XSD adapter and imports [message #496131] |
Sun, 08 November 2009 17:00  |
I think I have a similar problem as anubis stated in a message in the oAW forum in May: http://oaw-forum.itemis.de/forum/viewtopic.php?forum=1&s howtopic=1844 Unfortunately it was not answered.
I have 3 XSD which import each other. No matter which one I name in the workflow I get the following:
SEVERE: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be called for every EPackage explicitly. Schema:XSDSchema 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test) Root:XSDSchema 'file:/.../foo/bar/root.xml.xsd' (null) XSDSchemas: 'file:/.../foo/bar/root.xml.xsd' (null), 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test)
java.lang.RuntimeException: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be called for every EPackage explicitly. Schema:XSDSchema 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test) Root:XSDSchema 'file:/.../foo/bar/root.xml.xsd' (null) XSDSchemas: 'file:/.../foo/bar/root.xml.xsd' (null), 'file:/.../foo/bar/ns1.xsd' (http://www.example.org/test)
Any help is very appreciated.
br,
Marco
Re: XSD adapter and imports [message #498032 is a reply to message #497971] |
Fri, 13 November 2009 13:03   |
Hi Marco,
could you please create a bug-report at https://bugs.eclipse.org/bugs/
and attach the XSDs and the workflow I need to reproduce the problem?
cheers,
Moritz
> Sorry for pushing this. But I do not find a solution myself.
> Is there really no answer to this 1/2 year old issue.
> I tried a lot. With having now the schema split in 2 XSD, both reference
> in schemaFile of the workflow, I still get the same:
> WARNING: XSDSchema 'file:/.../foo/root.xml.xsd' has no namespace.
> Setting it to null
> Nov 13, 2009 2:41:27 PM
> org.eclipse.xtend.typesystem.xsd.builder.OawXSDResource
> collectImportedSchemas
> WARNING: Include /root.xml.xsd/XSDImport 'ns1.xsd' has not been
> resolved. XSDSchema 'file:/.../foo/root.xml.xsd' (null)
> org.eclipse.xtend.typesystem.xsd.builder.XSDResolver locateSchema
> INFO: Importing 'ns1.xsd' (http://www.example.org/test) from XSDSchema
> org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator createBean
> 'file:/.../foo/ns1.xsd' (http://www.example.org/test) Root:XSDSchema
> 'file:/.../foo/root.xml.xsd' (null) XSDSchemas:
> 'file:/.../foo/root.xml.xsd' (null), 'file:/.../foo/ns1.xsd'
> br
> m
FUDForum. Page generated in 0.30893 seconds
