Home » Modeling » EMF » peristent XML Schema to Ecore mappings
peristent XML Schema to Ecore mappings [message #496508] Tue, 10 November 2009 06:39 Go to next message
Hello!
I plan to create my Ecore models from existing XML schemas. However, there are a number of features that need a bit of customization, such as having features named "nodes" instead of "node" if the "node" child element has maxOccurs>1.
I can do this change in the genmodel itself, but then if the schema changes and I reload the EMF model, the customization is lost.
Is there a way to persist such simple mappings? (JAXB, for example, allows you to place such information in the schema itself or in a separate file).
Thank you in advance!
Csaba
Re: peristent XML Schema to Ecore mappings [message #496526 is a reply to message #496508] Tue, 10 November 2009 07:37 Go to previous message
--------------020203090206020202050101
Csaba,
Comments below.
Csaba Koncz wrote:
> Hello!
You can use ecore:name="nodes".
Read these to to find out more about that.
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
Essential EMF, DZone Refcard
<http://refcardz.dzone.com/refcardz/essential-emf>
> separate file).
> Csaba
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Csaba,<br>
<br>
Comments below.<br>
<br>
Csaba Koncz wrote:
<blockquote cite="mid:hdbjdj$b0c$1@build.eclipse.org" type="cite">Hello!
<br>
<br>
element has maxOccurs&gt;1.
<br>
</blockquote>
You can use ecore:name="nodes".<br>
<br>
Read these to to find out more about that.<br>
<blockquote><a
href=" http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf">XML
Schema to Ecore Mapping</a><br>
<a href="http://refcardz.dzone.com/refcardz/essential-emf">Essential
EMF, DZone Refcard</a></blockquote>
<blockquote cite="mid:hdbjdj$b0c$1@build.eclipse.org" type="cite"><br>
<br>
separate file).
<br>
<br>
<br>
Csaba <br>
</blockquote>
</body>
</html>
--------------020203090206020202050101--
Previous Topic:DocumentRoot
Next Topic:[CDO] Event Notification procedure
Current Time: Sat Jul 19 06:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.05021 seconds
