Home » Eclipse Projects » EclipseLink » java.sql.SQLException: ORA-00900 calling StoredProcedure
java.sql.SQLException: ORA-00900 calling StoredProcedure [message #493858] Wed, 28 October 2009 06:07 Go to next message
Hi all
I was wondering if some one would be kind enough to help me with an error that I keep getting. I have a stored procedure which doesn't take any parameters. when I try and call it, I get the following error. the funny thing is I have other stored procedure which take parameters which I can all successfully with no problems. It only seems to happen with procedures that do not have any parameters. I have tested the procedure in both SQL plus and Sqldeveloper and it works fine. I am using OC4J 10.1.3.4, Oracle DB 10.2.0.4 eclipselink/toplink as the JPA provider and I am also using the oracle thin drivers i.e. ojdbc14.jar.
Can anyone help please?
Internal Exception: java.sql.SQLException: ORA-00900: invalid SQL statement
Error Code: 900
Call: BEGIN testJPAProc(); END;
Query: DataReadQuery()
Here is the procedure
create or replace procedure testJPAProc is
 begin
 dbms_output.put_line('testJPAProc called');
 end;
Heres is java code for calling the procedure
                                StoredProcedureCall call = new StoredProcedureCall();
		ValueReadQuery query = new ValueReadQuery();
		call.setProcedureName("testJPAProc");
		query.setCall(call);
		session.executeQuery(query);
thanks
Re: java.sql.SQLException: ORA-00900 calling StoredProcedure [message #493972 is a reply to message #493858] Wed, 28 October 2009 11:56 Go to previous message
Hi All,
I have found the solution.
It turns out that I was using the wrong query type. I should have been using DataModifyQuery instead of DataReadQuery/ValueReadQuery as the function returns nothing!!. I changed the query type to DataModifyQuery and it works now.
Previous Topic:JPA and JAXB Annotated POJOs
Next Topic:provide mappings that are not on the classpath
Current Time: Sat Jul 19 20:23:47 EDT 2025
Powered by FUDForum. Page generated in 0.06131 seconds
