Home » Modeling » EMF » first stab at using domain modelling tools
first stab at using domain modelling tools [message #493080] Thu, 22 October 2009 23:02 Go to next message
Hi all,
For my fresh new project I have been working with a team doing lots of modelling up front, and this offers the opportunity to use a code and JPA annotation generation tool from the start.
My initial look at what tools were available led me to stuff like rational and omondo which were quite expensive. However there appear to be many other implementations of tools to do the sort of thing that I am after, which is to design my domain/data model and generate the Java classes and JPA annotations from them.
So I was hoping to get some recommendations on where to start, I am currently looking at the class diagram editors, and they seem to work pretty well.
However I would now like to generate the hibernate and DAO code off the digrams and I was wondering which tool I should use for that
Tom
Re: first stab at using domain modelling tools [message #493085 is a reply to message #493080] Fri, 23 October 2009 02:00 Go to previous messageGo to next message
--------------030907080708030705040900
Tom,
Comments below.
Tom H wrote:
> Hi all,
Perhaps worth the price though? Their models were built using EMF...
Yes, there's free technology available for that as well.
> pretty well.
You mean the Ecore Tools editor? It's really very nice.
You should have a close look at Teneo.
http://www.eclipse.org/modeling/emf/?project=teneo
Martin has been working with the EclipseLink guys to provide integration
with that.
> Tom
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
<br>
Tom H wrote:
<blockquote cite="mid:hbr6cg$q35$1@build.eclipse.org" type="cite">Hi
all,
<br>
<br>
<br>
<br>
rational and omondo which were quite expensive. </blockquote>
Perhaps worth the price though?  Their models were built using EMF...<br>
<blockquote cite="mid:hbr6cg$q35$1@build.eclipse.org" type="cite">However
<br>
</blockquote>
Yes, there's free technology available for that as well.<br>
<blockquote cite="mid:hbr6cg$q35$1@build.eclipse.org" type="cite"><br>
pretty well.
<br>
</blockquote>
You mean the Ecore Tools editor?  It's really very nice.<br>
<br>
</blockquote>
You should have a close look at Teneo.  <br>
<blockquote><a href="http://www.eclipse.org/modeling/emf/?project=teneo">http://www.eclipse.org/modeling/emf/?project=teneo</a><br>
</blockquote>
integration with that.<br>
<br>
<br>
Tom
<br>
</blockquote>
</body>
</html>
--------------030907080708030705040900--
Re: first stab at using domain modelling tools [message #493097 is a reply to message #493080] Fri, 23 October 2009 02:46 Go to previous messageGo to next message
Hi Tom,
If you're looking for a full JEE stack generation, the Acceleo.org project
is providing tooling using stereotyped UML and generating DAO, DTO, and
Struts from that.
http://www.acceleo.org/pages/modules-repository/
The project is now moving to the Eclipse servers, but took that chance to
re-implement the core technologies from scratch, the JEE module has not been
ported to this new implementation so far :
http://www.eclipse.org/modeling/m2t/?project=acceleo
Cédric
Tom H wrote:
> Hi all,
> pretty well.
> Tom
Re: first stab at using domain modelling tools [message #493256 is a reply to message #493085] Fri, 23 October 2009 19:49 Go to previous messageGo to next message
[quote title=Ed Merks wrote on Fri, 23 October 2009 02:00]
> pretty well.
I've managed to get a domain model saved using both the UMLDiagramEditor from the UML2 project - which produces UML files and the Ecore diagram editor from the org.eclipse.gmf.ecore.editor plugin which produces ecore files.
I actually preferred the UML editor from the org.eclipse.uml2.diagram.clazz plugin!
I guess I am a little confused at this stage, does the gmf not use UML?
The teneo options only appear for ecore files, are there any options for code generation from the UML files?
Tom
Re: first stab at using domain modelling tools [message #493257 is a reply to message #493097] Fri, 23 October 2009 19:54 Go to previous messageGo to next message
Cédric Brun wrote on Fri, 23 October 2009 02:46
Hi Tom,
Struts from that.
I'm actually only looking for a simple proof of concept to start, just the data/domain objects and data access objects and some persistence tool (like JPA hibernate or whatever, at this stage I am just researching whats possible)
I've installed (well I appear to have 2 versions of Acceleo installed, with 2 perspectives, so I guess I have done something weird) Acceleo and am working through the docs.
Are the Acceleo and JET stuff similar?, I noticed they both provide a sort of template based code generation
Tom
Re: first stab at using domain modelling tools [message #493278 is a reply to message #493256] Sat, 24 October 2009 04:06 Go to previous message
Tom,
The Ecore Tools project provides a more polished Ecore editor and the
basic example on in GMF.
It's possible to import an Ecore model from UML and then take advantage
of all the technology based on Ecore, including the code generator of
course. The steps are the same as in the basic tutorials, except you
choose UML in the wizard instead of XML Schema or Annotated Java.
>> pretty well.
> Tom
Previous Topic:xsi:type in EReference as Featurekind "element" wrong
Next Topic:Trouble using profile - newbie
Current Time: Sun Jul 20 12:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.04717 seconds
