Home » Eclipse Projects » EclipseLink » Fixed String or Oracle CHAR
Fixed String or Oracle CHAR [message #376325] Wed, 09 July 2008 10:59 Go to next message
I'm in the process of porting an application from Toplink Essentials to
eclipselink because we need some of the new features or extension of
eclipselink, but we encounter a snag...
All things considered, setup and etc, a SessionCustomizer that looks like
below that will handle CHAR columns doesn't work on eclipselink anymore?
Or am I missing something?
Nick
public class OracleSessionCustomizer implements SessionCustomizer {
public void customize(Session session) {
session.getEventManager().addListener(new OracleSessionListener());
//set the default for the columns.
session.getLogin().setDefaultNullValue(String.class, " ");
session.getLogin().setDefaultNullValue(Integer.class, 0);
session.getLogin().setDefaultNullValue(Long.class, 0);
class OracleSessionListener extends SessionEventAdapter {
public void postAcquireConnection(SessionEvent event) {
Connection conn = ((DatabaseAccessor) event.getResult()).getConnection();
OracleConnection oconn = (OracleConnection) conn;
oconn.setDefaultFixedString(true);
The same SessionCustomizer will work in Toplink flawlessly, where the PK's
are CHAR's:
For example using find:
pk.setCol1("XYZ");
pk.setCol2(" "); <--- a single space
EntityA entity = em.find(EntityA.class, pk);
For example using persist:
EntityB entity = new EntityB();
entity.setCol1("XYZ");
entity.setCol2(null);
em.getTransaction().begin();
em.find(entity);
em.getTransaction().commit();
eclipselink will not insert spaces but instead nulls
Re: Fixed String or Oracle CHAR [message #376332 is a reply to message #376325] Thu, 10 July 2008 16:53 Go to previous messageGo to next message
This appears to be a regression but may have been completed for
performance reasons. I have filed a bug but this bug will require more
research. I will review early next week.
--Gordon
http://bugs.eclipse.org/240407
Re: Fixed String or Oracle CHAR [message #376339 is a reply to message #376332] Fri, 11 July 2008 11:20 Go to previous messageGo to next message
Thanks Gordon!
We will follow your progress with great interest, as CHAR is still a very
important data type of Oracle. It allowed us (many of us) to easily
convert COBOL/ISAM based application to Java/Oracle combo with the help of
Toplink/EclipseLink.
Re: Fixed String or Oracle CHAR [message #376887 is a reply to message #376332] Tue, 22 July 2008 14:33 Go to previous messageGo to next message
Hi Gordon, I can see that you've proposed a fix for the said issue. Looks
good to me... :-)
Re: Fixed String or Oracle CHAR [message #381078 is a reply to message #376332] Wed, 03 September 2008 12:28 Go to previous messageGo to next message
Hi, I've been eagerly awaiting this fix but haven't seen it in the latest
releases. Do I need to build from the source? Thanks.
Re: Fixed String or Oracle CHAR [message #493313 is a reply to message #376332] Sat, 24 October 2009 13:04 Go to previous messageGo to next message
The patch worked for inserts. However, it doesn't work for Find and createQuery.
Is there something we need to do? Thanks
Re: Fixed String or Oracle CHAR [message #495482 is a reply to message #493313] Wed, 04 November 2009 21:20 Go to previous messageGo to next message
For those who are following this. I filed a bug report against this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=294138
Re: Fixed String or Oracle CHAR [message #495735 is a reply to message #495482] Thu, 05 November 2009 16:06 Go to previous message
Good news!!!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294138 is now slated for 1.1.4.
Big Thanks to Tom Ware!!!
Previous Topic:Unexpected Behaviour of Teneo while committing a transaction
Next Topic:OneToMany, FetchType.LAZY, CascadeType.ALL: Fails to persist child
Current Time: Sun Jul 20 04:40:11 EDT 2025
Powered by FUDForum. Page generated in 0.04459 seconds
