Password save problem with CVS [message #495915] |
Fri, 06 November 2009 10:49  |
When I try to connect to any CVS repository, I am prompted for a password. Although I always check Save password, it is never saved. When I restart eclipse, the password dialog always comes up again. There is no problem once I enter the password, but with a lot of repositories that I connect to, it's very annoying. I have tried new workspaces, and even moved up Eclipse, but it doesn't help, so I assume this is something to do with my environment (only happens on my laptop, not my desktop).
Does anyone have any idea what I could do to fix this?
[Updated on: Fri, 06 November 2009 11:04] by Moderator
Re: Password save problem with CVS [message #495918 is a reply to message #495915] |
Fri, 06 November 2009 11:03  |
I should add that it correctly remembers my user id, just not the password. The password dialog that comes up says incorrect username or password. This is in the log at that time:
org.eclipse.equinox.security.storage.StorageException: No password provided.
at org.eclipse.equinox.internal.security.storage.SecurePreferen cesRoot.getModulePassword(SecurePreferencesRoot.java:292)
at org.eclipse.equinox.internal.security.storage.SecurePreferen cesRoot.getPassword(SecurePreferencesRoot.java:219)
at org.eclipse.equinox.internal.security.storage.SecurePreferen ces.put(SecurePreferences.java:224)
at org.eclipse.equinox.internal.security.storage.SecurePreferen cesWrapper.put(SecurePreferencesWrapper.java:110)
at org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.updateCache(CVSRepositoryLocation.java:1021)
at org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.updateCache(CVSRepositoryLocation.java:1003)
at org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.setAllowCaching(CVSRepositoryLocation.java:990)
at org.eclipse.team.internal.ccvs.ui.WorkbenchUserAuthenticator .promptForUserInfo(WorkbenchUserAuthenticator.java:101)
at org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.promptForUserInfo(CVSRepositoryLocation.java:837)
at org.eclipse.team.internal.ccvs.core.connection.CVSRepository Location.openConnection(CVSRepositoryLocation.java:815)
at org.eclipse.team.internal.ccvs.core.client.Session.open(Sess ion.java:159)
at org.eclipse.team.internal.ccvs.core.resources.RemoteFile.int ernalFetchContents(RemoteFile.java:217)
at org.eclipse.team.internal.ccvs.core.resources.RemoteFile.fet chContents(RemoteFile.java:195)
at org.eclipse.team.core.variants.CachedResourceVariant.ensureC ontentsCached(CachedResourceVariant.java:111)
at org.eclipse.team.core.variants.CachedResourceVariant.getStor age(CachedResourceVariant.java:101)
at org.eclipse.team.internal.ccvs.core.resources.RemoteFile.get Contents(RemoteFile.java:186)
at org.eclipse.team.internal.ccvs.ui.RemoteRevisionQuickDiffPro vider.readDocument(RemoteRevisionQuickDiffProvider.java:254)
at org.eclipse.team.internal.ccvs.ui.RemoteRevisionQuickDiffPro vider.getReference(RemoteRevisionQuickDiffProvider.java:131)
at org.eclipse.ui.internal.texteditor.quickdiff.DocumentLineDif fer$2.run(DocumentLineDiffer.java:496)
FUDForum. Page generated in 0.02850 seconds
