com/' + self.name;
var schemaTargetPrefix := self.name.normalizeSpace();
var schemaForSchemaNamespace := 'http://www.w3.org/2001/XMLSchema';
var schemaForSchemaPrefix := 'xsd';
result.targetNamespace := schemaTargetNamespace;
result := self.map package2schema();
mapping UML::Package::package2schema() : XSD::XSDSchema {
var newObj := object XSDSchema{
schema.contents := self.packagedElement[UML::Class] -> map class2complexType();
schema.contents := self.packagedElement[UML::Class] -> map class2attributeGroup();
result := schema;
mapping UML::Class::class2complexType() : XSD::XSDComplexTypeDefinition {
name := self.name + 'Type';
_abstract := self.isAbstract;
derivationMethod := self.getDerivationMethod();
mapping UML::Class::class2attributeGroup() : XSD::XSDAttributeGroupDefinition{
query UML::Class::getDerivationMethod() : XSDDerivationMethod{
return if self.generalization -> notEmpty() then
XSDDerivationMethod::extension
else
XSDDerivationMethod::restriction
endif;
please help me.
[Updated on: Tue, 10 November 2009 14:45] by Moderator
Re: [QVTO] Error by Transformation [message #496733 is a reply to message #496657] |
Wed, 11 November 2009 03:52   |
Hi Radek,
thanks,
the Error LOg is below.
I think, I must Import the class xsdschema from the package org.eclipse.xsd in order to use the method setSchemaForSchemaQNamePrefix( schemaForSchemaPrefix ) and getQNamePrefixToNamespaceMap() . because the schema is empty.
the first mapping will be look like this:
init{
result := result.setSchemaForSchemaQNamePrefix( schemaForSchemaPrefix );
[Map qNamePrefixToNamespaceMap = result.getQNamePrefixToNamespaceMap();
result := self.qNamePrefixToNamespaceMap.put(schemaForSchemaPrefix , schemaForSchemaNamespace );
result := self.qNamePrefixToNamespaceMap.put(schemaTargetPrefix , schemaTargetNamespace );
import org.eclipse.xsd.xsdschema did not function. how can I import a Library or a Package?
thanks,
the Error log is below
eclipse.buildId=M20090917-0800
java.version=1.6.0_16
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
Error
Wed Nov 11 09:05:14 CET 2009
Operational QVT: Exception
at org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.handleNewB aseTypeDefinition(XSDComplexTypeDefinitionImpl.java:2116)
at org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.patch(XSDC omplexTypeDefinitionImpl.java:1061)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:535)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1602)
at org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching (XSDSchemaImpl.java:1529)
at org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1921)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1074)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:255)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList. java:307)
at org.eclipse.m2m.internal.qvt.oml.ast.env.QvtOperationalEvalu ationEnv.callSetter(QvtOperationalEvaluationEnv.java:531)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitAssignExp(QvtOperationalEvaluationVi sitorImpl.java:412)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitAssignExp(QvtGenericEvaluationVisitor.java:3 27)
at org.eclipse.m2m.qvt.oml.ecore.ImperativeOCL.impl.AssignExpIm pl.accept(AssignExpImpl.java:404)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitObjectExp(QvtOperationalEvaluationVi sitorImpl.java:950)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitObjectExp(QvtGenericEvaluationVisitor.java:3 79)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.ObjectExpI mpl.accept(ObjectExpImpl.java:176)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitVariableInitExp(QvtOperationalEvalua tionVisitorImpl.java:1004)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitVariableInitExp(QvtGenericEvaluationVisitor. java:407)
at org.eclipse.m2m.qvt.oml.ecore.ImperativeOCL.impl.VariableIni tExpImpl.accept(VariableInitExpImpl.java:262)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitOperationBody(QvtOperationalEvaluati onVisitorImpl.java:985)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitMappingBody(QvtOperationalEvaluation VisitorImpl.java:569)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitMappingBody(QvtGenericEvaluationVisitor.java :355)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.MappingBod yImpl.accept(MappingBodyImpl.java:122)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitMappingOperation(QvtOperationalEvalu ationVisitorImpl.java:732)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitMappingOperation(QvtGenericEvaluationVisitor .java:363)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.MappingOpe rationImpl.accept(MappingOperationImpl.java:220)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.executeImperativeOperation(QvtOperational EvaluationVisitorImpl.java:1611)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.doVisitOperationCallExp(QvtOperationalEva luationVisitorImpl.java:638)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitOperationCallExp(QvtOperationalEvalu ationVisitorImpl.java:597)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitMappingCallExp(QvtOperationalEvaluat ionVisitorImpl.java:587)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitMappingCallExp(QvtGenericEvaluationVisitor.j ava:359)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.MappingCal lExpImpl.accept(MappingCallExpImpl.java:112)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitAssignExp(QvtOperationalEvaluationVi sitorImpl.java:354)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitMappingBody(QvtOperationalEvaluation VisitorImpl.java:555)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitExpression(QvtOperationalEvaluationV isitorImpl.java:329)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitExpression(QvtGenericEvaluationVisitor.java: 191)
at org.eclipse.m2m.internal.qvt.oml.evaluator.iterators.QvtImpe rativeIteratorTemplate.evaluateResultTemplate(QvtImperativeI teratorTemplate.java:45)
at org.eclipse.m2m.internal.qvt.oml.evaluator.iterators.QvtIter ationTemplate.evaluate(QvtIterationTemplate.java:84)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitImperativeIterateExp(QvtOperationalE valuationVisitorImpl.java:1341)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitImperativeIterateExp(QvtGenericEvaluationVis itor.java:435)
at org.eclipse.m2m.qvt.oml.ecore.ImperativeOCL.impl.ImperativeI terateExpImpl.accept(ImperativeIterateExpImpl.java:210)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitEntryOperation(QvtOperationalEvaluat ionVisitorImpl.java:459)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitEntryOperation(QvtGenericEvaluationVisitor.j ava:443)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.EntryOpera tionImpl.accept(EntryOperationImpl.java:67)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.runMainEntry(QvtOperationalEvaluationVisi torImpl.java:2123)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl$1.invoke(QvtOperationalEvaluationVisitorI mpl.java:924)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.doVisitTransformation(QvtOperationalEvalu ationVisitorImpl.java:898)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl.visitModule(QvtOperationalEvaluationVisit orImpl.java:750)
at org.eclipse.m2m.internal.qvt.oml.evaluator.QvtGenericEvaluat ionVisitor.visitModule(QvtGenericEvaluationVisitor.java:371)
at org.eclipse.m2m.internal.qvt.oml.expressions.impl.ModuleImpl .accept(ModuleImpl.java:622)
at org.eclipse.m2m.internal.qvt.oml.runtime.project.QvtInterpre tedTransformation.evaluate(QvtInterpretedTransformation.java :170)
at org.eclipse.m2m.internal.qvt.oml.runtime.project.QvtInterpre tedTransformation.run(QvtInterpretedTransformation.java:118)
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.QvtLaunchCon figurationDelegateBase.doLaunch(QvtLaunchConfigurationDelega teBase.java:182)
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.QvtLaunchCon figurationDelegateBase.doLaunch(QvtLaunchConfigurationDelega teBase.java:137)
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.QvtLaunchCon figurationDelegate$1.run(QvtLaunchConfigurationDelegate.java :65)
at org.eclipse.m2m.internal.qvt.oml.common.launch.SafeRunner$Sa meThreadRunner.run(SafeRunner.java:33)
at org.eclipse.m2m.internal.qvt.oml.common.launch.SafeRunner$1. run(SafeRunner.java:26)
at org.eclipse.m2m.internal.qvt.oml.common.launch.ShallowProces s.run(ShallowProcess.java:41)
at org.eclipse.m2m.internal.qvt.oml.common.launch.ShallowProces s.run(ShallowProcess.java:32)
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.QvtLaunchCon figurationDelegate$3.run(QvtLaunchConfigurationDelegate.java :98)
Re: [QVTO] Error by Transformation [message #496746 is a reply to message #496733] |
Wed, 11 November 2009 04:30   |
Originally posted by: dvorak.radek.gmail.com
Hi Youssef,
Not sure what you need to import here. As for QVT access to metamodels
your are done,
as you have compiled. Just reference classes by simple or qualified name
(using modeltype identifier).
See where the NPE happens in the stack trace. It's in the xsd model.
Sometimes custom modified Java generated models are not coded sufficiently
defensive
and require certain invariants to hold in order to work correctly.
I recommend to check the line:
to see how the model needs to be initialized.
QVTO can access only what the metamodel exposes and you have to know how
to populate the
[out] model correctly.
/Radek
On Wed, 11 Nov 2009 09:52:12 +0100, Youssef <aitlaydi.youssef@gmail.com>
wrote:
> Hi Radek,
> thanks,
> init{
> result :=
> result :=
> result :=
> thanks,
> Error
> l.java:1921)
> coreEList.java:255)
> java:307)
> sitorImpl.java:412)
> sitorImpl.java:950)
> sitorImpl.java:950)
> sitorImpl.java:354)
> itor.java:435)
> torImpl.java:2123)
> mpl.java:924)
> orImpl.java:750)
> teBase.java:182)
> teBase.java:137)
FUDForum. Page generated in 0.07795 seconds
