Home » Modeling » EMF » Obtaining an EAttribut's container's implementation
Obtaining an EAttribut's container's implementation [message #495382] Wed, 04 November 2009 11:46 Go to next message
Hi all,
I feel I am struggeling with something very simple, here it goes:
I am iterating through a tree and collecting all EAttributes (and only
such) and the EObject they belong to (so it's parent, basically).
No I wondered why saving both, becasue there should be a way to get the
parent's implementation via the EAttribute. However, it seems I am
unable to get the right object.
If I do EAttribute.eContainer I'll get the container class, but not it's
implementation class which I need. So I am not looking for e.g.
"MyAttrib" but "MyAttribImpl"... ;-)
How to achive that?
With regards, Morten.
Re: Obtaining an EAttribut's container's implementation [message #495401 is a reply to message #495382] Wed, 04 November 2009 12:28 Go to previous messageGo to next message
Morten,
Comments below.
Morten MacFly wrote:
> Hi all,
The parent is an EClass while the EObject is an instance of that EClass.
> How to achive that?
Maybe this method on InternalEObject would be helpful:
* Returns a setting that can be used to access this object's feature.
* @param feature the feature of the desired setting.
* @return a setting that can be used to access this object's feature.
EStructuralFeature.Setting eSetting(EStructuralFeature feature);
I.e., it's an object that represents the EObject/feature pair.
Re: Obtaining an EAttribut's container's implementation [message #495499 is a reply to message #495401] Thu, 05 November 2009 01:46 Go to previous messageGo to next message
Thanks for the answer!
That is correct, of course.
While reading the answer I realised that of course I don't whant to have
the attribute's implementation, but the parent's implementation.
Just for clarification: I am working on a customised diagnostics view.
If an element does not validate (dignostic error) I want to be able to
jump to the attribute in the tree. For this to work when I setup the
BasicDiagnostic I need to provide/use the parent's implementation and
the attribute (with the error). It works perfectly if I use the EObject
I gathered while iterating trough the tree, but I didn't manage to get
the right parent only having the EAttribute at that point. Probably
There is an easier way?
This seems plausible to me, but how do I use it?
I read about InternalEObject:
"An internal interface implemented by all EObjects.".
So that means I can cast my EObject to that interface, obtain the
"Setting" by querying for the EAttribute (feature) and just store the
"Setting", right? Like:
EAttribute ea = eaEOEntry.getKey();
EObject eo = eaEOEntry.getValue();
InternalEObject internalEObject = (InternalEObject)eo;
Setting eSetting = internalEObject.eSetting(ea);
Then I should use the methods:
eSetting.getEObject()
eSetting.getEStructuralFeature()
....to obtain the pair I am looking for.
I'll try that...
Re: Obtaining an EAttribut's container's implementation [message #495565 is a reply to message #495499] Thu, 05 November 2009 06:18 Go to previous message
--------------030908020709060104020601
Morten,
Comments below.
> I'll try that...
Yes, that's the idea. You'll see it's used in the CrossReferencers.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Morten,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hctsbq$fer$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks for the answer!
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">The parent is an EClass while the EObject is an instance of that EClass.
</pre>
</blockquote>
<pre wrap=""><!---->That is correct, of course.
</pre>
<pre wrap="">Maybe this method on InternalEObject would be helpful:
</pre>
</blockquote>
<pre wrap=""><!---->This seems plausible to me, but how do I use it?
I'll try that...
</pre>
</blockquote>
Yes, that's the idea.&nbsp; You'll see it's used in the CrossReferencers.<br>
</body>
</html>
--------------030908020709060104020601--
Previous Topic:Extending a model
Next Topic:[CDO] CDO and RAP
Current Time: Sun Jul 20 09:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.04307 seconds
