Home » Eclipse Projects » SWTBot » Use Junit 4.7 with SWTBot
Use Junit 4.7 with SWTBot [message #492144] Mon, 19 October 2009 02:41 Go to next message
I use SWTBot with eclipse 3.4.2. is there a chance to use the newest version of junit (4.7)?
And if yes, what should I change for that? Should I only include it or must I contribute the swtbot plugins?
Re: Use Junit 4.7 with SWTBot [message #492158 is a reply to message #492144] Mon, 19 October 2009 03:54 Go to previous messageGo to next message
Eclipse the jdt-junit plugin in 3.4.2 depends on a particular version of
junit, changing the version by dropping in a new junit may not work. You
may try changing things though and see how it goes.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 19/10/09 12:11 PM, speedracer wrote:
> Hello,
Re: Use Junit 4.7 with SWTBot [message #492168 is a reply to message #492144] Mon, 19 October 2009 04:57 Go to previous messageGo to next message
thanks,
what is a good way to make this changes.
I hava an idea.
I generate a new plugin from the junit 4.7 jar.
Then I remove all dependencies and import packages of the junit4.3.jar from the swtbot plugins and add the junit 4.7 plugins as dependencie.
After that I build swtbot as a new version and add this to my eclipse installation.
Is that a good way, or not?
[Updated on: Mon, 19 October 2009 04:58] by Moderator
Re: Use Junit 4.7 with SWTBot [message #492190 is a reply to message #492168] Mon, 19 October 2009 07:42 Go to previous messageGo to next message
You could try dropping in the junit 4.5 bundle from eclipse 3.5 (and
picking up the eclipse 3.5 version of swtbot) and see how far you can go.
Ketan
On 19/10/09 2:27 PM, speedracer wrote:
> Hello,
> thanks,
> I hava an idea.
> installation.
Re: Use Junit 4.7 with SWTBot [message #492201 is a reply to message #492144] Mon, 19 October 2009 08:44 Go to previous messageGo to next message
> You could try dropping in the junit 4.5 bundle from eclipse 3.5 and
Hello Ketan,
can you explain me that.
Dit you mean, I should use the eclipse 3.5 version of the plugin org.eclipse.swtbot.junit4_x with the junit 4.5 libary? or have I misunderstood you?
Re: Use Junit 4.7 with SWTBot [message #492208 is a reply to message #492201] Mon, 19 October 2009 09:35 Go to previous messageGo to next message
1. Download eclipse 3.5
2. copy the org.junit4 plugin from eclipse 3.5 to eclipse 3.4
(overwriting it)
3. download swtbot for eclipse 3.5
4. copy the org.eclipse.swtbot.junit4_x because it works with junit>=4.3.
Ketan
> Hello Ketan,
> misunderstood you?
Re: Use Junit 4.7 with SWTBot [message #492250 is a reply to message #492144] Mon, 19 October 2009 11:15 Go to previous messageGo to next message
Thanks for the detailed replay.
But unfortunately, that doesnt function.
I dont get any compile errors bt when I start the test class as an swtbot test, I get the following exception.
Exception in thread "WorkbenchTestable" java.lang.IllegalArgumentException: No Classloader found for plug-in org.eclipse.jdt.junit4.runtime
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.getCl assLoader(RemotePluginTestRunner.java:79)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.readP luginArgs(RemotePluginTestRunner.java:94)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.init( RemotePluginTestRunner.java:84)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:63)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
But a normal Jnit Test for a single class does function
Re: Use Junit 4.7 with SWTBot [message #492331 is a reply to message #492250] Mon, 19 October 2009 23:20 Go to previous message
> Quote:
That's because the org.eclipse.jdt.junit4.runtime depends on junit4
between the range 4.2-4.4 as such it does not load up because the junit
version is 4.7.
You may need to additionally muck around with the
org.eclipse.jdt.junit4.runtime (possibly other plugins as well) and
change it's manifest (and delete the signatures in META-INF)
I'd recommend filing a bug on jdt and asking them for a workaround (I've
copied the jdt newsgroup)
Ketan
Previous Topic:clickLink fails if the linkText is too long
Next Topic:Re: [swtbot-dev] Workaround for Native Dialogs
Current Time: Sat Jul 19 21:09:52 EDT 2025
Powered by FUDForum. Page generated in 0.07598 seconds
