Home » Archived » Buckminster » Materialization issue
Materialization issue [message #491489] |
Wed, 14 October 2009 15:05  |
Hi there!
I am trying to use buckminster to help me create a development environment, but I am having a lot of problems on the materialization step.
I am also having some problems with selecting more than one component to place on my environment.
I am using this simple cquery and rmap files:
build.cquery
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap=" file:/C:/Pastore/Build/eclipse-SDK-3.5-win32/workspace_buck/ build/build.rmap ">
<cq:rootRequest name="org.eclipse.tml.device.feature" componentType="eclipse.feature"/>
<cq:property key="device" value="org.eclipse.tml.device.feature"/>
<cq:property key="localization" value="org.eclipse.tml.localization"/>
<cq:property key="protocol" value="org.eclipse.tml.protocol"/>
<cq:property key="vnc" value="org.eclipse.tml.vnc"/>
<cq:property key="vncviewer" value="org.eclipse.tml.vncviewer"/>
</cq:componentQuery>
build.rmap
<rmap
xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
<searchPath name="tml">
<provider readerType="cvs"
componentTypes="osgi.bundle,eclipse.feature"
source="true">
<uri format=":pserver:anonymous@dev.eclipse.org:/cvsroot/dsdp,org.eclipse.tml/{0}">
<bc:propertyRef key="vncviewer" />
<bc:propertyRef key="protocol" />
<bc:propertyRef key="device" />
<bc:propertyRef key="localization" />
<bc:propertyRef key="vnc" />
</uri>
</provider>
</searchPath>
<locator searchPathRef="tml"
pattern="org\.eclipse\.tml\..*$" />
<!--locator searchPathRef="tml"
pattern="dev\.eclipse\.org\\cvsroot\\org\.eclipse\.tml\..*$ " /-->
</rmap>
When I click the "Resolve to wizard" button, I can complete the task and save the BOM and MSPEC files. I can also open the BOM file and check my dependencies and it is correct. My problem begins when I try to materialize the BOM/MSPEC file. I just get nothing either from "Import -> buckminster -> materialize..." nor from "Resolve and materialize" button.
Any help would be greatly appreciated!
Thanks in advance!
Re: Materialization issue [message #491609 is a reply to message #491489] |
Thu, 15 October 2009 05:01   |
Hi Daniel,
I think you have misunderstood the way provider works. If you write:
<uri format=":pserver:mailto:anonymous@dev.eclipse.org:/cvsroot/dsdp,org.eclipse.tml/{0}">
</uri>
then you have declared a format string that takes exactly one parameter as input. That parameter is normally the name of
the component that the resolver is trying to resolve, i.e.
<propertyRef key="buckminster.component"/>
</uri>
If you declare that, then the first thing that will happen is that Buckminster will make an attempt to resolve:
:pserver:mailto:anonymous@dev.eclipse.org :/cvsroot/dsdp,org.eclipse.tml/org.eclipse.tml.device.featur e
given that it succeeds, it will read the dependencies declared in that feature and then try to resolve each one of them.
HTH,
Thomas Hallgren
On 10/14/2009 09:05 PM, Daniel Drigo Pastore wrote:
> Hi there!
> build.cquery
> <cq:componentQuery
> xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="
> build/build.rmap ">
> build.rmap
> <rmap
> <provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature"
> source="true">
> <uri
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="tml" pattern="org\.eclipse\.tml\..*$" />
> </rmap>
> button.
> Thanks in advance!
Re: Materialization issue [message #492699 is a reply to message #491657] |
Wed, 21 October 2009 09:08   |
Sorry to bother again, Mr. Hallgren!
I changed my RMAP the way you told me to, but my materialization process isn't working yet.
I tried following some other example, like org.eclipse.buckminster.tutorial.mailapp.releng, but I found out that the main difference is the
provider readerType="eclipse.import"
which really downloads components to the workspace and/or filesystem. But as far as I know, there is nothing like this on the TmL component I want to materialize. Also, all TmL components are either plugins or features, and they are hosted on a cvs server, so I think my provider is correct.
The CQUERY was simplified too:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="build.rmap">
<cq:rootRequest name="org.eclipse.tml.feature" componentType="eclipse.feature"/>
And now my RMAP is this:
<rmap
<searchPath name="org.eclipse.tml">
<provider readerType="cvs" componentTypes="osgi.bundle,eclipse.feature,buckminster" mutable="true" source="true">
<bc:propertyRef key="buckminster.component" />
</uri>
</provider>
</searchPath>
<searchPath name="org.eclipse.buckminster">
<provider readerType="svn" componentTypes="osgi.bundle,eclipse.feature,buckminster" mutable="true" source="true">
<uri format=" http://dev.eclipse.org/svnroot/tools/org.eclipse.buckminster /trunk/{0}?moduleAfterTag&moduleAfterBranch">
</uri>
</provider>
</searchPath>
<locator searchPathRef="org.eclipse.tml" pattern="org\.eclipse\.tml\..*$" />
<locator searchPathRef="org.eclipse.buckminster" pattern="^org\.eclipse\.buckminster(\..+)?"/>
</rmap>
I would greatly appreciate any help, because I'm really stuck on this issue. I have already checked and the resolution process is working fine since the BOM file is correct (at least it shows the right dependency tree).
Thanks again for your attention,
Daniel Pastore
Re: Materialization issue [message #492709 is a reply to message #492699] |
Wed, 21 October 2009 09:25  |
Hi Daniel,
In general, I think you can be greatly helped by enabling debug tracing for Buckminster:
"Windows" -> "Preferences" -> "Buckminster" -> "Console log level" -> DEBUG
Resolution/Materialization is normally performed by several parallel threads which can lead to some confusion. You can
limit it to one thead by setting the preferences "Max number of parallel materializations" and "Max number of resolver
threads" to 1. It will slow things down but the DEBUG output will be easier to read.
As always, our documentation is a good source:
http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminster/doc/BuckyBook.pdf (link available on the left hand
side menu of our homepage http://www.eclipse.org/buckminster).
Some comments inline:
> isn't working yet.
> the main difference is the provider readerType="eclipse.import"
Not sure what you are referring to when you say "nothing like this". Can you please elaborate?
> correct.
> <cq:componentQuery
What is relevance for the 'device' property?
> <rmap
> source="true">
> <uri
The 'mailto' part, should that really be in there? My guess would be that:
will work better ;-).
> </uri>
> </provider>
> </searchPath>
> source="true">
> <uri
> </uri>
> </provider>
> </searchPath>
> </rmap>
> tree).
As I mentioned earlier, debug trace is your friend. If you can't make it work, then it might help to include the trace here.
HTH,
Thomas Hallgren
Current Time: Sat Jul 19 09:14:39 EDT 2025
Powered by FUDForum. Page generated in 0.03607 seconds
