Home » Modeling » M2T (model-to-text transformation) » [XPand]: 0.8.0 Performance surprise..
[XPand]: 0.8.0 Performance surprise.. [message #495961] Fri, 06 November 2009 14:11 Go to next message
Hi folks,
I'm just experimenting with moving to 0.8.0 from 0.7.2 and I've noticed an, um.. significant change in performance characteristics. By significant, I mean that a model that was taking 1 second to generate is now taking 45 seconds . In general I'm seeing a 25-40x slow-down. This is with 0.8.0 v 2009092913 of Xpand, MWE, etc.. I've upgraded xtext as well but this happens on purely EMF based projects as well. Nothing else has changed (except for some API fixes for xtext in unrelated plugins) -- I've verified by reverting to each configuration.
Any guesses about what might be causing this? Areas where performance has been optimized for different cases? My templates are quite complex and use aspects and a lot of xtend calls.
I don't this this the class loader issues as the whole process seems to be much slower and again I haven't changed anything else.
cheers,
Miles
Re: [XPand]: 0.8.0 Performance surprise.. [message #495972 is a reply to message #495961] Fri, 06 November 2009 15:15 Go to previous messageGo to next message
One additional data point here. I've just tried it on my desktop machine (MacPro 8-core) and the performance delta is less compared to my laptop, but still in the 5x-12x + range. So perhaps there is some kind of caching or other heap issue here. It's a bit difficult to switch back and forth but I can prob. set up two configurations if more testing would be helpful. But hopefully there is something simple going on here.
Re: [XPand]: 0.8.0 Performance surprise.. [message #496123 is a reply to message #495961] Sun, 08 November 2009 13:39 Go to previous messageGo to next message
Hi Miles,
that not a nice suprise.
Did you change the execution environment from plain Java VM to OSGi?
If you are in an OSGi environment, please have a look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=278753
Please file a bug with a short sample project if you do not use OSGi.
Sebastian
Miles Parker schrieb:
> Hi folks,
> cheers,
> Miles
Re: [XPand]: 0.8.0 Performance surprise.. [message #496698 is a reply to message #496123] Tue, 10 November 2009 20:40 Go to previous messageGo to next message
Sebastian, see below please..
Sebastian Zarnekow wrote on Sun, 08 November 2009 13:39
Hi Miles,
Well, I'm executing it from an Eclipse plugin using WorkflowRunner, so I guess that's an OSGi environment. Wink However, this is what I've been doing all along, so unless the performance changes for the bug above have somehow worked at cross purposes to my own lousy attempts at managing buddies and class loading, I don't think that's it. Also, when I run it, it seems slow throughout entire process. But OTOH, I do use helper ext Java statics. But actually, my class-loading must have been working pretty well because up to 0.8.0 I think I've been getting identical performance with my plugin launched and workflow launched templates. Or at least I've been able to generate 30k lines plus within user interactive time (~10sec).
It doesn't make sense to do a small project because this is happening with my very large system. But..You could install the AMF plugins and *then* execute a very small example project I could bundle up for you. (This is just part of my plot to get people to play with AMF. Wink) If you don't feel like doing that I'll try to take another look at this when I return from modeling days next week.
cheers,
Miles
Re: [XPand]: 0.8.0 Performance surprise.. [message #499998 is a reply to message #496698] Tue, 24 November 2009 11:37 Go to previous messageGo to next message
--------------070008080205070900020608
>> Hi Miles,
> I guess that's an OSGi environment. ;) However, this is what I've been
> (This is just part of my plot to get people to play with AMF. ;)) If
> cheers,
> Miles
Hi Miles,
just curious - did you find the reason of your performance surprise ?
ekke
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:hdd4m4$f1s$1@build.eclipse.org" type="cite">Sebastian,
see below please..
<br>
<br>
<br>
<blockquote type="cite">Hi Miles,
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=278753">https://bugs.eclipse.org/bugs/show_bug.cgi?id=278753</a>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
cheers,
<br>
<br>
Miles
<br>
</blockquote>
Hi Miles,<br>
<br>
just curious - did you find the reason of your performance surprise ?<br>
<br>
ekke<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------070008080205070900020608--
Re: [XPand]: 0.8.0 Performance surprise.. [message #500043 is a reply to message #499998] Tue, 24 November 2009 14:08 Go to previous messageGo to next message
Hi Ekke,
This is very high on my list of very high things on my list to address. Smile On the theory that it might be related to use of Java external calls from Xtend, I'm planning to get rid of those and see how it affects things. I'll report back as soon as I can.
cheers,
Miles
Re: [XPand]: 0.8.0 Performance surprise.. [message #501442 is a reply to message #495972] Wed, 02 December 2009 06:07 Go to previous messageGo to next message
--------------050003090907080001080506
> going on here.
Miles, you're not alone,
just tested 0.8.0 - both versions: 0.8.0M3 and N-Builds 2009-12-01
I got nearly same values as you: 18x - 40x slower
I reverted to 0.7.2
ekke
skype: ekkes-corner
<html>
<head>
</head>
<blockquote cite="mid:hd2048$50b$1@build.eclipse.org" type="cite">One
on here.
<br>
</blockquote>
Miles, you're not alone,<br>
<br>
just tested 0.8.0 - both versions: 0.8.0M3 and N-Builds 2009-12-01<br>
I got nearly same values as you: 18x - 40x slower<br>
I reverted to 0.7.2<br>
<br>
ekke<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
--------------050003090907080001080506--
Re: [XPand]: 0.8.0 Performance surprise.. [message #501460 is a reply to message #501442] Wed, 02 December 2009 07:53 Go to previous messageGo to next message
Hi Ekke,
could you please submit a bug report?
Sven
>> going on here.
> I reverted to 0.7.2
> ekke
> skype: ekkes-corner
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: [XPand]: 0.8.0 Performance surprise.. [message #501462 is a reply to message #501460] Wed, 02 December 2009 07:55 Go to previous messageGo to next message
--------------050502010200050809080007
Sven Efftinge schrieb:
> Hi Ekke,
of course, but will take some days to prepare a project to test with
ekke
> Sven
>> I reverted to 0.7.2
>> ekke
>> skype: ekkes-corner
skype: ekkes-corner
<html>
<head>
</head>
<blockquote cite="mid:hf5nvj$pp4$1@build.eclipse.org" type="cite">Hi
Ekke,
<br>
<br>
<br>
</blockquote>
of course, but will take some days to prepare a project to test with<br>
<br>
ekke<br>
<blockquote cite="mid:hf5nvj$pp4$1@build.eclipse.org" type="cite"><br>
<br>
Sven
<br>
<br>
ekke schrieb:
<br>
<blockquote type="cite">Miles Parker schrieb:
<br>
<blockquote type="cite">One additional data point here. I've just
<br>
</blockquote>
<br>
<br>
<br>
<br>
I reverted to 0.7.2
<br>
<br>
ekke
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
skype: ekkes-corner
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
--------------050502010200050809080007--
Re: [XPand]: 0.8.0 Performance surprise.. [message #501591 is a reply to message #501460] Wed, 02 December 2009 17:52 Go to previous messageGo to next message
--------------090405000102080700050901
after discussion with Karsten Thoms: there's some work-in-progress and
no bugzilla needed at the moment
ekke
> Hi Ekke,
> Sven
>> I reverted to 0.7.2
>> ekke
>> skype: ekkes-corner
skype: ekkes-corner
<html>
<head>
</head>
no bugzilla needed at the moment<br>
<br>
ekke<br>
<br>
Ekke,
<br>
<br>
<br>
<br>
<br>
Sven
<br>
<br>
ekke schrieb:
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
I reverted to 0.7.2
<br>
<br>
ekke
<br>
-- <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
skype: ekkes-corner
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
--------------090405000102080700050901--
Re: [XPand]: 0.8.0 Performance surprise.. [message #501816 is a reply to message #501591] Thu, 03 December 2009 17:31 Go to previous messageGo to next message
ekke (ekkehard gentz) wrote on Wed, 02 December 2009 17:52
ekke
Oh good. Smile I was working for a few hours yesterday trying to put something together but my stuff is so API based that I was having trouble putting together a quick workflow to test things -- not to mention that you need half a dozen plugin dependencies. Any hints?
cheers!
Miles
[Updated on: Thu, 03 December 2009 17:32] by Moderator
Re: [XPand]: 0.8.0 Performance surprise.. [message #502196 is a reply to message #495961] Mon, 07 December 2009 03:03 Go to previous messageGo to next message
Hi all,
just tried to reproduce this using a workflow from the emfmodelvisualizer project [1]. On my machine, this workflow takes about 1.5 seconds with 0.7.2 and ~3 seconds using a 0.8 version. I was able to track it down to the following change in the EmfRegistryMetaModel:
@@ -262,20 +263,33 @@ public class EmfRegistryMetaModel implements MetaModel {
return getTypeForEClassifier(el.getEEnum());
final EClass clazz = ((EObject) obj).eClass();
return getTypeForEClassifier(clazz);
+ final Set<Type> types = getKnownTypes();
if (obj instanceof Enumerator) {
- final Set<Type> types = getKnownTypes();
for (Type t : types) {
+ // check for EEnumType because the EDataTypeType for
+ // ecore::EEnumerator matches all enumerator instances
if (t instanceof EEnumType) {
if (t.isInstance(obj)) {
return t;
+ } else {
+ // some other non-enumerated EDataType
+ for (Type t : types) {
+ if (t instanceof EDataTypeType) {
+ if (t.isInstance(obj)) {
+ return t;
return null;
public Set<Type> getKnownTypes() {
final Set<Type> result = new HashSet<Type>();
without the else branch (which is executed for tons of objects, e.g. all Strings, Integers,...), it only took 1.5 seconds again. But simply removing it won't be a solution, as it has been added to fix a bug [2].
Although this is "only" factor 2 (in contrast to 25-40x) for this workflow, it probably is at least one of the causes of what you observed.
> --- [ekke wrote] ---
> after discussion with Karsten Thoms: there's some work-in-progress and no bugzilla needed at the moment
Is this still true? Or should I put this information into a new bug report?
Daniel
[1] http://code.google.com/p/emfmodelvisualizer/source/browse/ga lileo/trunk/org.openarchitectureware.vis.graphviz.demo/src/v isualizeEcore.mwe
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=281269
Re: [XPand]: 0.8.0 Performance surprise.. [message #502226 is a reply to message #499998] Mon, 07 December 2009 05:07 Go to previous messageGo to next message
Well, others might want to be up to date:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297053
>>> Hi Miles,
>> cheers,
>> Miles
> Hi Miles,
> ekke
> skype: ekkes-corner
Re: [XPand]: 0.8.0 Performance surprise.. [message #502227 is a reply to message #502196] Mon, 07 December 2009 05:10 Go to previous messageGo to next message
Thanks, that is of great help.
sven
Daniel Weber schrieb:
> Hi all,
>> This [...]
> MetaModel {
> return t;
> + } else {
> + return t;
> return null;
> Regards,
> Daniel
> [1]
Re: [XPand]: 0.8.0 Performance surprise.. [message #503375 is a reply to message #502227] Sat, 12 December 2009 10:00 Go to previous messageGo to next message
--------------000604090806060001050400
just tested using N200912111914 MWE, Xpand, Xtext
the good news:
performance problem is fixed -
runs same speed as before with 0.7.2 :-)
the bad news:
now I'm getting hundreds of those warnings:
15:25:52.299 WARN [o.e.xtend.typesystem.emf.EClassType] Couldn't
resolve type
for EDiagnosticChain
resolve type
for EMap
but my workflow seems to run well
skype: ekkes-corner
<html>
<head>
</head>
just tested using N200912111914 MWE, Xpand, Xtext<br>
<br>
the good news:<br>
performance problem is fixed -<br>
runs same speed as before with 0.7.2 :-)<br>
<br>
the bad news:<br>
now I'm getting hundreds of those warnings:<br>
<br>
resolve type<br>
for EDiagnosticChain<br>
resolve type<br>
for EMap<br>
<br>
but my workflow seems to run well<br>
<br>
uml<br>
DE189929490<br>
</div>
</body>
</html>
--------------000604090806060001050400--
Re: [XPand]: 0.8.0 Performance surprise.. [message #504455 is a reply to message #503375] Sat, 19 December 2009 09:19 Go to previous message
--------------050600030101040607070805
using 0.8.0M4 this is fixed.
THX
ekke
> the good news:
> the bad news:
> resolve type
> resolve type
> for EMap
<html>
<head>
</head>
using 0.8.0M4 this is fixed.<br>
THX<br>
ekke<br>
<br>
ekke schrieb:
<blockquote cite="mid:hg0b6t$7hq$1@build.eclipse.org" type="cite">
<br>
the good news:<br>
<br>
the bad news:<br>
<br>
resolve type<br>
resolve type<br>
for EMap<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------050600030101040607070805--
Previous Topic:[XPAND] [MWE] 0.8.0 regression
Next Topic:QVT code for xsd Annotations
Current Time: Sat Jul 19 23:23:34 EDT 2025
Powered by FUDForum. Page generated in 0.10791 seconds
