Resource doesn't exist [message #495391] |
Wed, 04 November 2009 12:14  |
Originally posted by: formatzeh.gmx.de
I want to open editor with a given model file as input. I do this
programmatically because I don't know the meta-model before. But in the
following line I get an exception:
org.eclipse.emf.ecore.resource.Resource loadedResource =
resourceSet.getResource(uri, true);
The exception is a ResourceException saying that the specified file
can't be found. The uri will be created from an IFile object and does
exist because the file will be created just before intending to open it.
Does anybody has an idea or isn't it an EMF concern?
Re: Resource doesn't exist [message #495570 is a reply to message #495534] |
Thu, 05 November 2009 06:22   |
--------------070306010001090405040200
Gilbert,
Comments below.
Gilbert Mirenque wrote:
> Hi Ed,
>> You should use resourceSet.createResource if you're creating something new.
> I looked into the sources of ResourceSetImpl.getResource and found out
> that internally a new Resource will be created.
Yep.
> The other point is that
> I can't modify the code of the part where the resource will be loaded.
Why not?
> That's why I tried creating a new resource before, hoping that the
> resource will be registered in the registry and found after that. But it
> wasn't successfull. The following is the code of creating the new resource:
> IPath path = getPathFromCodeFile(codeFile);
> File file = new File(path.toOSString());
> String[] parts = codeFile.getName().split("\\.");
> String extension = parts[parts.length - 1];
> IPath ext = path.addFileExtension(extension);
> File tempFile = new File(ext.toOSString());
> if(tempFile.exists()) {
> boolean deleted = tempFile.delete();
> System.out.println("deleted: " + deleted);
> boolean created = tempFile.createNewFile();
> if(created) {
> FileOutputStream fos = new FileOutputStream(tempFile);
> FileInputStream fis = new FileInputStream(file);
> while(fis.available() > 0) {
> fos.write(fis.read());
> fis.close();
> fos.close();
> ResourceSet resourceSet = new ResourceSetImpl();
> URI uri = URI.createFileURI(tempFile.getAbsolutePath());
> resourceSet.createResource(uri);
> Resource resource2 = resourceSet.getResource(uri, true);
> IFile iFile = getFileFromPath(ext);
> return iFile;
This all looks a bit tortuous. I'm not sure what you're trying to
accomplish.
> codeFile is a representation of files in my RCP app. Physically it has
> no extension but it is represented as a normal file with extension in my
> workspace. But as the editor needs an extension I create a copy of the
> file just before trying to open it and add the appropriate extension
> that the editor can open it. The editor internally calls
> And there the exception is thrown that the resource doesn't exist. But
> when I do the same with resource2 in the code above no exception is
> thrown. I don't understand this. Besides I don't know if it has
> something to do with EMF or if it is a problem if I get in trouble with
> the IFile semantics because the returned iFile will be passed to the
> constructor of a new extension of FileEditorInput.
Keep in mind that creating a file in the file system doesn't
automatically update the workspace to know about it. You should be
using platform:/resource URIs for workspace access, not directly
accessing the file system, which will also result in the workspace not
being properly in sync and will bypass things like the workspace
history. If you want to ignore all that, you can always catch the
exception and call resourceSet.getResource(uri, false) to access the
resource that failed to load.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hcu6fp$44c$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
<blockquote type="cite">
<pre wrap="">You should use resourceSet.createResource if you're creating something new.
</pre>
</blockquote>
<pre wrap=""><!---->I looked into the sources of ResourceSetImpl.getResource and found out
that internally a new Resource will be created.</pre>
</blockquote>
Yep.<br>
<pre wrap=""> The other point is that
</pre>
</blockquote>
Why not?<br>
<pre wrap="">That's why I tried creating a new resource before, hoping that the
if(created) {
fis.close();
fos.close();
return iFile;
</pre>
</blockquote>
accomplish. <br>
<pre wrap="">
</pre>
</blockquote>
resource that failed to load.<br>
</body>
</html>
--------------070306010001090405040200--
Re: Resource doesn't exist [message #495702 is a reply to message #495680] |
Thu, 05 November 2009 14:33  |
--------------030606010709050305010505
Gilbert,
Comments below.
> Hi Ed,
> now I found the copy function from the IResource interface and tried to
> solve it that way because it is nearer to the Eclipse "way":
> IFile original = getFileFromPath(path);
Of course I don't know what these do exactly.
> try {
> original.copy(ext, true, null);
> } catch (CoreException e) {
> e.printStackTrace();
> return iFile;
> But when invoking "copy" I get the exception that the colon : isn't
> allowed.
Sounds like you're using a OS-dependent file name where a workspace
relative path is perhaps required.
> So I tried it relative to the workspace path of my RCP app but
> then the "Resource doesn't exist" exception is thrown again.
> So how can I do file operations with platform:/resource URI's? Or how
> can I register a file in the workspace? Another strange fact is that the
> second parameter of "copy" is the flag for controlling whether resources
> that are not in sync with the local file system will be tolerated.
These aren't really EMF questions. Look carefully at the APIs you're
using and be sure to use workspace relative paths rather than
OS-dependent paths. Also look at the EMF FAQ for converting between
IFile/IResource and URIs used in Resources.
<html>
<head>
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hcv3u6$uk9$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
</blockquote>
Of course I don't know what these do exactly.<br>
<pre wrap="">String[] parts = codeFile.getName().split("\\.");
try {
return iFile;
allowed. </pre>
</blockquote>
relative path is perhaps required.<br>
<pre wrap="">So I tried it relative to the workspace path of my RCP app but
</pre>
<pre wrap="">Keep in mind that creating a file in the file system doesn't
</pre>
</blockquote>
</pre>
</blockquote>
IFile/IResource and URIs used in Resources.<br>
</body>
</html>
--------------030606010709050305010505--
FUDForum. Page generated in 0.05729 seconds
