Home » Eclipse Projects » Platform - User Assistance (UA) » Eclipse help very slow to start on Suse 11.0
Eclipse help very slow to start on Suse 11.0 [message #492522] Tue, 20 October 2009 12:01 Go to next message
We are using Eclipse help system to provide on-line help for our applications on non-Windows platforms. We have been using Eclipse 3.3 so far, which worked for us. Recently I started to look into Eclipde 3.5.1, and noticed a strange problem. The Infocenter some times takes a very long time to start on Suse 11.0.
Here is my test environment:
Fresh install of Suse Linux 11.0 x86 32bit
Fresh install of Eclipse 3.5.1 classic SDK for Linux x86 32bit GTK
Sun JRE 1.6.0_16 x86 32bit
Here my command line to start Infocenter:
/home/sbao/eclipse/jre/bin/java -classpath /home/sbao/eclipse/plugins/org.eclipse.help.base_3.4.0.v2009 09170800.jar org.eclipse.help.standalone.Help -data /home/sbao/sa_help_launcher/workspace -configuration /home/sbao/sa_help_launcher/configuration -command start -eclipse_home /home/sbao/eclipse -debug
After I execute the above command line, I see the following output:
Debugging is on.
Lock obtained.
isApplicationRunning? false
Using workspace /home/sbao/sa_help_launcher/workspace
Ensured old .connection file is deleted. Launching Eclipse.
Launch command is:
/home/sbao/eclipse/eclipse
-vm
-nosplash
-application
org.eclipse.help.base.helpApplication
-data
-configuration
-debug
-vmargs
Configuration location:
file:/home/sbao/sa_help_launcher/configuration/
Configuration file:
file:/home/sbao/sa_help_launcher/configuration/config.ini loaded
Install location:
file:/home/sbao/eclipse/
Configuration file:
file:/home/sbao/eclipse/configuration/config.ini loaded
Shared configuration location:
Framework located:
file:/home/sbao/eclipse/plugins/org.eclipse.osgi_3.5.1.R35x_ v20090827.jar
Framework classpath:
Debug options:
file:/home/sbao/eclipse/.options not found
Time to load bundles: 3
Starting application: 1112
isApplicationRunning? true
Eclipse launched
Lock released.
As far as I tested, it can takes a very long time for the "The isApplicationRunning? true" to appear, some time up to 50 seconds. What really makes me to think that there must be a bug somewhere is that moving my mouse during the long wait times can suddenly make the loading process to become successfully completed.
Eclipse 3.4.2 has the same problem. But Eclipse 3.3 is always fast.
Is this a known bug? Did anyone see this before?
Thanks in advance.
Re: Eclipse help very slow to start on Suse 11.0 [message #493270 is a reply to message #492522] Fri, 23 October 2009 23:03 Go to previous message
I can't think of any reason why it would start up slower, both use the same server. I notice you had the debug flag set. Does it make any difference if you remove that flag?
Previous Topic:Run a JSP from within a help plugin
Next Topic:Sorting order for index entries
Current Time: Sat Jul 19 11:23:12 EDT 2025
Powered by FUDForum. Page generated in 0.03711 seconds
