p2 profile created By Buckminster [message #495909] |
Fri, 06 November 2009 10:35  |
Can anyone explain how the p2 profile creation in Buckminster differs from that created by an IDE export?
The product generated from "Export Product" has a default "profile.profile" folder under p2/org.eclipse.equinox.p2.engine/profileRegistry/, this contains a .data/ folder, a .lock file and a handful of *.profile.gz files.
When creating via Buckminster/Hudson, I specify a profile name in my buckminster.cspex file, and this creates a correspondingly-named directory, with the same .data/ folder and .lock file, but with fewer, ungzipped, .profile files.
This seems to make the difference between p2 updates working and not for me - if I replace my Buckminster-created profile folder with the one created by the IDE and modify my configuration/config.ini accordingly, my updates work fine, otherwise I get features and plugins that report as updated but with the old contents not replaced on disk.
Thanks!
Re: p2 profile created By Buckminster [message #496025 is a reply to message #495909] |
Sat, 07 November 2009 05:48   |
Hi Bob,
I'm uncertain what you mean by "buckminster created profile". The profile is created when a product
is installed by the p2 director. Are you referring to the "create.product" ant tasks in our RCP
tutorial?
Thomas Hallgren
> Thanks!
Re: p2 profile created By Buckminster [message #496238 is a reply to message #495909] |
Mon, 09 November 2009 07:49  |
I finally got to the bottom of my problem!! I thought I'd better share as I find it incredible that I seem to be the only person having this trouble...
In short, my problems were solved by adding the line:
<arg value="-roaming"/>
to the call to the director app in build/product.ant in my product feature project. Forgive me if I'm stating what everyone else already knew, but this came as something of a revelation to me!
Without this option, it *seems* that a product created via the create.product/create.product.zip examples can only be used successfully on the machine on which it was created, or a machine with file access to the build's working directory, as it *seems* the default profile created contains absolute file paths without the -roaming option passed to the director.
I can see why this would be the case, and the scant documentation on the -roaming option makes sense, but I feel like I'm missing something else here - I can't be the first person the build a p2-enabled product via Buckminster and Hudson following the examples and have it not work as expected?
Confused (but happy) :-S
Bob
FUDForum. Page generated in 0.04124 seconds
