EMF.Edit's ItemProviders ad-hoc behavior [message #494950] |
Tue, 03 November 2009 06:17  |
I would like to monitor the notifications so i put a println method for the console to display it, like:
public void notifyChanged(Notification notification) {
System.out.println("TableItemProvider: " + notification);
When I start a new Eclipse instance for the GMF editor to edit the model, I cannot always see that println method would run, because there is nothing on the console. It means that the notifyChanged does not run when for example I create a Table (this is a Model Element) on the diagram. Sometimes when I remove than re-add the Properties view of Eclipse windows and create a new diagram again, it seems good (a trick, but not sure it is the answer for the question).
I really don't know why I get notification in an ad-hoc way when something changed. The notifyChanged should be called every time when there is a change on the model caused by the diagram, but it doesn't seem to work in this way.
Regards, John S.
Re: EMF.Edit's ItemProviders ad-hoc behavior [message #494995 is a reply to message #494950] |
Tue, 03 November 2009 08:55   |
John,
Comments below.
John S. wrote:
> Hello,
Of course this only monitors changes for objects that have been viewed.
> the diagram.
I don't think GMF is using the item providers for the diagrams
themselves, only for the outline I think...
If you want to consistently monitor all changes, regardless of whether
the objects have been viewed, use an EContentAdapter on the resource set.
> Regards, John S.
Re: EMF.Edit's ItemProviders ad-hoc behavior [message #495334 is a reply to message #495197] |
Wed, 04 November 2009 10:34  |
John,
Comments below.
John S. wrote:
> Hello,
>>> set.
> My code looks like this in the itemprovider of a modelelement, but it
> still doesnt monitor all the time when i create this element with the
> GMF editor.
> @Override
> EContentAdapter adapter = new EContentAdapter() {
> @Override
> super.notifyChanged(notification);
> System.out.println("Notfication received from the data
> model. Data model has changed!!!");
> EObject eNotifier = (EObject) notification.getNotifier();
> ResourceSet resourceSet =eNotifier.eResource().getResourceSet();
> resourceSet .eAdapters().add(adapter);
You add a new one each time you get a notification. That sounds more
than a little horrible and still leaves you with the problem of it not
being attached until the objects is viewed. You need to attach it once
when the editor is opened and the resource set is created.
> I do not know what is missing.
> Best Regards
> John
FUDForum. Page generated in 0.25746 seconds
